Question about Maytag Neptune MDE6700A Electric Dryer
I have a maytag neptune f/l dryer model #MDE6700AYW that displays an error code that looks like a capital E5 without the top horizontal line. when I go into diagnostic mode the most recent error code is a 01. According to the tecnical info. manual it can be rectricted vent, clogged lint screen or the Thermistor resistance. I have cleaned and checked the entire vent system etc. and changed the thermistor but the error code is still showing. I hope you can give me something to go by. Do I need to clear the error code somehow. P.S. this all started when i accidentally bumped into my dryer door transfering clothes from the washer to the dryer.
  • mrgarrett1 Aug 04, 2010
    i have not yet tried testing the different components that you have suggested, due to computer failure that i also had to deal with, but another question is : Is there a reset code for the dryer board or a reset button for the dryer. I just find it unbelievable that this all started because i bumped into my dryer door or is that just a coincidence. i would hate like he.. to cause more problems by tearing more things apart just to test them if there is an easier route like a button or a code. Besides wouldn't a different code show up if it was something other than the items i have already tackled?
    President:
  • 1,554 Answers
It is actually fault code "tS" which indicates that the main electronic control detected a very low thermistor resistance or the thermistor is shorted. It is also supported by the recent error code "01".
Since you have cleaned and checked the entire vent system and changed the thermistor but the error code is still showing, this signifies that the thermistor wire harness is shorted. Check it by measuring the resistance between the wires with a multimeter. Set the multimeter to its lowest scale setting (R X 1). If the wires are indeed shorted, recheck the resistance between the wires at the main electronic control side. Replace the wire harness should it confirm a short circuit condition. Otherwise, check the resistance between Pin #2 and Pin #6 of connector CN6 on the main electronic control. Replace main electronic control board if a short circuit is found between Pin #2 and Pin #6 of connector CN6.
Feel free to update us about the development of the troubleshooting and repair. You don't have to accept or reject and rate this post to add information or post comments and follow-up questions. Accepting a solution does not stop you from communicating with an expert. You can continue communicating with the expert as long as you need assistance regarding the issue stated herein.
Posted on Aug 01, 2010
  • 2 more comments
  • mrgarrett1 Aug 01, 2010
    do you have a picture or diagram of the control board that i can work from? thank you! wanda
  • Jahn27
    Jahn27 Aug 01, 2010
    Here is the picture/diagram of the main control board:
  • Jahn27
    Jahn27 Aug 04, 2010
    There's definitely no such reset button for the dryer. It can be simple coincidence that the fault code flashed after you bumped into the dryer but the thermistor might have been dislodged causing it to short. A different code would definitely appear if the issue is other than a shorted thermistor. All you can do is follow the troubleshooting guide outlined in the previous post and you should be able to address the problem.
  • Phil Fritz Sep 25, 2012
    I have Maytag Neptune model MDE6700AYW; the panel LEDs light up as normal, but does not run. Checked and clears int trap, and the exhaust tube (not much in there anyway). I do hear a "click" as if it is about to start, but it does not run, and all lights look normal. I entered Service Mode by pressing Chime and Temp to get diagnostic codes, which show as 10 and 08, but, I can not get into software revision or System Check mode. Any ideas?
Amanda dryer 7200 series error code E5 code?
The E5 error code is only referenced by a technician. More than likely it refers to a circuit board problem. Only solution is to have it replaced by a technician.
Apr 18, 2014 | Amana NED7200TW Electric Dryer
Maytag Neptune dryer, model mde6700ayw, cycle selector knob will not change cycles. It gets stuck on a random cycle even when I power off, power on. Tried to put in service mode but as the cycle selector...
you have a problem with this dryer,the computer board and other parts are no longer available,your better off replacing the dryer.if you go here you can see the parts
http://www.searspartsdirect.com/model-number/MDE6700AYW/3048/0151200.html?searchType=modelSearch&q=mde6700ayw&searchTerm=mde6700ayw
Sep 06, 2017 | Maytag Dryers
Maytag neptune error message e5
This normally indicates that the thermistor is bad. Try measuring it to prove it is OK. It should be 10K Ohms at room temperature (20C / 68F).
If necessary, replace it then clear the error code.
1. Enter to Service Mode by press CHIME and TEMPERATURE keys for 3 seconds or until 3 beeps are heard.
2. Access Diagnostic Codes by pressing WRINKLE PREVENT. A d will be displayed. Rotate the CYCLE SELECTOR KNOB in either direction to read it.
3. Press SENSOR DRY and TIME keys for 3 seconds to clear it.
4. Power OFF to exit Service Mode
5. Power ON
Sep 06, 2012 | Maytag MDE9700AYW Neptune 174 Electric...
My Maytag Neptune dryer is still flashing the E5 code
I looked up and there is no E5 error code listed in the tech sheet.
Check it and confirm us.
Oct 13, 2011 | Maytag MDE9700AYW Neptune 174 Electric...
My dryer is still flashing the E5 code after I changed the themister
Oct 13, 2011 | Maytag Neptune MDE4000 Electric Dryer
I have model # MDE6700AYW (Maytag Neptune electric dryer) Error code T5, service codes 0, 19 and 76. Can anyone tell me what part needs to be replaced?
Check to see if your thermistor is bad by measure the resistance. It should be 10K Ohms at room temperature.
If it's bad, replace it BUT you have to CLEAR to error code.
5. Power ON
Here is a link to the part in case you need it.
Aug 23, 2011 | Maytag Neptune MDE6700A Electric Dryer
Maytag neptune dryer has e5 error code
I looked up your model and there is no E5 error code listed in the tech sheet.
Download a copy of your tech sheet here.
files.me.com/appliancejunk/e8bg66
When I search the maytag data base this is the service manual it list for your model number.
http://appliancedigest.com/index.php?/files/file/81-16023110-maytag-sloped-front-dryer-repair-service-manual/
If the dryer is running but not heating then the relay on the control, ignitor or thermistor are the most likely causes.
Aug 03, 2011 | Maytag Neptune MDG5500AW Gas Dryer
MAYTAG DRYER NEPTUNE MODEL MDG6700AWW SHOWING ERROR CODE ON PANEL E5
this is a way to diagnose your dryer, as the only codes I have ever saw E 1,2 and 3:
http://media.fotki.com/1_p,srtrqwwdrrfrtkrxgtqsskgwtqkq,vi/bqdgktddqxbwtrqsbqdxbwsqrwrtq/1/1303472/5961857/image7954013674829342211img-or.jpg
Mar 04, 2011 | Maytag Dryers
Due to power outage now the Neptune dryer model MDE6700AYW does not work and goes into an error code of t5 and there are keys that need to he pressed in sequence to get this corrected, please let me know...
My book say's you have to be in service mode first.
turn the dryer on, then press chime and temperature keys at the same time for 3 seconds. The diagnostic codes can be accessed by then pressing the wrinkle prevent key. a "d' wil be displayed. you can then turn the knob to see all of the codes that are listed. To clear the codes, press the sensor dry level and time keypads together for 3 seconds while veiwing the list. This cleared all of my codes. Good luck.
Jun 23, 2010 | Maytag Neptune MDE6700A Electric Dryer
Maytag neptune has error code e5
What does an e5 error code mean?
Feb 22, 2010 | Maytag Dryers
Maytag Neptune MDE6700A Electric Dryer Logo
682 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Marvin
Marvin
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
