Question about Frigidaire 24 in. FDB1050RE Built-in Dishwasher
Dishes smell when they come out of the dishwasher
I use Cascade Complete and Jet Dry in my dishwasher. The dishwasher is 2 years old. We've cleaned the trap and scrubbed the elements in the bottom. I've tried adding bleach to the load and also vinegar (separately). Nothing seems to work. The dishes still come out smelling like pond water. What can do?
    President:
  • 949 Answers
There is a new product out that works well for this problem.
It is called Affresh D, You can find it at most stores near the dishwashing detergents. It comes in a yellow bag.
Posted on Aug 01, 2010
Testimonial: "Thanks, Phil! I'm going to try that right away!"
I have Whirlpool WDT720PADM I bought this year 2017 (2 months old). Dishes are coming out clean but slimy when touched.
sorry but FIXYA has no fix for this . check with the manufacturer's website and tech support
Nov 30, 2017 | Whirlpool Dishwashers
There is a film like residue on dishes after complete cycle has ran. I use cascade tablets and also have refilled the jet dry. It is on all dishes but the glasses and clear plastic show it the most.
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Dec 05, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
I've had my dishwasher (GU2455XTSB3) for almost 2 years. The first year and half were great. I always use the same cycle (with options) and it took approximately 1.5 hours to complete. Now it takes over 3...
heatman101
Oct 23, 2010 | Whirlpool GU2455XTS Built-in Dishwasher
My dishes are coming out with a white chalkyness on them. I use Cascade Complete and Jet Dry. We do have hard water but also have a Water Softener. Could I have a filter problem with my dishwasher.
Check your heating element..
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehow simple it was. thanks Ronnie " - ronnieshomes
Sep 16, 2010 | GE Dishwashers
I have just moved into a home with a 1 year old Whirlpool Gold GU2400XTP Quiet Partner III. THE DISHES ARE NOT CLEAN, GLASSES HAVE WHITE SPOTS, SILVERWARE AND PLASTICWARE HAVE WHITE FILM. I am using...
A bad heating element causes many problems in dishwashers…
heatman101
Asker's Testimonial " explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Sep 08, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
Film on glasses and dishes.using cascade complete and jet dry.Dishwasher is a kenmore elite.
make sure when you fill the jet dry that you make sure it is completely filled. you must add jet dry,close door,lower and raise the door 3 times and then check normally you could add more jet dry because the air is now pushed out by this process. and finally b4 you turn on your machine make sure tolet your faucet run until it hot and then start machine. that should handle the problem. let me know if this helps by sending me a 4 thumbs up post . thanks
Feb 28, 2010 | Dishwashers
New dishwasher leaving powder residue on dishes.
Quit using the new Cascade. The formula change is what is causing the problem. No research from Cascade before releasing the product
Nov 18, 2008 | Dishwashers
Dishwasher leaves soap in dispenser.
Hi Dirty Dish gang.
After having 2 appliance repairmen here, I now have the latest scoop on our dishwasher problems, $200 later!
Los Angeles IS currently having hard water issues. Also, all the new cleaning gels etc. are actually a cause of our dishwasher problems.
So, here is what we need to do:
1. Use Cascade POWDER detergent only.  Make sure is is just "plain" no "scented" or "complete"  or gel, etc. (I have tried a phosphate free powder and gel and this is a cause of our problem as well!) 2. Use Jet Dry in the dispenser (set it to a 2-3 opening) 3. Make sure water is at least 120 degrees 4. Only run dishwasher on "normal" setting.  All others just run it longer, hence causing more water stains. 5. Do not pre-wash dishes! You can knock of chunks with a "non" soapy brush, but don't rinse (the oils actually help to clean the dishes) 6.  Do not wash sponges in dishwasher.
Acid Wash: The repairman just gave my washer an Acid Wash today. It says it is an acid derived from lemon, I got mine from Carters appliance in Torrance, CA for about $19. I am to run a normal cycle with the above mentioned Cascade after this "acid cycle" is finished.
If you are still having problems:
Monthly maintenance: Glass Magic: Buy a box of Glass Magic (near the Cascade)  Use 1 Tbsb in main detergent compartment of dishwasher along with the Cascade, till washer starts working again. White Vinegar: You can run an empty dishwasher with white vinegar once a month.  Fill a bowl with 2 cups vinegar and place on bottom rack.  Then run as a normal cycle...this allows vinegar to disperse slowly.
So far it seems to be working.  Good luck.
Nov 07, 2008 | Kenmore 24 in. 16032 Built-in Dishwasher
Maytag dishwasher DWU7560AAM
Check your water spray bars. I'll bet they are plugged with calcium or something.
Oct 13, 2007 | Maytag 24 in. MDB3700 Built-in Dishwasher
Frigidaire 24 in. FDB1050RE Built-in Dishwasher Logo
337 people viewed this question
Top Frigidaire Dishwashers Experts
Carmen Mikulic
Mike
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
