Question about Whirlpool Refrigerators
I have a Whrilpool refrigerator, model #
I have a Whirlpool refrigerator, model # ED5FHEXSS00. Every afternoon when it seems to be going thru the defrost cycle, there is water that leaks from inside the freezer onto the floor. Is there a filter that needs to be replaced? Also, I just replaced the water filter with a PUR Whirlpool filter from Walmart. Is this as good as the filter directly from Whirlpool?
    President:
  • 2,468 Answers
The drain hose to the base is plugged that sends water to the lower area by the floor to evaporate
Posted on Aug 01, 2010
Whirlpool dimensions
Overall Height: 68 7/8" Cabinet Width: 35 1/2" Depth incl. Door & Handles: 33 3/4" Depth less Door & Base Grille: 29 1/4" Depth Extreme Swing of Door: 49 7/8"
Sep 02, 2014 | Refrigerators
Why will my Whirlpool Gold Refrigerator not get cold Again?
You probably have a leaking problem but of course just to sure call the company and ask for repair service. If the unit is still under warranty you will not spend anything but if's not then be ready with expenses.
Jun 12, 2013 | Kenmore Whrilpool Refrigerator End Cap...
How to remove icemaker from whrilpool ultraease refridgerator
I had a simular problem with my Whirlpool frig--First of all I would check 1/4 inch plastic line coming from water valve up to ice maker,loosen this line & try to blow thru it -if there is an obstruction it probably is frozen inside plastic fitting at top where it goes thru cabinet & into ice maker if so you can melt by by running a very warm metal object up & inside fitting be patient, you need to both inside & outside--If this the problem,your water valve is probaly bad because of not shutting off properly causing the "drip effect" you can purchase valve on line for aprox $10.00--$25.00 Good Luck--John Morris--
Feb 08, 2013 | Whirlpool ED2FHEXNS 21.8 Cu. Ft....
I have brought the new whrilpool refrigerator model is 12279 mm zx please send details to install
THERE IS A MANUAL BOOK THAT COME WITH IT JUST FOLLOW THED INSTRUCTION STEP BY STEP AND YOU WILL BE OK
Oct 24, 2010 | Whirlpool Refrigerators
Whrilpool refrigerator will not cool.
First, put the control back to it's normal setting. Turning it colder is not going to help. Then check the obvious, the coils underneath need to be cleaned, and the fan needs to be running. And check to see if there is a heavy frost on the back wall inside the freezer. If there is it could indicate a defrosting problem. Both will cause the temperature to rise. Also, be sure the fan in the freezer is running.
Jan 06, 2010 | Whirlpool ES5FHAXS Side by Side...
Whrilpool refrig, smells hot, so i cleaned the coils and turned it off for a few hours, seems cooling fine
sir, your refrigerator need a servicing. so please call the nearby service engineed to checkup the compressor condition, refrigerant pressure, etc.
thanks for contacting fixya
Sep 12, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Our side by side whrilpool frig. ice maker quit working,
I HAVE THIS SAME PROBLEM,I ALSO HAVE THE SAME MODEL.\
I CAN GET WATER BUT NO ICE IT IT SOUNDS LIKE ITS TRYING TO WORK,
BUT NOTHING COMES OUT.PLEASE HELP
NNANCY GREEN
Apr 11, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Refrigerators Logo
202 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
