Question about SVP DC-12DX Digital Camera
How do I turn the flash on?
I lost the manual.How do I cut the flash on
Click the right arrow button: once for auto detection of light, twice for always flash and three times takes you back to no flash.
Posted on Jan 07, 2011
Lost my remote on my 02 jeep liberty and need to
the key fob? or radio remove or what?
remote to what.
the operators manual covers this , under car keys.
the car came with 2 Fobs. lost them both now>?
RKE its called, (makes looking fact more easy)
is this car with SKIS Immoblizer option> yes./no
if yes.
SENTRY KEY IMMOBILIZER SYSTEM - IF
EQUIPPED
im reading your operators guide now.
lost that too>?
Duplication of keys may
be performed at an authorized dealer (or locksmiths) or by using the
Customer Key Programming procedure.
DIY, takes 1 key , good, called a valid key, in the below text.
You can program new keys to the system if you have two
valid keys by doing the following:
1. Cut the additional Sentry Key Transponder blank(s) to
match the ignition switch lock cylinder key code.
2. Insert the first valid key into the ignition switch and
turn the ignition switch ON for at least 3 seconds but no
longer than 15 seconds. Turn the ignition switch OFF and
remove the first key.
3. Insert the second valid key and turn the ignition
switch ON within 15 seconds. After ten seconds, a chime
will sound and the SKIS indicator light will begin to
flash. Turn the ignition switch OFF and remove the
second key.
4. Insert a blank Sentry Key into the ignition switch and
turn the ignition switch ON within 60 seconds. After 10
seconds, a single chime will sound. The SKIS indicator
light will stop flashing, turn on for 3 seconds; then turn
off.
The new Sentry Key has been programmed. Repeat this
process to program up to a total of 8 keys.
did i guess right, the Key FOB RKE,
remove key entry fob.?
Sep 18, 2014 | 2002 Jeep Liberty
Luxor LED550FHD Wont start
I'm afraid if the power was lost during the update, the TV has a real software problem. But you don't have the tools to put in a complete set of new firmware. When the TV is still working, the processor and the program can manage the upload to the memory and after a restart everything should work fine. But no perfect firmware in the TV now that can do the upload rot the flash memory. A technician has to connect the TV to a computer and flash the firmware manually.
The best thing is to contact a certified service centre from luxor and ask them.
Sep 06, 2014 | Luxor Televison & Video
Samsung un60es6100 won't turn on just red flashing led
That is probably an overload indication. The lamp may need replacing or the optical engine may be malfunctioning. Either way it needs careful examination. Read through the owners manual on lamp replacement procedures, etc. and check the troubleshooting section in the manual. If you have lost the manual you can download it from online search. Also, count the number of flashes when set turned on that is a trouble code for the set.
Aug 15, 2014 | Televison & Video
Don't know how to turn flash off my Coolpix iso 1600
press the flash symbol to open the flash menu, now using same selection ring of buttons navigate to the setting you require, press "OK" to confirm.
you can download a replacement manual file here (PDF), you can save it to your computer/laptop.
Dec 17, 2013 | Nikon COOLPIX S200 Digital Camera
Service manual repair
If you are having issues with the flash not firing due to the 'thermal indicator' coming on, simply turn the thermal indicator off in the settings panel and all should be sweet.
Oct 02, 2013 | Nikon SB700 Flash
My Samsung S630 Digital Camera doesn't flash after a series of picture taking. Now it fails to flash although I set in Manual mode and selected Flash manuall, but still t doesn't flash. What should I do?...
Hi there remove the memory card and reset the camera. Now turn on the camera with out the memory card and make the camera flash light ON mode and take a snap. If the flash not working after this setting, then you need to replace the flash tube. The flash tube is cut off and thats why its not working.
Feb 19, 2011 | Samsung Digimax S630 Digital Camera
How do I turn off the flash for a coolpix 885?
There is a dedicated button (with the symbol of a lightning) for the flash. To turn off flash, press the button (maybe repeatedly) till the flash indicator on screen shows 'lightning with a circle around it'. To set it back, press the same button till the display shows Lightning and A.
Search on the Internet, you will definitely find a soft copy of the User Manual of your camera.
Jun 22, 2009 | Nikon Coolpix 885 Digital Camera
Cant turn on flash
It's the left button <, pressing it turns flash on and off. If the battteries are low it won't turn on. Here's a link to the online manual for your camera.
http://www.goaiptek.com/manuals/manual-pkdv4.pdf
May 03, 2009 | Aiptek PocketCam DV4500 Digital Camera
232 Plantronics bluetooth manual
flashing purple after you hold it for 3 seconds is discovery mode. blue flashing is active on. hold for 6 seconds to turn off. hold for 2 seconds to turn on.
Jan 11, 2009 | Plantronics Explorer 220 Bluetooth Headset...
Ge 94948 universal remote instrutios for progaming t.v.
Hiya this is how i got mine to work.Manually turn on the tv.
Press and hold setup on your remote till the light comes on and stays on.
Then press the tv button then release. The light will flash then continue to stay on.
Now press and release the power button waiting 2 seconds before you press it again until your tv switches off.. you may have to press it for awhile.
Once your tv cuts off press the mute button and now your remote is set for your tv.
Feb 19, 2008 | GE RM24948 Remote Control
SVP DC-12DX Digital Camera Logo
Top SVP Cameras Experts
Steve Sweetleaf
Steve Sweetleaf
Jaime Hernandez
Kazim ERGUNEY
Kazim ERGUNEY
Are you a SVP Camera Expert? Answer questions, earn points and help others
