Question about GE WSXH208A Front Load Washer
Door on ge front loader washer leaks, door gasket is fine. Could it be the lock not working properly
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 289 Answers
Yes it could be the door lock not pulling the door in enough to make the seal. Solution... Remove covers and with door pressed in hard, ( You may need help ), adjust the lock mechanism to make seal. Put lock-tite on the threads after it works for you. This will prevent the shaking of the washer from losening of the nuts again.
Posted on Aug 02, 2010
GE front loader leaking new door hinge on left side... It is not down spout but that the gasket didn't contact door on that side allowing leak door will push .5 -1 inch on hinge side. M#Wbvh6240fww
Recheck the door hinge install. Sound like the hinge is not installed properly leaving a gap on the hinge side. There are sometimes notches or hooks on the hinges that need to be in holes or cutouts on the washer body for proper fit. if the hinge is not in the holes right it will stick out from the body and leak.
May 16, 2015 | GE Washing Machines
LG front loading washing machine. SEVERE water leak from front door. Gasket has been checked and is OK. Seems there is quite a bit of 'play' (i.e. slack or free movement) in the front door since if you...
This is a very common problem with the LG front loaders, and some other front loaders for that manner. There was a few recalls on them and some parts that were supposed to fix the issue. Even if the gasket looks ok i would replace it, as they have updated the design of the gaskets to fix issues on models that were having issues leaking. Most of the time its just a bad gasket and you cant really do anything other then replace it. Front load washers are about the worst appliance made today in my opinion, the repair shops around here are always full of broken and leaking front loaders. I have fixed quite a few myself, some work ok after the repair, some fail again in a matter of months, its a real duck shoot on them. The biggest failure rate though is the gaskets! And most of the time they look ok but still leak like a screen door.
May 04, 2017 | LG WM-2077H Front Load Washer
Front door leaks
The door gasket is bad this page will help http://www.appliance-repair-it.com/GE-front-loader-washer.html
I know the page says GE front loader but replacing the door gasket is the same.
Oct 05, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Door gasket leaking
My GE washer model wcvh6400j0ww was leaking too. The repair person thought the same thing the gasket. It turned out to be the water in-let pipe (WH41X10118 and you will need seal WH41X10119) and not the gasket. He ordered the gasket and took machine apart to replace and found cracked pipe. Take your machines front off and make sure it is the gasket leaking. Good Luck,
Jul 20, 2010 | GE WBVH6240F Front Load Washer
GE Profile front loader washing machine is leaking front of door, believe the problem is the rubber washer ring, however can this be replaced?
Hello, this is usually the door seal, most machine incorporate a one piece combined door seal and outer drum seal(often just called a DOOR GASKET), the door seal are put in on the front panel first in the factory, then the drum assembly is put in and the seal pushed over the outer drum. This means a lot of stripping down has to be done just to replace the drum to the door seal.
Thanks
Jun 14, 2010 | GE WSXH208A Front Load Washer
Door wont lock on front loader
It is possible that you have a bad door lock assembly, I would check the wiring harness connector to door lock for proper fit
Nov 05, 2009 | GE Energy Star WCVH6260F Front Load Washer
Front loader washer leaks from bottom center of door osmetimes
Check inside the door on the bellows gasket to make sure the inlet area (normally at the 10 o'clock position) is properly positioned around the water inlet, sometimes these work themselves off the inlet nozzle and can casue a leak when the washer is filling up.
Also, carefully run your hand around the bellows gasket to see if you can find any small holes that cold be letting water leak out. You'll need a flashlight to make this easier. It is hardly ever the hinges that causes a leak since the hinges are mounted outside of the door seal gasket (bellows gasket) and aren't ever exposed to the water.
Jul 27, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Replace rubber gasket
Replace the machine with a top loader and you'll never have a leaking gasket again! Worked at National Linen for a while and the floors had drains in them and were always wet! Needless to say the pros have the same problem you do! ;)
Apr 22, 2009 | GE WBVH6240F Front Load Washer
GE WSXH208A Front Load Washer Logo
164 people viewed this question
Top GE Washing Machines Experts
Tim Whalen
Marvin
Marvin
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
