Question about Konica Minolta PagePro 1350W Laser Printer
Konica minolta 1350w
I've got white streaks running vertically down my prints...I don't know how to check the level of my toner, and I'm not sure that is the problem before I replace it.
Any tips?
  • 210 Answers
If you're getting white lines, you are running out of toner, but if the lines are black, I believe the drum is the problem .Remove the OPC drum and check its surface for lines, if there are any lines, you can bet it will be printed on the paper.
Chip reset device for Konica Minolta Bizhub and CF imaging units
http://www.chipreset.eu
Posted on Aug 23, 2009
  • Andy Smith Oct 01, 2012
    I have the same printer (KM PagePro 1350W) and white streaks. But my toner cartridge is new, so I guess that means cleaning. How do I clean it?
White streaks on every printout
Pull all imaging units out and clean the laser with the wand provided either in tray or on front door.
Sep 07, 2017 | Konica Minolta PagePro 1350W Laser Printer
I'm getting vertical streaks from my konica minolta 1350W laser printer. I've read it's the charge wire that needs cleaning, where is it located and how do I clean it? thanks
Hi
You can find this wire on the front side of the drum assy. You can check near the drum it is known as Corona wire which passes high voltage to erase the drum making it ready to receive the next image. You can clean if with a ear swab without any cleaning liquids. And also do remember that sometimes there is an Blue color tab on right or left side of the toner which moves hence you can clean with it as well. Its been given for the same purpose.
Regards
Jul 24, 2011 | Konica Minolta PagePro 1350W Laser Printer
Stop streaks on printed copies pagepro 1350w
streaks are caused by toner on paper path rollers, clean these and it should stop. Also dont overfill the casettes with toneer ( common with refurbished)
Please rate my help++++Thanks for using FIXYA
May 12, 2010 | Konica Minolta PagePro 1350W Laser Printer
Light toner streak on all sheets top to bottom
Toner streaks usually denotes a bad drum.
Sorry.
If you are satisfied with my answer, be sure to click on the "Thumbs-Up". If you have further questions, please feel free to ask them. Thanks for using our service!
May 11, 2010 | Konica Minolta PagePro 1350W Laser Printer
Pagepro 1350w prints with streaks on left side
Hello sir; Not thing you can use forever if lifetime is out you need to change otherwise the streak line not go away.
May 13, 2009 | Konica Minolta PagePro 1350W Laser Printer
Konica Minolta PagePro 1350W laser printer. Have
your carteidge OPC duram is faulty .
so change cartedige
Apr 25, 2009 | Konica Minolta PagePro 1350W Laser Printer
Konica Minolta PagePro 1350W Laser Printer won't print anymore
Go to printer faxes check and it might change the default setting and it might default Microsoft Office Document Image Writer. When you print make sure that you are printing to a right printer you can select the printer of your choice by clicking the down arrow. If you select the right printer and it did not print I suggest that uninstall the print driver to the control panel, add or remove and install a new printer driver. make sure set as a default.
Jan 27, 2009 | Konica Minolta PagePro 1350W Laser Printer
Refill toner konic minolta 1350w
hello
i just installed a new cartridge , but i still have vertical streaks on my sheets
do i need to get the toner clean , and what product do i use ?
thanks again for you time / help
Mar 19, 2008 | Konica Minolta PagePro 1350W Laser Printer
Konica pagepro 1350W
There is no cleaning sequence for the 1350w. I usually just pull the toner unit out and clean the roller, etc. Compressed air for the moving parts and hard to reach places. Best to do it outside.
Sep 05, 2007 | Konica Minolta PagePro 1350W Laser Printer
HELP WITH INK LINES DOWN THE SIDE OF PRINTOUTS
If the line is solid from top to bottom of the page, the problem can be in different parts of the printer. Try a different toner cartridge if you have an extra one.
Jul 25, 2007 | Konica Minolta PagePro 1350W Laser Printer
Konica Minolta PagePro 1350W Laser Printer Logo
433 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
