Question about Linksys WRT160N Wireless Router
I can't find the WEP for my linksys WRT160N - Linksys WRT160N Wireless Router
    Brigadier General:
  • 10,406 Answers
Start Internet Explorer.
Login to the web-server "inside" the router.
Run the "Wireless Network Setup Wizard",
to enable 'WPA' and to set a password/passphrase.
Posted on Aug 01, 2010
Testimonial: "Thank you!!!!"
Using a Linksys WRT160N how do I connect two different devices with different security settings? One using WEP and the other using WPA2?
You can't connect two different devices on WEP and WPA2. It's one or the other. I suggest using WPA2 because it is uncrackable thus far. WEP can be cracked in under a minute.
Feb 28, 2011 | Linksys WRT160N Wireless Router
How do I secure my network
etting up wireless security is the easiest way to prevent other people from using your wireless internet connection. Your Linksys router supports three (3) of the most commonly-used wireless security types WEP, WPA and WPA2.
This article will explain the difference between WEP, WPA, WPA2 and how to set up each of them.
Nov 06, 2010 | Linksys WRT160N Wireless Router
Pass pharse
Log on to the router, go to wireless security.
I would choose WPA ( you choose the password)
WEP is much weaker, try not to use WEP ( It gives you a pass phrase/key)
Jul 22, 2010 | Linksys WRT160N Wireless Router
Cannot get wirelss connection through my WRT160N wireless router. Was working and now not. I can get internet connection through the LAN ports so I know that the router is working with a fixed cable
by default ip address of linksys is 192.168.1.1
to star config you need to be connected with ethernet cord rj-45
or conenct via wireless by conencting to linksys on wireless
admin user: blank
admin pws: admin
*choose a protocol on your linksys router on internect conenction type:
check isp protocol :
dhcp: needs serail number of mac address
it picks up automatic
pppoe: needs username and pws from isp
*the ip address has to be diferent from the isp modem:
isp modem 192.168.1.1 linksys 192.168.1.1 incorrect
isp modem 192.168.1.1 linksys 192.168.2.1 correct
change the ip on lan settings on your router
*wireless: ssid by default is linksys
ssid: linksys
wep : none
to setup wireless
access the wireless basic
change the ssid to any network name
enable the wireless password
choose wireless security
enable wep key 10 digit hex pws
make shure you saved settings on every setting
May 04, 2010 | Linksys WRT160N Wireless Router
My Linksys will not connect to my WII
Well the first thing is that you have WRT160N router. This router has issues with the firmware. So first you will need to upgrade the firmware of the router. Download the firmware of the router from the manufacturer's web site. Connect your computer to the router. Open the router page. Click on Administration tab. Just below administration you will find firmware upgrade subtab. If you click on it, you will find the browse option. Browse the file that you have downloaded from the web site. and Click upgrade.
For WII, you will also need to change the MTU to 1365 and open some port numbers on the router.
Apr 17, 2010 | Linksys WRT160N Wireless Router
Hi my nintendo ds needs a wep code to go on wifi but i cant find it on this wrt160n router.
You need to input the wireless password you set to your router during setup
Dec 29, 2009 | Linksys WRT160N Wireless Router
I am new at this
There is nothing to Delete. Simply unplug the old and plug in the new. A WEP key is a way to ensure a small amount of encryption in the Wireless network. If the new Router has WPA - you should use that instead of WEP as the WIRELESS Encryption. There should be a "quick start guide" to help you install the new Router.
Mar 29, 2009 | Linksys WRT160N Wireless Router
Wep password
If you forgot the WEP of your wireless network, but you think you left the admin password the default, then you can access the router's configuration utility by opening a web browser to http://192.168.0.1 (or 192.168.1.1, depending on your network) and entering the default admin password. You can then go to the wireless security area and enter a new WEP and this time, write it down! :-)
Hope this helps!
What is a wep key
It is the security code for your router. Most are on the bottom of the router, sometimes there will be two WEP & WPA.
This is unless you have changed it to a different one, if so this is the code you need to enter.
Jan 10, 2009 | Linksys WRT160N Wireless Router
Linksys WRT160N Wireless Router  Logo
151 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
