Question about Whirlpool GB2SHDXTT 22.1 Cu. Ft. Gold Bottom-Freezer Refrigerator - Biscuit
Replaced defrost thermast and timer now it wount turn on. was running before i replaced them but kept on freazzing over.
Maytag sxs; freezer frosts up no defrost + runs all the time + fridge side is cold.? Thanks.
Try to turn the defrost timer manually to force into defrost. If the frig defrost the ice then replace defrost timer. If unit dose not defrost the ice then check defrost heater and replace if needed.
Oct 26, 2014 | Refrigerators
What happens when the set wount turn on and the timer just keep blinking
the lamp needs replacement it blown replace it and reset timer the telly will be fine
Jul 05, 2013 | Televison & Video
Hotpoint side by side, freezer cold and frosty. Frig side not cold??
Signs of a defrost problem. Inside the fresh food section and behind the light cover you should see a small opening that leads to the defrost timer. Turn timer clockwise slowly until compressor and fans stop running. Leave everything in this position with fan and compressor not running for up to 30 minutes. Defrost should be taking place during this time inside and behind freezer rear wall.
Listen for signs of crackling or hissing coming from freezer. If after 30 minutes the defrost timer does not restart compressor and fans on its own then again slowly turn timer clockwise until they do start. If you need to do this you will need to replace the timer=> WR9X489 Defrost Timer If the timer is not the problem then the next two parts just may be the problem. The=> WR51X443 Defrost Heater Assembly that comes with a defrost thermostat as a kit. Let me know how you do with the defrost timer, Thanks, Sea Breeze
Jul 12, 2012 | Hotpoint Refrigerators
Bad defrost timer
The defrost timer is bad when the frig goes into defrost and stays off the frig should restart if you turn the timer, the frig will run fine until the timer cycles back to defrost then the frig will not restart. If this is what happens, replace timer and your problems are solved.
May 04, 2012 | Whirlpool Refrigerators
I have a maytag MSD2556AEA refrigearator and the coil freezes up. I've replaced the the defrost timer and the heater and it still freezes up.
While the suspected components have been replaced it is also important that the defrost timer works to move forward and switch on the heater. Also the connections to the defrost timer and heater must be checked., Secondly the thermostat must be checked or should be kept lower than the present point or to normal.
The compressor MUST CUT OFF from the switch on the defrost timer and put the heater to work. if not check the timer and wiring.
Jul 19, 2011 | Maytag Refrigerators
I found the refrigerator not cooling. I unplugged the unit, vacuumed the coils, plugged unit back in. The unit began to cool and kept it's temperature for 18 hours. I then noticed it began to cool back...
DEFROST PROBLEM
The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue to build up until the air can't flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad, it can prevent the heater from coming on OR it won't turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
With an ohm meter it should show continuity when cold and none when warm.
You can also bypass(disconnect the two wires plugged into it and twist them together) the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
The defrost heater is located on the evaporator. It is in a tube which is at the bottom and can also go up the sides of the evaporator. On some types you can see a burnt spot if it's bad. With an ohm meter it should show continuity from end to end when disconnected from the wiring in the freezer. You can also test the wiring for voltage when it's in the defrost mode.
If you have a defrost timer you can test it. It can be located under the fridge behind the kick panel on the front. Some are in the fridge with the controls at the top. You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer because that means the timer is not running. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
If you have an adaptive defrost control instead of a timer, replace it if the heater and thermostat test good. It is located in the fridge with the controls in some models and on the back in others.
Dec 26, 2010 | GE Profile PTS22LCSCC 33" 21.7 Cu. Ft....
My freezer keeps frosting up
if on the back wall of unit you have a defrost issue recommend replaceing the adc/timer and defrost thermast. if not on the back wall you have a air leak often found around the doors and the ice chute .more often the ice shut look to see if everything is closing tight
Jun 03, 2010 | KitchenAid (KSRD22FKST) Side by Side...
Everything in ref freezing up
1)check the temperature setting.it should be set on normal mode. 2) check if the ventilation in the fridge are blocked .there are two possibilities you will have to check 1)the defrost timer 2)the evaporator coil. How a common frost free defrost cycle works and the main parts. When the refrigerator is running ( cooling mode ) the defrost timer contacts prevents any power from getting to the defrost heater. When the defrost timer turns off the power to the compressor and fan motor(s) the power is then redirected to the defrost system. The defrost timer motor. Defrost timers:
The defrost timer is sometimes found behind the front grill of the refrigerator. It may also be found behind a cover plate inside the refrigerator or freezer, in the temperature control console, or behind the refrigerator near the compressor.
The timer is usually held in place with one or more screws. Remove the screws and gently pull the timer out far enough to disconnect the wiring connector.
Locate the timer switch and turn it clockwise until you hear it click. One click and the refrigerator shuts off = defrost mode, second click the compressor and fans come back on = run/cooling mode.
*Some defrost timers are a constant or continuous run timer, which means when ever the refrigerator is plugged in the defrost timer is powered up and running. Some defrost timers are an accumulative run timer, which means when the refrigerator is off the defrost timer is off and not running, when the refrigerator is running the defrost timer is running. This is also sometimes called a demand defrost. The power for the defrost timer goes through the cold control first on an accumulative defrost system. The timers are often the same but will be wired differently to get the different operations.
the evaporator coils are located at the inner side of the freezer section.if the ice gets collected in the coil and the evaporator fan stops running then the inner system of refrigerator will get over cool and this problem happens.
now to solve the issue .if to check evaporator coil is faulty or not there is a system.just unplug the unit from main power outlet then wait for 24 hours.then replug the power cord in the main power outlet.in 24 hours all the ice collected in between the coil and anywhere will get melted and then check out.if it works properly the problem was ice in coils.but if same problem then defrost timer needs replacement,you can get new timer friom
--- www.repairclinic.com
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya.
Nov 10, 2009 | Frigidaire ATF6000ES Front Load Washer
My admiral fridge/freezer runs a lot but does not get down to temperature
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Sep 14, 2009 | Freezers
Whirlpool Estate series fridge/bottom freezer no longer gets cold
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Sep 13, 2009 | GE GSS25LGM Side by Side Refrigerator
Whirlpool GB2SHDXTT 22.1 Cu. Ft. Gold Bottom-Freezer Refrigerator - Biscuit Logo
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
