Question about Coffee Makers & Espresso Machines
Miele CVA4070 won't grind. I have a brand new CVA4070 and whe I tell it to brew it does everythig except grind beans and run the water through them . I do have a great new supply of hot wasther, thought. Thanks for any assistance you can give.
    President:
  • 2,030 Answers
The controller inside needs replaced. I recommend taking it back to place of purchase for ecxchange, as it is under full warranty at this time.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
Posted on Aug 01, 2010
  • lidwis Aug 01, 2010
    No other possible answer?
  • Sean Wright
    Sean Wright Aug 01, 2010
    Sorry there isnt.
The machine was not dispensing any coffee at all! I cleaned the nozzle with a fine wire and now it is making espresso, but not coffee????
I suspect your type of coffee beans is too oily. Try another type of coffee. Otherwise the grind settings is probably too fine. Change it two steps at the time.
If all this doesn't work, you are due for a full cleaning machine at the Miele service centre. Or you have a leak inside (tubes or the brew unit drive). Many causes are possible according to the description you posted.
Oct 08, 2014 | Miele CVA4070 Coffee Maker
Miele cva4070 coffee maker showing fault76
Fault 76 is caused by there being too much coffee to compress . Assuming there is not a fault with brew unit or brew unit drive, then try to use less coffee (see menu settings) or grind the coffee to a finer level (see manual). regards
Jun 16, 2014 | Miele CVA4070 Coffee Maker
The grinder is not working
Likely causes are grinder has burnt out or temperature cut-out for Grinder has blown. Either can be replaced as a spare from Miele.
May 13, 2014 | Miele CVA4070 Coffee Maker
The grinder is not working. Only water is coming out.
Basically coffee is not being ground. Likely causes are grinder is faulty or temperature cut-out for Grinder has blown. Either can be replaced as a spare from Miele. Note: A possible cause for Grinder not working is that the carbon brushes are worn away preventing electrical contact. Unfortunately Miele does not sell brushes as a spare part.
Fault F 17 appears when in use. Starts grinding the beans but no coffee in the cup yet. What does F17 mean?
f 17 is no water flow. It usually occurs when the brew unit has not been cleaned regularly, when the coffee grind size is set too fine, or when oily beans are used. You can try to soak the brew unit in hot water for a while, and run water through it in the sink. Unfortunately, most cases require brew unit replacement. A properly cleaned and maintained brew unit should last the life of the machine.
Jan 26, 2011 | Miele CVA4070 Coffee Maker
Hi. I have a miele cva4060. The grinder is working but it does not seem to be getting any beans through it and I am only getting water dispensed instead of a coffee shot! It was working fine a few days...
Hi
If you hear its 'grinding' then that's good - problem is where is the ground coffee going or supposed to go??
Check there is no build up of damp/dried coffee grinds in the pathway between grinder and brew unit - this can happen if the machine is not properly cleaned say every 3 mths or more often depending on usage - coffee 'dust' can build up.
Also suggest remove all beans from grinder, vacumn last ones out. clean all around grinder opening. Add a dozen or so beans to the grinder, turn on and try again. If the beans disappear, its grinding properly. If they don't end up in the brew unit, then the hold up is as I said in that pathway - grinder to brew unit. If you cant see an obvious blockage/build up, suggest you have a tech look at it.
Cheers
Mike
Dec 10, 2017 | Miele Coffee System
My meile does not make good coffe
Remove the Brew Unit from the maschine and clean it very well und running water. Thn go into the Main menu and switch back all settings to factory defaults. Then take a vaccum cleaner and put the pipe in the small hole where the coffe falls into the brew unit (knock a bit on the maschin inside). Put out the bean container and do the same with the hole where the beans go into the grinder. Then put everything back in and start a cleaning process for the brew unit (do it 2 times).
After that your Problems must be gone. The Problem is between the grinder and the brew unit. the grinded coffee has bee stuck and is not falling into the brew unit .... that happens when you use beans with lots of oil inside  .... or coated beans .... they "glue" the chute .....
Mr. cool
Jan 01, 2009 | Miele CVA4070 Coffee Maker
Water in the waste unit, coffee comes not strong enough, as use to, although the settings are for strongest possible and the coffee grinder is set to medium. My unit is 4075 but I think it is just the...
Your chute between the grinder and the brew unit is "glued" with coffee. Take out the the brew unit, clean it under water. Take a vaccum cleaner and put the pipe into the hole where the coffee falls into the brew unit. Move the bean container "hard" in and out ( knocking inside the maschin to loose the blockage). Switch in the main menue all to factory defaults. Put the grinder "level" into the middle again. start a brew unit cleaning process. After that you coffee must be ok again. Do not use oily beans or coated beans. the block the chute.
Mr. Cool
Sep 30, 2008 | Miele CVA4070 Coffee Maker
Coffee Makers & Espresso Machines Logo
37 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Marvin
Marvin
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
