Question about Tascam DP01 All-In-One Recording Package Microphone
Tacsam DP02 All Recording lights and mute lights are on can't turn them off.   Also my vocal tracks vanished!
  • 243 Answers
This generally means there is a short.
Posted on Aug 22, 2008
Why is my 2nd recording track picking up the first recording track. I want to record another instrument, but the new track picks up the other tracks.
I don't know if this will help, but the Magix software I use create their own set of files. You can see these in the folders it will create for your project. I would specify another folder - create one - for each project or recording, that might solve the problem.
Jan 07, 2015 | Magix Music Maker 2014
I have a Tascam DP-02 8-track all-in-one digital recorder. I've successfully armed and recorded Ch's 1 and 2 to input A and saved the session. When I loaded the session the next day to resume the project,...
i had a look for u on the net only the small yellow ones light up but ill get back to you about the other question as soon as i find a ansew wont be long thanks from chris
Sep 14, 2008 | Tascam DP01 All-In-One Recording Package...
I am trying to record in multi track mode-want to know how to record for example vocals on track one then without erasing the vocals add for example harmony or guitar so i get two things on one track. At...
How multitrack recording works is assigning each recording to a different track. A way around this is to record the vocals to track one, then your harmony to track two. Save that as a single recording, or mixdown, then open that saved mixdown to track one. You may need to be connected to a computer to do this.
I use the same technique when using Cool Edit Pro (outdated, yes, but I've been using it for 4 years, and I know most of the ins and outs), especially on the guitar tracks, where for studio sound, you've gotta use 4 total tracks. Putting two tracks together frees up your processor, and uses less in the way of effects, as well.
Hope that helps!
Feb 07, 2011 | Samson Technology Zoom H4n Handy Recorder
My DP-02CF comes up with no free disk space even though i've bounced everything together and ive still got 6 tracks left. how can i stop this from happening
This is just a suggestion - back up the track to a PC using the USB port and reload and reburn on a new disc. Sounds like you may have a bad file and or disc. And by the way you worded this, has this happened before? Make sure the activity light is out and your tracks have been recorded fully before turning the unit off or you will get "end of file" errors.
Nov 01, 2009 | Tascam 2488 Portastudio Multitrack...
Recording vocals while the music tack is playing simultaniously
it's not supported on that or any earlier sony software that I know of. have you tried running the program twice (simultaniously) and playing on one while recording on the other then mixing the tracks together after??
Apr 26, 2009 | Sony Sound Forge Audio Studio 9
Dp02 recording music(from stero)
Sounds like you are using the DP-02's 'stereo mix' inputs here. If so, the signal input from those is only routed to the line out and headphone jacks and cannot be recorded using the DP-02.
To record from a stereo you need to take the left and right aux outs (or some other line out - like the tape outs) from the stereo and put them into the main A and B mic/line inputs on far right of the DP-02's back panel. Then assign them to two respective tracks and you can record the stereo output to the DP-02. Just make sure you use a line level output from the stereo as the amplified speaker output can overpower and damage the inputs on the DP-02. You might need a couple of rca to 1/4 inch adapters to accomplish this.
Hope this helps.
Jan 14, 2009 | Tascam DP01 All-In-One Recording Package...
Tascam DP-02cf
You've got two inputs on the DP-02 so you can record two sources at once.
Depending on how you want the electric guitar recorded (mic the amp, or direct line in) you can in the first case plug your guitar mic into one of the mic inputs on DP02 and plug your vocal mic into the other mic input. You also have the option of plugging the guitar directly into the DP02 (using the hi-z input - I believe it is labelled 'guitar' or something on the DP02. I any event I believe it's the one on the left). This way you only need one mic for use recording the vocal part.
To avoid any 'bleed' between channels you can use the headphones while recording this way and you'll avoid having the unamplified guitar sound coming through over the vocal mic.
Once you have the mics or guitar and mic plugged into two inputs, you need to assign the inputs to a channel (track) to record on. You do this by pressing the select button for the input and then pressing the select button for the track where you want to record the input. Do this for both inputs so that they are recording on different tracks. Then arm the tracks for recording by pressing the record button for each track and the lighted buttons will flash above each armed track. Then just press play and record and you'll be recording. You can go back and redo it as many times as you like and record over what is there, or preserve a take and assign a new track (or tracks) for another take. You've got 8 to play with.
Hope this helps.
Sep 01, 2008 | Tascam 2488 Portastudio Multitrack...
Vocal effects on Tascam 2488 MK 2 portable studio
Hi again,
The easiest way to record using an external Lexicon effects unit (without an external mixer) is to connect your mic onto one of the 2488's inputs and assign that input to a channel strip (track). You should have the 2488 sends (output) going to the Lexicon's inputs. Then connect the Lexicon outputs back into another set of inputs on your 2488 and assign those inputs to two empty channel strips (tracks).
Then you will have to take that channel that has your mic input assigned to it and press send and set the levels there to send the signal out the sends (to the Lexicon).
Now you have a channel strip assigned to the mic input which contains your dry signal, and you have the two inputs returning from the Lexicon which contains your wet or effected signal.
You then have some options. You can control the amount of effected signal you hear while recording by adjusting the faders of the two wet tracks and you can either record the dry signal or the wet signal (or both) onto separate tracks.
Typically when recording the singer will want to hear an effect (say reverb) on his voice, but the engineer wants to record only the dry track at recording time (because effects can always be added later, but they can't be taken out). To accomplish this you would use the setup above, but only arm the mic input track for recording. In this way the singer hears the reverb, but only the dry vocals get recorded and the engineer can add reverb to that track again later as desired (and mix it back with the dry vocal etc).
On the other hand if you want to record only the effected signal you would simply arm the two channels to which the inputs coming back from your Lexicon are assigned for recording. This will get you a recording of the effected signal only.
Hope this helps you do what you are trying to do.
Aug 30, 2008 | Tascam 2488 Portastudio Multitrack...
Headphone monitoring DP02
It was a bad phone jack adapter ... found another one, and it works fine. The DP02 ROCKS! I wish it had build in compression though - I am finding my vocals get too loud and too quiet at times. Maybe it does, I have to keep reading. So far, it does everything except the dishes :)
I started recording back in the 80s, and spent over $30K back then to get equipment that honestly doesn't do as much as this little machine. (I wasn't rich, I went bankrupt).
Jun 07, 2008 | Audio Players & Recorders
Tascam Us144 and Sonar3 problem!!!!
Try this experiment:  Record a click track on track #1.  Record track #2 of the output of a monitor speaker playing track #1.
Now you have two click tracks which will probably not be cooincident (like they should be).
Measure the offset of the two tracks!  You now know your latency exactly, and can compensate by adjusting settings or moving the vocal track back manually that many milliseconds!
Apr 06, 2008 | Tascam US-144 Sound Card
Tascam DP01 All-In-One Recording Package Microphone Logo
80 people viewed this question
Top Tascam Audio Players & Recorders Experts
Sam Palermo
Sam Palermo
Michial Gueffroy
Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
