Question about Sport & Outdoor - Others
Hi, I just bought a used Schwinn 418 elliptical, suposedly the computer needs replaced. When I plug the adapter I imidiatly get a display of "Error 1". The machine seams to function very smoothly at a moderate tension. I have looked at previous reponses on this site to this and found two contraticting answers, one suggests a cabeling/electrical or computer problem, the other a step by step on how to "unstick" the servo. Before I start taking things appart or just ordering a new computer, any advise how to narrow down the possiblities? Thanks.
  • sjmcgrady Aug 03, 2010
    Is there a list of possible issues Error 1 would address? Taking the machine to a repair shop is not a good option, I bought it used and it is big and difficult to transport. Any suggestions on what I could try to maybe at least eliminate some possiblities? I was planning on just ordering a new computer, because that is what the seller told me was wrong, but now I am worried that it may not have been the truth and I will end up purchasing a computer and end up with the same problem.
    Guru:
  • 825 Answers
This is definitely the problem with cabling structure... becase the computer detects there  is an error1... it clearly says that the computer is working fine only thing is it is not able  to detect the device connecte to it... so check with the cabling structure before buying a new one...
Posted on Aug 04, 2010
  • sjmcgrady Aug 04, 2010
    that does make sense, I suppose we will have to try and fiddle with it, maybe we can figure something out. Thanks.
  • 10,865 Answers
Hello. I recommend that you take it into a Schwinn dealer for a free estimate. The problem with repairing these things is that it is so easy to put money into a repair part that is not necessary. Since I used to consult with these shops, I can tell you that they often replace the suspect part to see if that is the fix and if it is not they replace the new with the old and keep eliminating suspect parts. This is the luxury you do not have at home as most times once you purchase any electronic component you can not return it. J.
Posted on Aug 01, 2010
  • sjmcgrady Aug 02, 2010
    Well, taking it to an expert is easier said than done, it's not exactly something that can fit into my cartrunk. Also, do you have a recomendation of where to get a "free" estimate?
    Is there any list of issues that "Error 1" indicates? What's the purpose of an error code if it dosn't mean anything.
    Now I'm frustrated, I may have made a bad decision purchasing this after all, sigh...
The digital read out on my 420 elliptical schwinn system blinks on and off. There is no error code
follow this steps and replace batteries too. God bless you
Check power problems if the console on the elliptical machine does not light up. Make sure that the plug for the machine is secure in the outlet. If it is plugged in, ensure that the outlet is receiving power. Check the breaker to make sure it has not tripped off.
Be sure that you are using the correct adapter that came with the elliptical machine. Because different adapters are able to handle differing amounts of energy, the wrong adapter will not transfer electricity like it should. If the adapter is pinched or damaged, this could also alter its effectiveness.
2 Make sure the correct adapter is being used if the resistance settings seem to be too hard or too easy. If the correct adapter is being used, reset the machine. To reset the machine, either switch the "On/Off" button or unplug the machine from the wall. Doing this will allow the device to reset itself to the default resistance. Turn on or plug the device back into the wall and retry all of the levels of resistanc
Oct 01, 2013 | Schwinn 420 Elliptical Trainer
Looking for manual for 418 elliptical repair and user type
Hello Mug,
Please download the Schwinn® 418 Elliptical manual from the link provided below :
http://download.dfxi.com/supportdocs/AM/Schwinn/SCH_418-428_AM_web.pdf
Oct 10, 2011 | Schwinn Exercise & Fitness
The computer on my schwin 418 eliptical does not work. Is there something I can do to fix it myself? Where can I get it serviced?
Call Schwinn customer service (actually Nautilus) at 1-800-nautilus if it is broken so you can order a new one or they will send you a new one if you are under warranty. They are very helpful. You can also check the power connection on the bottom or make sure the wire harness in the main pipe in the center is properly connected if the system is brand new and not working.
Jan 04, 2011 | Schwinn 430 Elliptical Trainer
I have a 418 schwinn elliptical and the screen went blank while I was using it. I changed the batteries and looked at the wires that connect to the console everything looked good but still nothing. What do...
hi there, did you get your problem solved? I am having the same problem and are searching everywhere without a satisfactory answer. hope you can help out!
Oct 21, 2010 | Schwinn 430 Elliptical Trainer
I have an Eliptical Trainer BY-430E. I keep getting Error 1 every time I turn it on to use it. Does anybody know how this can be repaired. Thanks in advance
Error 1 on a schwinn is a generic electrical error. Check your ac adapter and make sure you're getting the proper voltage off of it. Typically an error 1 warrants a replacement of either the ac adapter, the wire harness (wires that connect the power to the console) or the console itself. If the console has batteries, change those first, then check your adapter. If the problem persists, you're looking at a more in depth problem that will require taking the casing off the machine and individually testing each component of the machine. It's usually worth at that point to pay a tech to look at the machine for you.
Jun 28, 2010 | Schwinn 430 Elliptical Trainer
I am trying to remove the covers on my Schwinn 418 elliptical trainer. The covers hang up on the crank/flywheel. The repair manual says to use a crank puller. Is there another way. If not what type of...
Hello there. Unfortunatley there is no way other than removing the crank arms. You do need to remove the nut on the axle and you will need a crank puller. The puller is available at any local bicycle shop for around 10-15 dollars.
Good Luck Tim
Jan 31, 2010 | Schwinn 430 Elliptical Trainer
Schwinn 418 Computer does not come on.
Did you ever fix this? I am having the same problem...
Dec 10, 2009 | Schwinn 430 Elliptical Trainer
Sport & Outdoor - Others Logo
Top Sport & Outdoor - Others Experts
Marvin
Marvin
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
