When I try and boot my laptop it says device driver not found mscd001 no valid cdrom device drivers selected. What now?
  • 4,281 Answers
When you power up the computer press F1 or F2 or del or ALT+F2 key to enter in bios then go to boot menu and set first boot device as cd/dvd rom then save settings and exit then try to boot from disk. First load optimal defaults settings of bios then set first boot device as cd/dvd rom then save settings and exit. Then check. Let me know if you need further assistance. Thanks for using FixYa.
Posted on Aug 01, 2010
My acer laptop cdrom does not boot start at all
Try uninstalling and reinstalling the CDROM driver via the device manager.
Right Click on Computer. Click on Manage. Go to Device Manager.
Right Click on the CDRom driver. Uninstall. Restart the computer so that windows will generate the driver. Update it. You can either go to the website of the computer's manufacturer to get the updated version of the driver or do it automatically by using RadarSync.
I hope this helps!
David
Apr 12, 2013 | Acer Aspire Computers & Internet
When i turn on my Acer Aspire One D255 it says: "check cable connection! PXE-M0F: Exiting Intel PXE ROM. No bootable device -- insert boot disk and press any key"
The PXE ROM is part of your system's network interface controller. It is being entered on your system's startup to look for a bootable image on a physical network connection and if found, to boot from that image. If there is no network cable connection to your system or if there is but no bootable device is found on that connection, the result is the error message that you got. As to why your system is entering the PXE ROM can be explained by looking at your system's Setup Utility,,,
Press F2 while powering up to enter the Setup Utility and use the cursor control keys to go to the Boot tab which then shows the Boot priority order. The default order is as follows...
1. IDE0
2. IDE1
3. USB FDD
4. USB HDD
5. Network Boot : LEGACY PCI DEVICE
6. USB CDROM
Your system's internal hard disk drive should be listed beside IDE0 and it will be accessed first to look for a boot record. If the drive fails to boot, the next devices in the list will be accessed accordingly until either a bootable device is found or the last item which is USB CDROM. If a USB CDROM is plugged in on one of the system's USB ports, it will be checked for a bootable record and if not found or no CDROM is plugged in, then the system displays the last part of the message -- insert boot disk and press any key.
Press F12 while powering up enters the Boot Menu which has the Boot Option Menu. This menu should show by default the following...
1. IDE 0: (the name/type information for your system's internal hard disk drive
2. Network Boot: LEGACY PCI DEVICE
If there is no hard disk drive information shown beside IDE 0, then the possibilities are that
1. there is no internal hard drive present
2. there is a hard drive but it has failed
If there is hard disk drive information and pressing enter to select it does not result in an operating system startup, then the drive's startup partition has been wiped and so it has no bootable image.
If there seems to be an internal hard drive present but it has no bootable image, you may attempt recovery from the installation images in the hidden partition. The recovery allows restoration of...
1. operating system to factory defaults
2. applications (selectable)
3. drivers (selectable)
Press Alt and F10 keys together while powering up and the Acer logo is showing to enter Acer's eRecovery Management. Follow the instructions to do the recovery.
Feb 09, 2011 | Acer Aspire One Netbook 8.9" Notebook
Iam can not access cdrom from dos iam using lg dvd rewriter
It's been a while but in DOs you need two drivers to acess a CD drive. One is a a generic driver loaded by your autoexec called MSCDEX.EXE. That should look something like
LOADHIGH=X:\MSCDEX.EXE /D:MSCD001
The next one you will need is the specific driver for the drive. For an LG I think it is gscdrom.sys
So for this you need an entry in your config.sys that looks like the following.
DEVICEHIGH=X:\GSCDROM.SYS /D:MSCD001
X is the drive you are booting from.
May 07, 2010 | LG GSA-H55N DVD-RAM Burner
CD drive refuses to open or run even when I press the button
Select a cd rom device,then add another boot up disc,then see if it opens.Will it take a cd rom better than a floppy? If so use the boot up disc,rather than an older and possibley more damaging floppy.
Feb 16, 2010 | E-Machines eOne 433 PC Desktop
My laptop acer aspire4730z i got problem with my cd-rom(can't run)Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39) ...my cd-rom drive(tsstcorpcd...
You have one of two problems....
1 - The driver for the cdrom drive has become corrupted somehow and needs replacing. Go out to the ACER website and download the cdrom driver specific to your make and model of computer (it is IMPORTANT that you provide specific information in the window boxes to get the correct driver for your hardware.) Once you have the new driver, uninstall the device from within Device Manager. Reboot the computer and when Windows proclaims it has found a new device, select to install the device driver from a specific location. Browse to the folder where you expanded the drivers and let Windows install and update the drivers from that location. OR the other possibility is....
2 - Your cdrom drive has died. Remedy, have it replaced.
Jan 24, 2010 | Acer Computers & Internet
CdRom/DVD not working at all
Right click on my computer and then select properties. Then select Device Manager. Locate the Optical Drive and then right click it and delete it. Reboot the computer and then it will reinstall the driver when the computer boots. Should take care of it.
Dec 17, 2008 | Toshiba Satellite M45-S169 Notebook
IBM Thinkpad T21 doesn't boot from CD-rom
Check the following:
1 make sure that the cdrom is okay. if not sure then try cleaning the cdrom lense which can be found in the cd tray,
2 make sure that the cd disc you are trying is a bootable one
Nov 24, 2008 | IBM ThinkPad T21 Notebook
Webcam
Make sure you have the drivers in the disc that came with the device. After inserting the disc to you pc, do not run the set up. Open MY COMPUTER, right click your cdrom drive and click EXPLORE. You must see DRIVERS in the folders. If you have DRIVERS on the disc, try to install the drivers manually.
You can only install the drivers if the computer is detecting the webcam. Go to DEVICE MANAGER and see if your webcam is listed on the devices. If pc is detecting it, you should see the webcam with a YELLOW QUESTION MARK(meaning drivers are not installed). Right click the webcam and click update drivers. Select install from a list of specific location. Select DO NOT SEARCH, I WILL CHOOSE THE DRIVER TO INSTALL. Select the HARDWARE TYPE(imaging devices), then click HAVE DISC. Click BROWSE, select your CDROM DRIVE, select the driver folder of the webcam. The drivers should be copied to your pc.
Good Luck
Mar 16, 2008 | Computers & Internet
I can't load my drivers dor the cdrom
google win98 bootdisk
the floppy you create will have them.
or just boot the win98 cd and there they are.
Feb 04, 2008 | Microsoft Windows 98 for PC
Armada E500
using edlin you can enter for config sys device=c:\dos\himem.sys device=c:\dos\emm386.exe noems device=c:\dos\cdrom.sys /d:mscd001 /l:e for autoexec bat @c:\dos\mscdex.exe /d:mscd001 ----------------------------------- config sys himem.sys is the upper memory manager emm386.exe is the 'gate' to allow access or combine all of it noems turns off expanded memory cdrom.sys is the CD Driver - yours may have a different name /d:mscd001 refers to the name of the CD Rom Drive (generic) /l:e refers to the drive letter (e:) to designate for the CD Hope that helps If used, rate me
Nov 11, 2006 | Compaq Armada E500 Notebook
Computers & Internet Logo
Alun Cox
David Payne
David Payne
