Question about Maytag Neptune FAV6800AW Top Load Washer
Beeping and changing spin cycle
It keeps beeping and changing the spin cycle and sometimes and change the the type of cycle I want to use
  • 526 Answers
Lets confirm the Machine Model number is it a FAV6800A?
If so I think this could be an issue with the Control Board.
Do you want to some basic troubleshooting like see if the Consol will let you into Service Mode?
If so let me know………Rich
FAV6800A/FAV9800A Service Manual for reference. Sears Parts Direct for reference
Posted on Aug 01, 2010
Good afternoon my wash machine Samsung WA17x7r does not spin anymore. Everything else work perfectly, except it doesn't spin nor for washing, rinsing or drying.
First thing to check would be your safety lock switch, see if it's engaged, can you open lid while still set on cycle? It shouldn't open. Sometimes they bend a little, no latching, won't spin, or a loose screw needs tightened.Sometimes the timer switch can be a little off. Pull off your knob that sets the cycles and see if it is in true line up with function. If not, I think I remember you can adjust it from behind panel.
Feb 17, 2017 | Samsung Washing Machines
Changed lid lock on a 750 simpson ezyset washing machine.
most likely a problem program board not moving onto the next cycle and that is why the lid lock is still activated
Feb 08, 2016 | Simpson Washing Machines
Whirlpool - MOD WTW 6600SW1 SER - CT 4270227 Type 580 For the past several weeks, the washer became progressively louder during the spin cycle and it sounded as if there was something rattling such as...
Sounds like you have change in the pump the coin may be stopping the propeller of the pump not allowing it to pump out the water. you may be able to take the pump off and clean the pump if the propeller is too bad you may need to replace the pump the pump part number is W10049390
Jul 15, 2011 | Whirlpool Washing Machines
My 3 year old lg w/machines lid lock keeps beeping through almost an entire cycle, also doesnt spin or rinse properly..what could be the problem???
It is probably the lid switch itself. They get bent sometimes. Try to adjust it if you can. It may be bad. That is why it is probably beeping. The lid lock will cause all of this.
Mar 05, 2011 | Washing Machines
Water level buttons keep cycle through continuously and the estimated time changes with the soil level.
hi thanks for the question. the actions of this washer that you are describing is normal these washers are a real pain in the you know what but it is normal welcome to the way they are building them to-day
Sep 19, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Stop beeping at end of wash on bosh machine
When the machine is on, but not running, press and hold the "pre-wash" button. After a few seconds it will begin that beep noise, keep holding it in until the beep volume goes down and finally stops. Once the beep has stopped, release the button and voila, no more annoying beeps at the end of your cycle.
To restore the end of cycle notification (beep) do the same thing as described above, but release the button earlier while the beep is still going.
Aug 16, 2008 | Bosch Classixx WFL 2066 Front Load Washer
My washing machine, after washing, changed to the spin cycle then started beeping so I turned it off, re-started it & when it got to the last spin cycle it just beeped then stopped. Now it wont start. It's...
No power? Let's see if we can solve this problem.
  1. Unplug then plug back again.
  2. Start the program.
  • If beeping send for repair/replacement.
  • If not beeping be happy to continue using your washing machine.
Jan 21, 2008 | Washing Machines
Maytag Neptune FAV6800AW Top Load Washer Logo
116 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
