Question about GE Microwave Ovens
I have a GE Advantium 120 oven, model number SCA1000DBB03. While the oven is turned off, the oven makes a stange noise. It's not the fan. If I unplug the oven, the noise stops. It doesn't seem to affect the ovens ability to heat or cook. Sometimes the noise is very loud. The noise continues if the oven is turned on. The sound does not stop if you open the door of the oven. The sound seems to be coming from the top portion of the oven. I noticed it for the first time after heating a glass of water for 2 minutes. The oven just "all of a sudden" started to make this LOUD noise. This went on for about a couple of minutes and then stopped. The LOUD sounded started again about 30 minutes later but didn't last as long. After 30 more minutes I walked over to the oven and could hear a sound coming form the oven. Remember, I only heated a glass of water for 2 minutes...and this was at 6:30 in the morning so we had not used the oven for about 10 hours.
5 Suggested Answers
SparkGap
  • 363 Answers
SOURCE: I recently purchased this home,
The manual is available on the GE web site
http://www.geappliances.com/service_and_support/literature/
Type in the model number
Good Luck.
Posted on Aug 26, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: GE Profile Advantium 120 Microwave (Model SCA1000DBB03)
We have the service manual for this model and have uploaded it to our site here to help you.
You will need the
free Acrobat Reader to view or print it in case you don't have it.
A microwave can be dead for many reasons.
It may be the fuse, which is usually located behind the grille, on the floor of the oven behind the control panel, between the door switches, or on the filter board near where the cord comes into the unit.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open.
Then when it cools, it closes the circuit and allows power through again.
When checking TCOs or thermostats, if it has a hood fan thermostat, that should read open, as opposed to the others, which should read closed.
So don't let that fool you.
If the cavity thermostat needs to be checked or replaced you'll need to pull the oven from the wall.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download GE owner's manuals and installation instructions here.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker (or GFI) when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
You should do a continuity test on the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again.
If you remove the fuse, then press the meter leads against the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on Dec 25, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: GE Profile Advantium 120 Oven not working; less than year old!!
No need to scan now...
We got the service manual for this model and have uploaded it to our site here to help you.
You will need the
I'm suspecting the keypad or a door switch or switch mount issue.
Also, you can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on Dec 26, 2008
heatman101
  • 43501 Answers
SOURCE: Have a GE Profile Advantium 120 over the range
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
kjf
Posted on Sep 30, 2010
Fan runs when door is closed and no time set.
Some GE units were starting on their own. I would definitely unplug this oven and call GE to make sure yours wasn't one of the ones being re-called.
Feb 14, 2013 | GE Advantium 120 Convection/Microwave Oven
GE Advantium Oven Noise
Most are eqipped with a small cooling fan that allows the unit to cool down quickly..fan may need replaced
Jun 07, 2012 | GE Microwave Ovens
SCA1000DBB03 ZA905619K Unit is DEAD
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven.......
heatman101
Oct 15, 2010 | GE Advantium 120 Convection/Microwave Oven
How do I unlock the control panel
If this is a GE Advantium series microwave, the control panel can be locked to prevent children from manipulating the controls. To lock or unlock, press and hold the CLEAR/OFF button for 5 seconds. These instructions are included on page 36 of the owner's manual listed here:
http://www.managemylife.com/mmh/owner_manuals/14895/GE-Built-In-Microwave-Oven-L0902200?brand_name_search=+GE+Advantium+120
If you have questions, please post back and let me know. Please include your MODEL NUMBER if diffrent form the model you posted this question under. I hope this helps you.
May 20, 2010 | GE Advantium 120 Convection/Microwave Oven
Ge advantium 120 powered off after a few minutes
I would call GE and explain the problem It may be a glitch in that model they may be able to give you the solution
Dec 29, 2009 | GE Advantium 120 Convection/Microwave Oven
Broken bottom latch on GE Advantium 120
You have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
Dec 25, 2008 | GE Advantium 120 Convection/Microwave Oven
Does not work after speedcooking bacon.
Most repair warranties are only 30-90 days, but you might consider asking the servicer if they'll cover it. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info (as well as a text file which helps in diagnosing and repairing door switch problems) at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams and order parts by entering your actual model number (like SCA1000DBB03, not Advantium 120) here: http://tinyurl.com/gv383 That part is the thermal cutout (TCO) or thermal fuse. It's reference number 1430 on the first diagram listed there.
May 07, 2007 | GE Advantium 120 Convection/Microwave Oven
Microwave Ovens Logo
53 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
