Question about Gateway 300 S PC Desktop
Pc has power,but will not complete boot up process
Keyboard and monitor LEDs flash on and then quickly off.
  • Gateway Master
  • 11,800 Answers
That means that the motherboard on your pc has died. Replace it.
Posted on Aug 01, 2010
My eee intel will turn on but the screen is black and the power lights will come on to when you turn it off it flashes white and thats it!Can someone help me please,
It'd be a good idea to check if the laptop is actually booting up or not getting anywhere at all. You can check this two ways, fairly accurately.
First of all, the best way to check is to plug your laptop into another external monitor, you should be able to do this with the VGA connector on the left side of your laptop. You can do this with any monitor that's used with a PC. See if the monitor turns on when the laptop starts.
If you don't have an external monitor to try, the numlock, caps lock and scroll lock keys on your keyboard should show that they're active by the LED that shows they're on or not. Turn it on and let it boot up (give it a few seconds or minutes to be sure), then press numlock or caps lock or scroll lock and see if the LEDs for those keys turn on or not.
If the external monitor works, or the LEDs are functioning as normal, it's likely that the monitor has a loose connection inside or that the monitor is entirely broken. Since the monitor is flashing white when you turn the laptop off, it would sound to me that the inbuilt monitor is connected but not working.
If the external monitor doesn't work, and the LEDs for capslock etc don't respond, then it's likely that something else is wrong with the laptop entirely.
It will be helpful to know what happens to narrow down additional help.
Dec 23, 2012 | ASUS Eee PC 1005HAB Netbook - Intel Atom...
Desktop PC powers up but can't fully boot
Check hard drive cable, remove and insert again, this only u ca do if u see the bios running up but couldn't complete the process because no hard drive detected.
May 17, 2012 | HP Computers & Internet
Sudenly kingstone usb changed to skymedi and doesnt formated
When the flash drive is inserted and is still detected Kingston, flash drives can be repaired and the data can be saved.
How to save data
To save data, use software full version, for example, you can use EASEUS Data Recovery. After the data is saved, do the repair flash drive.
Repair flash drive Kingston
1. Right-click the flash drive, select Format - select quick format. If this does not work, don't repeat, do the second.
2. Format from Administrative Tools.
Win XP: click START - Control Panel - Administrative Tools - Computer Management - Disk Management - right click the flash drive - select Format - select quick format
Win Vista & 7: click START - Control Panel - select View by: Large Icons - Administrative Tools - Computer Management - Disk Management - right click the flash drive - select Format - Perform a quick format - OK. If this does not work, don't repeat, do the third process.
3. Format using the software, the HP USB Disk Storage Format Tool. Make the process quick format. If this does not work, don't repeat, do the fourth.
4. Repair the flash drive using the software HP Drive Key Boot Utility (Support Win XP, Vista, 7)
How to install the HP Drive Key Boot Utility to the operating system
Win XP: double click the file cp006049.exe - select Install
Win Vista & 7: double click the file cp006049.exe - select extract
How to use the software HP Drive Key Boot Utility
For Win XP, first way
Insert the flash drive - open the HP Drive Key Boot Utility - Next - select flash drives - Next - Create New or Replace ..., select Next - Next select Hard Drive - Create New File system, select Next - wait for the process is completed - Select Next - HP firmware Flash ..., select Next - wait for the process is completed - finish. Then, quick format the flash drive.
For Win XP, second way
Insert the flash drive - open the HP Drive Key Boot Utility - Next - select flash drives - Next - select Backup/Restore - Next - click Restore - click browse, open file C:\Program Files\Compaq\hpdkbu\ flash\initrd.img - Next - wait until the process is complete.
For Win Vista & 7, first way
Insert the flash drive - double click cp006049.exe - for example, extract to C:\HP Drive Key Boot. Open folder C:\HP Drive Key Boot then double click file hpdkbu.exe - Next - select flash drives - Next - Create New or Replace ..., select Next - Next select Hard Drive - Create New File system, select Next - wait for the process is completed - Select Next - HP firmware Flash ..., select Next - wait for the process is completed - finish. Then, quick format the flash drive.
For Win Vista & 7, second way
Insert the flash drive - double click file hpdkbu.exe - Next - select flash drives - Next - select Backup/Restore - Next - click Restore - click browse, open file C:\HP Drive Key Boot\initrd.img - Next - wait until the process is complete.
Description
initrd.img files, the image file for the schema partition flash drive capacity <= 2GB. For capacity >2GB, example: 4GB, 8GB, 16GB, 32GB, etc when we use the initrd.img file, will be changed to 2GB capacity. To restore the capacity of flash drives, do the Low Level Format. To make the process of Low Level Format, use software HDD Low Level Format Tool.
How to restore the capacity of flash drive Kingston
Open HDD Low Level Format Tool - select drive - Continue - click S.M.A.R.T - click Get SMART Attributes - click the tab LOW LEVEL FORMAT - click Format This Device - wait for the process is completed - Finish. Then, remove the flash drive from the computer, then insert it again. Then do a quick format the flash drive. Finish
Hope it helps.
Sep 04, 2011 | Kingston Technologies 512MB DataTraveler I...
Getting orange flash light instead of green stable light on my dell optplex 520 and 745 what should to solve the problem
replace the power supply with a known good one. If that doesn't solve the problem then the motherboard is bad and would need to be replaced.
Jan 15, 2010 | Dell OptiPlex 520 PC Desktop
Pc has power but no response
Connect the video monitor to another working system to see if your monitor is the cause for your dilema.
If the computer logo appears when you first boot up, but it blanks out after the windows logo, then it would be an issue with your installation of windows and may be in need of a reload.
But again, if the monitor is completely black, I would test out the monitor on another machine.
Good Luck
-Carlos:
Dec 20, 2009 | Sony VAIO PCV-RZ45G PC Desktop
My Computer boots and montitor says Going to sleep and flashes VGA : NO signal and goes off
Check under "Power Options" of the control panel of Windows that "Turn off Monitor" is set to "Never" Also check under the advanced tab of "Power options" that "When I press the sleep button on my computer" its set to "Do Nothing"
This will most likely solve your problem. the sleep button may be stuck on the keyboard causing the pc to quickly go into sleep mode
Nov 22, 2009 | HP Vs17 17" LCD Flat Panel Monitor
Laptop powers on but will not boot. Keyboard lights remain on. Disk light comes on for a second and then goes out.
For all troubleshooting, have the notebook connected to the DC power supply.
Does the power stay on? if the power goes off are you getting any beep codes or do the leds flash in a specific pattern? if no beep/led codes, and system turns off, then it's likely to be a bad system board or cpu. if power stays on, but you see nothing on the display, the lcd could have gone bad. can you connect an external monitor to this unit?
Oct 03, 2009 | HP Pavilion ZV5260US (PF144UA#ABA) PC...
Dell wont start up
On the back of the chassis, there are 4 LEDs above the PS2 connections marked ABCD what do they indicate? During the boot process the lights normally flash on and off green, when the boot process is complete, they should all be green GGGG.
If any are Amber then they are indicating a power on self test (POST) failure. AAGG is bad memory for example.
Post the indications
Aug 06, 2008 | Dell Dimension 4600 PC Desktop
Monitor shut off, no BIOS post, no keyboard or mouse lights, will not boot
Try another (Known good monitor). Or try you're monitor on another system.
Remove all memory except 1 DIMM. Double check all data cables (internally) & power cables. Remove the added video card. Try booting the system. Watch for the case LEDs to flash/blink, listen for hard drive spin up /cd-rom spin up. Lastly pull the battery & check with a volt meter. Bios battery should test no less than 3 volts. Post the correct MD rev.
Mike
Jul 22, 2008 | Intel Motherboard
Gateway 300 S PC Desktop Logo
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
