Question about Samsung Heating & Cooling
Water not draining properly coming into the inside of house
  • 10,865 Answers
Hi. Check the hose as it is either clogged, or pinched or simply not positioned to drain out. J.
Posted on Aug 01, 2010
My water levels are fine. why does my 2001 eclipse get water inside only on the drivers side, its not antifreeze.
The AC condensate (water/condensation coming off the cold evaporator core) drain is plugged. The drain hole is located inside the AC blower motor housing and drains out at the base of the engine bulkhead on the passenger side under the vehicle.
Jul 13, 2017 | Cars & Trucks
Does it come with a drain pug to let water out of unit
no -- there is no drain plug for air conditioners
If you have a problem with water dripping inside the house --down the wall --there is a drain at the bottom of the evaporator ( inside section) that drains water outside
that becomes blocked with gunk and dust from the room and has to be cleared occasionally.
Jul 29, 2015 | Heating & Cooling
My water supply pump to house works but does not pump water from tank to house
What type of pump is it? Is it a shallow well pump or submersible
pump? Is the pump connected to a pressure tank? How have you confirmed that the pump is working properly? Is there a drain valve, and is there water pressure from the drain valve when it is opened? If the pressure tank is of the pre-charged type, is it working properly? Is there water coming out of the air valve? Are there any shut-off valves in the system which may have been turned off, preventing water flow?
Apr 17, 2014 | Saniflo 021 Saniswift Residential Water...
Where is the drain hole on goldstar window ac my ac keeps dripping water inside the house
Hello, make sure the unit is tilted toward the outside a bit, if it is level the condensate will collect in the front and start dripping inside the house. Also, if the unit has a drain make sure it is clean so the water can drain out properly.
Jun 07, 2011 | Goldstar KG6000R Window Air Conditioner
On my LG window AC Md. LWHD1009R, I cannot find a drain hole to let the water out. The back bottom of the pan was filled water containing a rusty sludge, but the heat exchanger coils are aluminum, so it...
usually in the middle underside of the window units is a hole that water drains out of, you can always drill new holes in order to make it drain, Good Luck Tim
Apr 24, 2011 | Heating & Cooling
The air conditioner is pouring water on the floor!
Sounds like your water drain line is plugged. There should be a bundle of wires tubes and a drain hose that goes through the wall to the outside unit. The water drain hose should split off outside and drain on the ground. You should check that the drain hose is not plugged or kinked somewhere. The hose must also slope downwards from the inside unit to where it drains outside. You can check if the hose is plugged by blowing into it if you can reach the hose outside. You should be able to easily blow through the tubing back into the house. I have done this with this type of unit at night (determined to get it working), and was able to get it to start draining properly. Before I got it to start draining, I had the same waterfall that you are seeing. The unit had been off all winter. Hope this helps.
May 23, 2010 | Fujitsu 24C1 Air Conditioner
Washer not draining properly.
your pup is not working properly it may have somethig inside or draining house coud be that problem too good luck
Nov 05, 2009 | Maytag Neptune MLG2000A Front Load Stacked...
Water standing in Dishwasher
Hello buzzy220,
If you have water remaining in the bottom of your dishwasher then I would check the following:
  1. The drain filter screen is free from food byproducts that might limit drainage.
  2. The drain line exiting the dishwasher itself.. is it kinked or clogged?
  3. If your drain line is plumbed into a garbage disposal side entry, is that clogged or your house drain clogged?
  4. Is your dishwasher pump contaminated with sediment or anything that would limit its ability to pump?
  5. Are the water lines that come into or out of the pump blocked, damaged or restricting water flow?
Those are the main reasons areas of concern to investigate.. BTW, your drain line exitting the dishwasher should be routed up high and down into your sink drain system or thru the garbage disposal tap so that you have an air gap as 20YRSEXP was inquiring about..
You can run a simple test to verify all this..
Detach your drain hose from the house drain system ( from the garbage disposer or sink drain.. then route that into a rubber barrel ( be sure to keep part of the house up around the height of the countertop when you do this.. )... You should see a fairly robust flow of drain water into it when the system functions properly.. I would encourage you to run this test with no dishes inside it,.. This test will tell you if the restriction is in the dishwasher or house drain side..
Hope this helps you..
Regards,
Rick
Nov 28, 2008 | Maytag 24 in. MDB5600A Jetclean II...
My sister was stumped because her window unit a/c keeps leaking water inside her house.She even had her husband drill a small hole in the housing of the a/c, so that it would drain excess water more...
If you remove the lower casing of the unit, you will find that it was design in such a way the water followed a certain track. Your problem should be fixed if you align that track with the opening to coils so water should drain in the proper track.
Aug 20, 2008 | Heating & Cooling
Heating & Cooling Logo
77 people viewed this question
Top Samsung Heating & Cooling Experts
gbob59
billconfused
Are you a Samsung Heating and Cooling Expert? Answer questions, earn points and help others
