Question about Stanley PC1A09 100 Watt Inverter Auto
My fuze for my Stanley PC1A09 has blown. The fuze is an 6S12A/250V. Where can I find one of these? I've checked local chain electronic stores and hardware stores and online but can't seem to find a 12 amp / 250v fuze.
2 Suggested Answers
mmnhltm
  • 695 Answers
SOURCE: The red light on my Stanley pc1a09 power inverter
POWEWR SUPPLY PROBLEM
Posted on May 10, 2011
I need to find a fuse for my jbl sub 160 subwoofer.
Those are pretty common. I'd pull the old one just to make sure the new one looks like it and be SURE the new one is a "Type T" or Slo-Blo.
Google "30mm 3.15A 250v slo blo fuse" and you will find them at Mouser, DigiKey, even Amazon. Better still--if you have a local electronic parts store, go there.
Sep 28, 2015 | JBL Audio Players & Recorders
Why did my radio and rest of the car electronics turned off on me
You may have blown the main fuze, if not then you may have blown a few fuzes check your fuze box and see if all are working, if they are please comment back on here what you did and we can go from there.
May 26, 2014 | 2004 Mazda RX-8
I have 2 10" Sony Explod Subs and a 1000w amp. My fuze was blown but i bought a new fuze that was stronger. My system is still not working.
the amp has power, ground and emote turn on? is the amplifier lighting up? is it going into protection?check the wiring to the amp before you suspect a bad sub and amp
Nov 01, 2012 | Sony Car Audio & Video
My harman kardon avr 520 shorted out. i see 2 fuses blown 1 slow burn 7a 250v slow burn & 1 slow burn 2a 250v 5x20mm. Is this a good place to start fixing it? i had metat to metal shorting because of...
The output transistors are most likely shorted and need to be replaced. Since this was a short caused by user action, there is a high probability that other components further back into the circuitry is also damaged. This is not a repair that should be attempted by a homeowner. Incorrect repairs can cause further damage, so I would suggest that you at least get a repair estimate from a local shop. If you have any electronics experience, we can then perhaps guide you through the actual repair.
Please keep us posted.
Dan
Oct 12, 2012 | Harman Kardon AVR 520 Receiver
Its keeps blowing fuses
what are you trying to use? 100 watt pretty small, could plug in cell charger..not much more!
Oct 21, 2010 | Stanley PC1A09 100 Watt Inverter Auto
Electrolux oxygen 3 fuse
The fuse on my ELECTROLUX Oxygen3's sumo board did have clear markings: F5AL250V - this is a 5A/250V 20mm fuse made by BEL FUSE, however, any other such fuse should work. The fuse on my board was blown (luckily, what caused it seems to be a glitch as replacing the fuse was all that I had to do). I got 5A/250V 20mm fuse from RadioShack and, expecting that this could happen again, I also installed a simple (5A/250V-rated) automotive fuse holder (also from RadioShack) (the only fuse holder that was available at a local store) and it works wonderfully now. Should the fuse blow on me again, I should be able to replace it in less than 3 minutes.
Feb 03, 2009 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Blown bulb in Maytag Neptune Drying center in tumbler section
1-800-688-9900 OR WWW.MAYTAG.COM, THIS SHOULD HELP YOU OUT.
Jan 16, 2009 | Maytag Neptune MDE5500AY Electric Dryer
BH2004D
I opened the back found out that the circuit board slid out easily and at the bottom is a 2A 250V fuze which was burned out. A $2.50 replacement from Ace hardware fit in nicely and the TV works perfectly now.
Jun 23, 2008 | Durabrand DWT1905 TV
Fuse blown
the fuse will always blow if there is a shorted component. the horizontal output transistor may be the most likely culprit, if you are not a technician, have it service by a qualified one.
May 15, 2007 | Samsung TXR3079 TV
Stanley PC1A09 100 Watt Inverter  Auto Logo
132 people viewed this question
Top Stanley Electronics - Others Experts
Clint Millett
ray gallant
Are you a Stanley Electronics - Other Expert? Answer questions, earn points and help others
