Question about Siemens Hammering
I attempted to change a fixture and the room switch in a bedroom. I have the fixture wired correctly. At the wall switch box, i have 2 black and 2 white. I cannot get power from either or any combination. The breaker is fine as all other circuits on it work fine. What's goin on???
    President:
  • 2,468 Answers
Is this a 3-way switch(as in can you control this light from more than one switch)?if so,then you may have a bad switch on the other switch
Posted on Aug 01, 2010
Hunter ceiling fan/light unit install with 3 pole switches. there are 2 white, 2 black and one orange wires coming out of the electrical box. How do i handle the installation?
Not understanding, three pole switch is a wrong switch, wires in the ceiling or wall electric box.
Needed: What switch is existing and what wires are in the switch box and runs or groups in each run coming in as wire groups. Same for ceiling box, colors and wires in each run coming in.
Basically, remove the existing ceiling fixture and connect the ceiling fan replacing the fixture to the same wires the fixture was connected to. White to white, green or bare to green or bare, colored wire to fan's blue and black. Wired like this one switch controls both fan and light, on and off at same time. Use fan pull chain switch for individual fan or light control.
Oct 22, 2017 | Hunter Dryers
Light switch wiring
Yes.
The code is maximum 12 boxes per circuit breaker.
You can connect a 12-2 NM W/G cable to one of the outlets. Black-to-black and white-to-white and ground-to-ground. Black is hot, white is neutral, and ground is ground. And bring that cable into a hollow-wall box you install 50" high on the wall. Then run the 12-2 cable up to your light fixture.
http://waterheatertimer.org/images/GE-15312-single-a-300.jpg
http://waterheatertimer.org/How-to-wire-switches.html
http://waterheatertimer.org/OWB1.html
You can also replace one of the outlets with a combo switch-outlet. The run singe 12-2 cable up to light.
This wiring diagram shows half way down how-to-wire-switches page.
Outlets have wide blade on neutral side, and narrow blade on hot side.
The black hot wires from old outlet connect to side of combo device with narrow blade.
The white neutrals from old outlet, and new wire going to switch, all connect to silver screw on wide-blade side of new combo device.
The black wire going to new light connects to screw next to switch located on wide-blade side of device.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Aug 28, 2012 | Electrical Supplies
How to wire this fan
The wiring on most paddle / ceiling fans id such:
White = Fan and Light neutral or "common"
Black = Fan line voltage or "hot"
Blue = Light line voltage or "hot"
Green = safety ground
If you are replacing an existing light fixture - be sure to replace the ceiling box with one designed for use with a fan - as per electrical code. If the existing box had only 2 wires (or 3 counting the ground) that connected to the old light fixture and it was controlled from a wall switch, the wiring would be fixture white to ceiling white, fixture black and fixture blue to ceiling black (or red) and fixture green to ceiling bare ground or connected to the metal box. This would power both the fan and light whenever the wall switch was on and the pull chains for each were also on. This is also the preferred wiring for replacement of a pull chain type light fixture (no wall switch present).
If there are other wires in the box that previously were not connected to the old light fixture, using a meter or tester - determine if there is constant power between the ceiling white wire and any of the these other wires (test with the wall switch on and off to be sure). If you do have constant power available, you might consider using the wall switch to control only the light, and using the pull chain to operate the fan (or vice-versa). Simply connect the black (for fan) or the blue (for light) to the "constant power on" wire and that part of the fixture will work by pull chain only - regardless of the wall switch position. If the fan can be shut off by the wall switch, it is very important that the wall switch remain a toggle (or on / off switch), do NOT replace with a dimmer type switch.
If you'd prefer to operate the fan and light completely independently of each other - you can purchase a 3rd party fan & light remote control device for between $30 - $50.
I hope this helps and good luck! Please rate my reply. Thanks!
Apr 22, 2011 | Aloha Housewares (93645) Ceiling Fan
I am trying to install utilitech 7 day in-wall timer. Their are 3 switches in box controlling different fixtures. The old switch had black connected and a black looped to the next switch. How do I connect...
1) Wires in box:
Black looped to to next switch is Black hot wire
Other Black goes to fixture
2) Connect timer wires
Black timer wire goes to Black hot
Red (or Blue) timer wire goes to fixture
White wire connects to white neutral wires (usually connected together with wire nut and pushed to back of box)
Green goes to bare ground wire
Sep 04, 2010 | Intermatic Inc. ST01C Digital In-Wall...
Switch stuck in trip mode
The reason why the breaker stays tripped is a result of a direct short. Unplug every electrical device plugged into an outlet in both rooms and try the breaker. If it stays on, individually start plugging in each device until the breaker trips, that is the defective device. If the breaker stays tripped, start checking wall outlets for short circuits with an ohm meter. If you did not find a short, check your hard wired lamps and appliances for shorts. If you did not find any shorts the only other problem is a shorted pair of wires in the wall or ceiling. You will need to disconnect any hard wired lamps and appliances and check for shorts between individual pairs of hot (black) and neutral (white) then hot and ground. I have a short circuit finder, but you do not need one because the technology is not perfect and you may have to manually check for shorts with a meter anyway which never lies.
Jun 25, 2010 | Square D Co. HOM130 Circuit Breaker
We have 2 identical fans in 2 different bedrooms. I had an aircompressor going and my daughter was running a blow dryer and it blew the breaker. Now both fans don't run, but the lights work. ?? the black...
Do me a favor, prior to reading on any further; did you try pulling (or turning) on the fan chain? As simple as this sounds, I've experienced this before. And I'd rather you try the simple solution first, before opening up the fixture. Okay, if that didn't work - the first TURN OFF the light switch or circuit breaker before working on these fixture's. If you're not well schooled in doing electrical work, I'd advise turning the circuit breaker off along with the wall switch. Now, when you open up your fixture, the black wire should be hooked up to the fan motor(s) lead wire; and the blue wire to your light(s) lead wire. Now, if both your fan and light were working before, then the wires at the fixture (black/motor and blue/light) were wired together. If so, then it could've blown both motor(s)? But I don't believe it did. Now that you've checked everything out, and your ready to turn the fixture back on. Keep the wall switch in the off position. Then go turn on your circuit breaker. If everything holds, then turn the wall switch on. It's done in this manner for safety reason's. Try this, and then let me know how it went. You should be good to go. Good Luck, and feel free to contact me again if you have any problems. Jim
Mar 16, 2010 | Hampton Bay 52 In.Carriage House II in...
I want to put a switch on a existing light that has a power source from the main panel then carrys on to other wall receptacles.i just want the light to go on and off with the switch, not the receptacles.
there is a simple way and a not so simple solution, the simple solution is to take down the light fixture and replace with a pull chain fixture. I would have to know the building type commercial ...residential...is it hard piped and so on. In a residential setting the solution would be to install a piece of 14-2 romex between the fixture and the switch. 14-2 with ground is a flat cable with 3 wires (2 insulated and 1 bare). do not attempt with the power source on. the white insulated wire should be connected to the black wire in the fixture box, the other end of the white wire in your new piece of romex should be attached to one pole of the switch. the black wire in your new piece of romex should be attached to the black wire or gold screw of your fixture and the other end of your wire should be attached to the other pole of your switch. Now the other wire(the bare ground)if not attached will not affect the operation of the switch or light, but it is a safety which should be installed. all grounds should be connected to insure that any faulty wiring will trip the breaker saving anyone from getting shocked.
Dec 21, 2009 | Cooper Industries Cooper Wiring 2158V 3...
I put up a new ceiling fixure which is controlled by a wall switch. The light now won't swirch off....... I attached the fixture's 2 black wires to the black and the black with a white stripe wire in the...
One of those cables in the ceiling is a power cable from the electrical panel . the other is a wire to the wall switch. if you have a meter then you can connect them correctly .. BUT ,, basic connection would be .. the two black house wires together ,, then a white wire to each of the fan wires .. that puts the fan/light on the switch control.
To be totally correct the white power wire should connect to the white fan unit wire.
Nov 16, 2009 | Westwind Classic Hugger Polished Brass 52"...
I have an outside spot light with a motion detector controlled by an inside switch. I want to change outside fixture & install dimmer switch in place of wall switch. I removed outside fixture. There...
First, let me say that if you're not entirely comfortable doing high voltage electrical work, you might want to call an electrician. It's not impossible for you to get hurt or killed or burn down your house. At least be sure to turn of the circuit breaker while you're working on it.
The blacks and whites twisted together are passing through power to other parts of your premises and are always on, so be sure to keep them twisted together. The red is the one that will take power from your light switch and send it to your light fixture.
At the fixture, connect the white to white and red to black, the same as before. At the light switch, connect the black to one side of the switch and the red to the other. When you turn on the switch, it will permit power from the black to travel down the red to the fixture, and from the fixture, the circuit will be completed through the white.
Sep 12, 2009 | Leviton (102-5G108-RW5)
Ceiling fan wires
is the old fixture still installed?
Oct 16, 2008 | Hampton Bay 24002 Ceiling Fan
Hammering Logo
207 people viewed this question
Top Siemens Hammering Experts
John Trevino
Steve
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Siemens Hammering Expert? Answer questions, earn points and help others
