Question about Linksys Wireless-G Broadband Router
WHERE DO I FIND A WPA SECURITY PASSPHRASE FOR MY LINKSYS
    Brigadier General:
  • 10,406 Answers
Use an Ethernet cable to connect the network-port on your computer to one of the LAN ports on the router.
Start Internet Explorer.
Access: http://192.168.0.1 or
Access: http://192.168.1.1 or
Access: http://192.168.2.1
to access the web-server software "inside" the router.
Login, and run the "Wireless Network Setup Wizard",
to choose WPA, and to set a password or a passphrase.
Posted on Aug 01, 2010
  • 550 Answers
Are you looking for the wireless network key or password ?
Is there any computer online using the router.
If not then you will need to connect the computer to the router.
If yes then you can open the router set up page on that computer.
router set up page is the page where you can check all the router settings.
You will find the wireless network key or password on the set up page of the router.
Click Here for step by step instructions
Posted on Aug 07, 2010
Want a secure line
kb19073-001_en.png NOTE: Image may vary depending on the type of router and computer you are using.
To setup your router's wireless security settings:
i. Accessing the web-based setup page
ii. Setting-Up the Wireless Security
Step 1:
Access the router's web-based setup page by opening a web browser. On the Address bar, enter your router's local IP address then press [Enter].
NOTE: The default IP Address of Linksys routers is "192.168.1.1". For instructions on accessing the web-based setup page using a Mac computer, click here.
Step 2:
When the login prompt appears, enter your router's Username and Password.
NOTE: The default password is "admin" and the Username field is left blank. If you have set a password before but forgot it, you need to reset the device. For instructions on how to reset a Linksys router, click here.
Step 3:
On the Setup page, click the Wireless > Wireless Security.
NOTE: If some of the tabs are missing in the web-based setup page, upgrade the firmware of your router. For instructions, click here. You can also set the wireless security of your Linksys E-Series routers with Cisco Connect. To learn how, click here.
On the Wireless Security sub-tab, there are various wireless security options that you can choose from.
However, as mentioned earlier, the three most commonly used security modes are WEP, WPA Personal (or WPA Pre-Shared Key), and WPA2 Personal. The instructions below will show you how to set up the following security modes. On the other hand, the WPA2/WPA Enterprise Mixed Mode, WPA Enterprise, WPA2 Enterprise, and RADIUS security modes will only work if the router is connected to a RADIUS server.
Wired Equivalent Privacy (WEP)
WEP can be a 64-bit key with 10 hexadecimal digits or a 128-bit key with 26 hexadecimal digits. This encryption will prevent other users from connecting to your wireless network. It will also protect your wireless transmissions from being accessed by other users.
NOTE: In case the screen on your router's web-based setup page looks different, click here.
Step 1:
On Security Mode, select WEP.
Step 2:
Under WEP Encryption, select 40 / 64-bit (10 hex digits) and enter a unique word in the Passphrase field.
NOTE: The 128-bit key uses a higher level of encryption compared to the 64 bit WEP. It uses a 104 bit (26 Hex Character).
Step 3:
Click the Generate button and copy the string of letters and numbers displayed in the space provided for Key 1. The Key 1 contains the wireless password.
NOTE: You can also create your own Wireless Password (Key 1) given that it is in hexadecimal format. The hexadecimal system consists of the characters 0,1,2,3,4,5,6,7,8,9,A,B,C,D,E, and F. You can only choose 10 characters (in any given order) from that set.
Step 4:
Click kb19073-007_en.png.
Wi-Fi Protected Access (WPA)
Wi-Fi Protected Access (WPA) is a Wi-Fi standard designed to improve the security features of WEP. WPA is stronger than WEP encryption. PSK and PSK2, the two types of WPA, give you a choice between two encryption methods: the Temporal Key Integrity Protocol (TKIP), which incorporates Message Integrity Code (MIC) to provide protection against hackers, and Advanced Encryption System (AES), which utilizes a symmetric 128-Bit block data encryption.
NOTE: For older versions of Linksys routers, WPA Personal is also referred to as WPA Pre-Shared Key. Refer to the image below for an example.
To set up WPA Personal on a Linksys router, follow the steps below:
Step 1:
On Security Mode, select WPA Personal.
NOTE: If you are unable to find the WPA Personal or WPA2 Personal in the list of choices for the Security Mode then you might need to upgrade the firmware of your router to its latest version. Upgrading the firmware can fix the bugs of the previous version and update its other features.
Step 2:
Enter your Passphrase.
NOTE: The Passphrase must consist of at least eight characters and is case-sensitive.
Step 3:
Click kb19073-011_en.png.
Sep 19, 2011 | Linksys Wireless-G WRT54G Router
Installing new printer and it's asking for my
The WPA passphrase is the security code that you used to set up the wireless networking. If you can't find that passphrase you will need to reset the device and start over, including for all of your other devices.
Jun 16, 2011 | Linksys WRT320N Wireless Router
Where can I find the security key for my Linksys Router? I have the password, but it isn't working to help me get my laptop on line.
Network security key
Theencryption key secures your data from unauthorized access. The router's password is a Passphrase or the WEP or WPA orWPA2 encryption key. The Passphrase generates the WEP or WPA or WPA2 encryptionkey and this is in the router's wireless settings. To connect to your wireless router, it needs the router'swireless settings configured ie SSID, WPA or WPA2 encryption key and also thewireless cards in all the laptops and or computers needs to be configured withthese router's wireless settings. Then the laptops and desktop computers cancommunicate with your wireless router.
Apr 09, 2011 | Computers & Internet
Where can I find the WPA or WPA 2 Key on my Cisco N?
Mar 19, 2011 | Cisco Linksys Wireless N Home Router...
Need wpa passphrase
To get the WPA passphrase of the Cisco Linksys E1000 Wireless N router, you need to have a computer that is wired to the device. Log in to the router's setup up page by opening a browser then type in 192.168.1.1 on the address bar. Leave the Username blank and on the Password type "admin". On the setup page click on Wireless then on the sub tab click on the Wireless Security. You will see then the WPA passphrase.
Jan 15, 2011 | Cisco Linksys E1000 WirelessN Broadband...
How can i lock my router
1. Use an ethernet cable to connect a computer to any one of the four LAN ports of the linksys router.
2. In a web browser, enter the router's IP address - either http://192.168.0.1 or http://192.168.1.1 by default.
3. When prompted for a Username and Password, enter the default username and password , unless you have already changed it.
4. Select Wireless Settings from the Setup menu in the left-hand navigation bar.
Under SSID Name, Give a Unique name for Wireless N/w
5. Under Security Options, select WPA-PSK (Wi-Fi Protected Access Pre-Shared Key).
6. Under Security Encryption (WPA-PSK) > Passphrase, enter a passphrase.
7. * The passphrase may either be a string of 64 hexidecimal digits, or word/phrase of 8-63 ASCII characters.
* SAVE or KEEP NOTE of the passphrase - it will be required to connect wirelessly to your network.
8. Click Apply to save your settings.
9. Scan and Connect to your Wireless N/w on your Wireless Computer with your Password
Oct 02, 2010 | Linksys WRT300N Wireless Router
I am trying to connect my laptop to my hp printer
It's the password you used to setup security in your wireless router.
Feb 02, 2010 | HP Officejet Pro L7680 All-In-One Printer
Linksys wusb100 usb adapter
Did you put in your WPA passphrase on the software for the adapter?
Click on the linksys icon in the lower right corner, go to site survey select your network then click connect. Put in your security key. That should do it.
Jul 22, 2008 | Linksys WUSB54GC 802.11g/b Wireless...
Security Keys or Passphrase
  1. Now we will secure you wireless connection to prevent others from connecting. Under the Home tab, click the Wireless option from the left.
  2. Beside the SSID option, enter the name for your wireless network connection.
  3. Beside Security, select WPA. If you can’t connect using WPA, then select WEP. Using WPA will provide a much more secure connection that using WEP. For more information about WEP and WPA please read Wireless Security: WEP and WPA.
  4. Click AES beside the Cypher Type.
  5. Make sure PSK is selected beside PSK/EAP.
  6. Now you must get very creative. Specify a long Passphrase with a mix of upper and lower case letters, numbers and punctuation. Once again, please read Creating Secure Passwords for tips on how to do this. In this case the longer the better. Make sure you write down this key somewhere, either on a piece of paper or in a text document on your computer. You will need this information when you connect to your wireless network.
  7. Enter your passphrase next to Passphrase and again beside Confirmed Passphrase.
  8. Click Apply to save your security settings.
  9. Now you are all done securing your wireless router and network. All you need to do is connect to your network, and enter your Passphrase exactly as you specified it. I won’t go into detail on how to connect to your wireless network, as I will save that for another post.
May 10, 2008 | Linksys WUSB54GC 802.11g/b Wireless...
Password settings
Greetings!
I am presuming that the address you are using, 192.168.1.1 is the address from the user manual. This may not be the address that is actually assigned to your router however.
The Linksys Router can be configured in one of two ways, either with a static IP Address or by DHCP, a service that automatically assigns an IP from a DHCP Server on your network.
An easy way to test this is to go to a PC on your network that you know is functional and uses the Linksys Router as its network access point and open a command prompt from the start menu (start/accessories/command prompt).
At the command prompt type in tracert www.fixya.com and hit enter. The first address that you see in the traceroute is the IP address of the Linksys Router.
Write this down IP down and then plug it into your web browser. A login prompt window will appear on the screen. Do NOT enter a login name in this prompt - the default for admin is nothing. Simply input the admin password and the web browser will open to the admin page on the router.
As you are configuring a new network security password and protocol be aware of a few things:
1. WEP and WPA are two types of security used on these routers. Of the two, WPA is the more secure, however there may be devices and or clients on your network that do not support WPA. Prior to selecting WPA verify that there are no devices that cannot use that standard.
2. If you are adding a new security profils (password) and retaining the existing login passwords (keys) then your network will continue to function as it has, however if you delete the existing keys (passwords) then you will need to go to each computer/device on the network and update each with the new login information.
Once you have decided upon the security protocol you intend to use (WEP or WPA) you must then do the following:
1. On the router admin page click WIRELESS and then WIRELESS SECURITY.
2. For WEP you will set the Encryption Size and then enter a passphrase. The router will generate a key in hex and you will need to write down this key and provide it to the users on your network. If you change the passphrase later the key will also change and you will need to repeat the above.
3. For WPA, you set the encryption type and then enter a passphrase. Provide this passphrase to the users as that is how they will authenticate using WPA.
Nov 15, 2007 | Linksys Wireless-G WRT54G Router
Linksys Wireless-G Broadband Router Logo
547 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
