Question about Mitsubishi VS-50609 50" Rear Projection Television
Digital chassis I need to know the price of the digital chassis or board for this tv
  • 927 Answers
Good Day,
Did not see a digit board but did you mean main PWB? If so the cost is $415.50, Part Number; 930B874001.
I hope this helpful,
big IRISH.
Posted on Jul 20, 2008
Power Issues with Sanyo DP50749
Main board is most likely but that is an educated guess--problem with all these is you can only check so many things and then have to guess and try a board.
Apr 22, 2012 | Sanyo DP50749 50 in. Plasma TV
Where are tha capacitors fo misubishi wd62725 located
1. If you haven't done so already... Unlplug the TV!
2. Remove the rear lower outside panel using a phillips screw driver. Set the panel aside somewhere where it won't get tripped over and broken.
3. Remove the screws from the lower metal panel that hides the electronics and connections. When removing this panel from the back of the TV, there will be an exhaust fan attached. You will need to disconnect the fan's connector in order to set it aside to get it out of the way. Take note that all the connectors inside the TV except for one on mine had the ends labeled with a code so that they could be matched up when it comes time to plug things back in. Just make sure that when you're disconnecting the connectors that you number them or code them if they aren't already marked as there are probably 10+ connectors that will need to be undone in order to get the electrical chassis out.
4. Remove the big metal plate on the left side of the electronics chassis. This will help you get the electronics chassis out of the TV.
5. Slide the TVs power cable up and out of the slot that holds it in place. This will also give you slack to move the electronics chassis out of the TV so you can work on it.
6. Unplug the USB and Firewire connectors from the top of the electronics chassis.
7. Carefully slide the electronics chassis away from the TV. Take note that you will have to start to disconnecting connections now in order to get the chassis out of the TV, I didn't fully remove mine from the TV. There were just too many connections that needed to be undone. So what I did was undo enough of them so that I could set it on a chair, but still connected to the TV.
8. Now the electronics chassis is out so we can work on it. Remove the protective metal housing from the electronics chassis and expose the circuit boards.
9. Now you should be able to see your circuit boards. There are typically two boards that have bad capacitors on them. One is called the DM board and the other the Power board. The DM is the hard one to get to as its the middle board of three. When accessing this board, be extremely careful of the ribbon cables at the bottom and sides of the boards. They can easily be broken, torn, etc... Again, take note of the connections you have to remove and make sure they're labeled. Take a picture of things if you need too.
10. Now that you can see the capacitors on the DM Board, look for a grouping of capacitors:
11. Now look at the Power board. Its the board on the back of the electronics chassis. There are two capacitors to look for here: Photo of Power Board Capacitors Are these bulging or leaking? If so, they'll need to be replaced. Look for others while you're here. I ordered mine from mouser using this part#: Mouser Power Board Capacitors Link
12. Once you have the capacitors replaced. Button everything back up and hope for the best.
Nov 29, 2011 | Televison & Video
I think my convergence is off. Just the green and red seem to look off. I do not know how to adjust each color. When you go into the convergence setting under the menu and it just does like an automatic...
You will need to know How to Enter the Service Menu to bring up the Convergence Pattern in order to adjust the Convergence,another thing is it depends on which chassis you have RCA had bought the right to use the name Zenith, when in fact these TVs had RCA Chassis and not Zenith Chassis
Remove the back to Tv, Make sure TV is unpluged and look to see if you have on a board Located on the right hand side
2 Big Black ICs they will have Part number on them example STK392-570 these are your convergence ICs that need to be replaced.You can exchange this board for new board at Zenith exchange moduels 1-800-632-6637
But if you have the RCA Chassis then you will have 2 bottom boards one on the Left hand side will be the Deflection board it will have the FBT flyback transfomer on it and their is 2 Ribbons that connect to the board on the right handside which is the ssb board that has your cable/AV input jacks on it.and their will be 2 boards above the 2 bottom boards if these are the boards you have then you can with Tv Off Press and Hold vol- and ch- wait untill TV comes on,release buttons and then you should be in the service menu to adjust convergence manually. R/G/B
For these chassis PTS rebuilts boards 1-800-844-7871
Jun 26, 2011 | Zenith R57W46 57" Rear Projection...
I have 2 RCA 52" projection TV's. One has a
RCA always has the part number stamped on the board. It will be a six digit number and usually is preceeded by "P/N". I have worked on these units and would guess that many of the boards are the same. Check the part numbers and if they are the same and the physical layout of the board looks the same the boards should be interchangable. I could not determine through research if the parts are the same because the units are older. I did determine that the CRTs are identical which would mean that more than likely the control signal board for them will also work.
Thanks for using FixYa and for the great rating.
Apr 19, 2011 | RCA P52921 52" Rear Projection Television
I have a 60" rear projection Mitsubishi Tv with a "wavy" picture in the vertical direction. What may be the problem?
You have dreaded model that build around so called V-26 chassis. It's an epic story of Mitsubishi's bad engineering several years ago. They even faced class action about it and issued recall that (of course) already expired by now. You can search web for info on court case against Mitsubishi. This particular issue is caused by faulty components in Format board that is part of the chassis. The only right way to fix it - is to remove whole chassis (sandwich of several boards in metal enclosure) and send it to Mitsubishi to get rebuilt. If you will pay someone for repair of just this board - soon others will fail as well, one of another associated issue - after unplugging TV from the wall outlet you have green blinking light forever (reboot does not come to complete).
Right now Mitsubishi lowered price for rebuilding from $640 to $320 for authorized Repair Centers nationwide. Add to it labor charge for removal/installation (at least $150) and shipping (Mitsubishi assign number for repair and send special padded box that fits chassis) at least another $50.
Also take into consideration that lamp inside of your TV sooner or later have to be replaced. It is another $150-$225.
Calculate all of this together - that's how much you have to spend to watch your TV for another 2-3 years.
Common sense would be to cut you losses and invest in new one.
As for my experience - I've removed/installed those V-26 chassis about 1000 times or so while working for Mitsubishi Authorized Center.
Hope my knowledge of this issue would help you save some money.
Aug 18, 2010 | Mitsubishi WD-62525 62" Rear Projection...
RCA F32650 Bad Circuit Board
try pts electronics, just go to search engine and type board number and it will tell where yoiu can buy it . at least 250.00
Feb 26, 2009 | RCA F32650 32" TV
Flashing timer light, cannot turn on tv
Press and hold "Device" and "Menu" buttons for six seconds and see if you then get a patter of flashes pertaining to the error codes... I would suspect one of the following codes:
12 No Error Detected
22 Recovery From Momentary Reset
32 Lamp Cover Open
33 Air Filter Cover Open
34 Lamp Abnormality
35 Chassis Fan Failure
36 Exhaust (Back Cover) Or Lamp Ballast Fan Failure
37 Engine (Dmd Or Lamp) Fan Failure
38 Excess Lamp Temperature
39 Excess Dmd Temperature
41 Short Detected
44 Dvi Cable (Between Chassis And Engine) Disconnected
Sep 26, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Blue screen with flickering horizontal lines
Sounds like the 1000uf capacitors on the FMT board need replacing. This is a common symptom with that chassis. There are three 1000uf caps that fail on that PC Board
May 23, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi ws-65807 v17 chassis
go to this websight leave an e-mail with your model number and let them know you need a signal board and they should be able to help you plus there prices are very reasonable and they also offer free online tech support to their customers
Apr 29, 2008 | Mitsubishi WS-65807 65" Rear Projection...
Mitsubishi VS-50609 50" Rear Projection Television Logo
49 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
