Question about Microwave Ovens
Rainbow series e does not turn on - Microwave Ovens
  • genymg Aug 01, 2010
    Thanks for the valuable information, I did find the problem and this avoid me to buy an new one or spend more money sending it to repair.
    Thank for your help!!!!
  • 10,515 Answers
Is it a vacuum or Oven?
Thanks!!
Posted on Aug 01, 2010
  • 5 more comments
    vacuum cleaner
    Hi Taran
    Should I ask some one else or you can help me?
  • taran_2005
    taran_2005 Aug 01, 2010
    Thanks for your response!!
    Have you tried to reset the red button on the Power nozzle cover?
    Have you gone through all the basic troubleshooting. If not, you could download the user's manual from :-
    http://www.rainbowsystem.com/rainbowsyst...
    You need to have acrobat reader to view this.
    Note - Your unit have 4 years warranty on this.Do not try to repair it yourself as it would VOID the warranty.
    Good Luck!!
    Thanks!!
    Thanks, I will download the manual. The machine is more than four years old. I am trying to open it to find if motor has power, it may be could be a broken power cable inside.
    Thanks again
  • taran_2005
    That could be a case. Most of the times, it is either a cracked or broken wire.
    There are a couple of models under this series. Look at the schematic :-
    http://www.elkypro.com/hoops2005/vacuum_...
    There is a safety switch on all E series and E2 series Rainbow vacuums,
    that keep it from running without the water basin on it.
    One other thing. All E series vacuums have a built in circuit breaker on
    the motor. Some of the earlier ones, it was only a fuse, and if it
    blew, it had to be replaced, or removed and wired directly without it on
    there. Most of them have a automatic reseting curcuit breaker, that
    will blow and auto reset its self, after it cools off. They do sometimes
    stay blown also, and do not reset. If that is the case, it has to also
    be replaced, or removed, and wired directly, with out it on there.
    Motor
    brushes are usually the source of a non working E-2 vacuums and when
    they burn out, they usually take the motor armature with them, from
    excessive heat and flare electrical arking to the armature.
    Good Luck!!
    Thanks!!
    thank for you valuable input, I open below cover and found the safety switch, when I press it the vacuum turn on, then I check the water bessel on found the plastic stick that activate the switch broken, so i just need to buy a new water tank. Thank you to help to solve this problem.
    Eugenio
  • taran_2005
    I am happy that you found the fault, before you could buy a new one.
    If you have any other questions, revert and i would be glad to answer. Do accept the solution, if 100% satisfied from my response and close the thread.
    Good Luck!!
    Thanks!!
My Pro Series Frigidaire Microweave oven is not heating. The turntable is not turning but the light is working and the timer is counting down.
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Feb 10, 2011 | Frigidaire PLMB209DC Microwave Oven
Microwave doesn't heat or turntable doesn't turn
Check the door switches as they are in series with the magnetron power supply which is also the power feed for the turntable.
Jan 01, 2011 | Sharp R-310DK 1150 Watts Microwave Oven
The turntable on my hotpoint gold series won't go around, but you can still hear the motor
Check to see if the glass is fitting properly on the motor slots. Sometimes they can work loose - which will make it not turn. Good luck!
Dec 09, 2010 | Hotpoint Microwave Ovens
My Sylvania micro/convec oven was installed in my RV last year but has never worked correctly. It runs long after the beeping ends and the glass sometimes gets a rainbow haze across the glass. Is this...
With this oven being a combi ventilation and extraction is important, the haze across the plate is
surplus heat, It not cooking but what you hear is the extraction fan running until the oven cavity has cooled down
Feb 12, 2010 | Sharp R-353 Microwave Oven
Frigidaire Professional series microwave won't heat
The most likely problem is the magnetron. Check your warranty in owners manual, I believe you have five year warranty on magnetron.
Mar 15, 2009 | Frigidaire FMV156DC Microwave Oven
Frigidaire microwave gallery series turntable is not turning
This co. has one for $19.99
http://microwaveglasstrays.com/shop/microwave-turntable-motor-st16fe-ex73saaa3-p-214.html
I am also looking elsewhere
Mar 04, 2009 | Frigidaire FMT116E1B Microwave Oven
My microwave says "child" and won't play anymore
Not sure of the TT series models but for the NN series models the procedure is as follows:-
If "Child" is displayed in the display window, then the child safety lock is on.
To remove the child safey lock, press the "Stop/Reset" button 3 times in fairly short succession (less than 3 seconds). The time of day or just the Colon sign (:) is then displayed
If you later want to apply the Child safety lock, then, when the time of day (or colon sign) is displayed, press "Start" 3 times (again in short succession).
Hope this helps
Doug
Nov 08, 2008 | Panasonic NN-T990SA Microwave Oven
Is there a recall on Sharp Carousel Microwave R-530 LW series. I have one and it is so loud when I turn it on. It is like something is loose inside and rattling.
We had an R-240 or R-250. I can't tell you which because the other night while not in use it caught our kitchen on fire. It was just plugged in and not in use. The insurance guy said that this can happen. Maybe don't buy the R series from Sharp. Or keep it unplugged when not in use.
Jun 23, 2008 | Sharp Microwave Ovens
Microwave Ovens Logo
23 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Microwave Oven Expert? Answer questions, earn points and help others
