Question about Sharper Image Hybrid GP (SI724) Air Purifier
My unit keeps turning off, attention required red ligth is blinking, I just clean te unit
    Problem Solver:
  • 6 Answers
Make sure not to forget cleaning the corona wires. i used light grade sandpaper and gently cleaned the wires as well as scrubbed the metal grids with scotch brite pads. the unit has been running normally .
Posted on Aug 03, 2010
Why does a red light on top of the ionic breeze GP S1750 blinks and does not blow the air
well i had the same problem at one time ..heres what to do... try turning it upside down and bang on the unit gently .not to break it and make sure you did not break the two strings behind the vents..
take out the bulb and clean the whole inside as best as you can..
and if that wont work unplug turn button to on pisitioin and then plug the unit inand hope for the best ... if all else fails go to amazon and replace the unit..hope that helps
Jun 11, 2014 | Sharper Image Ionic Breeze GP SI730 Air...
Model s1871sharper image room purifiler. keeps blinking that it is not clean when i just cleaned it
Just check to make sure none of the wires at the front of the unit broken and shorted to an adjacent plate.
Wash the electrode unit with an acidic cleaner like Formula 409, and let it dry, and dust out the cabinet with clean compressed air if you have a source. While this will not alleviate all the red indicator indicators, it will address most of them. The others, you may just decide to live with because the air filer is still filtering/ionizing even if it does indicate it needs cleaning..
Sep 28, 2012 | Air Purifiers
Ionic Breeze Midi Prof. Plus has red light on and won't work
When you cleaned everything did you also turn the whole unit upside down and gently shake to remove trapped dirt in the bottom of the unit. As for taking this unit apart to clean throughly there is no need. Just use some q-tips with 91% Isopropal alcohol not Rubbing alcohol to get to the small areas. Pay close attention to the small arrow shaped metal contact near the bottom of the unit. Make sure it is wiped clean and everything is completely dry. Plug unit back into power and the red button should turn green.
Mar 22, 2010 | Sharper Image Professional Plus Ionic...
"Cleaning overdue" red blinking light after cleaning was done
Check that there are no fine pieces of lint that are bridging the plates or the ionizing wires, to ground.
Check the contact points of the collector cell and inside the unit.
The light is caused by a shorted collector cell and associated components.
Dec 21, 2009 | Sharper Image Ionic Breeze GP SI730 Air...
Sharper Image Hybrid GP. Unit powers on, goes to
The solution drgoff provided ( the guy that used to work for Sharper Image ) actually did the trick !!!! Super excited to have this unit working again , thanks drgoff
Jul 07, 2009 | Sharper Image Hybrid GP (SI724) Air...
I purchased a Hybrid GP germicidal Air Purifier, Model # S1724 ((Electric Air Cleaner AC110v 20w 50/60Hz)). My unit is severly malfunctioning and i nee to either send it in for repair or be given detailed...
Locate the photo electric eye that picks up the need to clean and give it a thorought cleaning. Good Luck and I hope you get it repaired. That photo cell should be your problem It's probably a little black or ruby red dot in a fin or on the housing where yhe air passes.
Jul 06, 2009 | Sharper Image Hybrid GP (SI724) Air...
Red Light
slow blinking light means the unit is in DRY MODE.. flast blinking light means some sort of arcing or bad power supply..
if in dry mode let the unit run for an hour and it will stop blinking ..
Jun 28, 2009 | Oreck XL Professional Air Purifier
Red light keeps blinking
I take mine apart when red light comes on and the filters and inside good. It goes off when the unit is screwed back in and turned back on
Nov 15, 2008 | Oreck XL Professional Air Purifier
Red Cleaning Light won't turn off
After cleaning the unit, replace the grid into the unit. Hold upside down for at least 30 seconds to reset.
Jul 19, 2008 | Sharper Image Ionic Breeze GP SI730 Air...
Take it back. Hopefully it is inder warranty. I have had 2 units do the same.
Nov 29, 2007 | Sharper Image Ionic Breeze 3.0 Air...
Sharper Image Hybrid GP  (SI724) Air Purifier Logo
426 people viewed this question
Top Sharper Image Air Purifiers Experts
Daniel Dollive
Daniel Dollive
Mike Squire
Are you a Sharper Image Air Purifier Expert? Answer questions, earn points and help others
