Question about Frigidaire GLEQ2152ES Electric Dryer
Need to remove lower front panel off a LEQ2152es0 model, can you pry it off with a screw dryer, how is it attached. I remember the service tech showing me, but now I can't remember and I need to check for hair as alot as gotten through the regular lint filter (I have alot of dogs so towels and such get very hairy)
    President:
  • 2,468 Answers
There are 2 screws located near the floor,remove these,then it comes outward toward you and unclips,then remove the door hinge screws next with the door open and remove the door,then the upper rest of the front cover can be removed too
Posted on Aug 01, 2010
How to remove the lower front panel on a two panel whirlpool dryer model number LG7801xsw2 gas dryer
Disconnect power then pry the lower access panel off with a flat-head screwdriver as shown.
You may need to pry on the sides of the bottom panel to completely release it.
Feb 12, 2011 | Whirlpool Dryers
How do i remove the driver's inside panel door? My electric button panel for windows and locks isn't moving.
Like reference guide, check this procedure to Removal & Installation / Door Lock Motor...
The door lock motor is integral with the door latch. If the door lock motor is found to be defective, the entire door latch must be replaced.
  1. Before servicing the vehicle, refer to the Precautions Section.
  2. Roll the door glass down.
  3. Disengage the 2 clips attaching the speaker grille to the door trim panel. (They are at the front of the grille, one near the top, and the other one at the bottom).
  4. Remove the 3 large washer-headed screws surrounding the speaker.
    Fig. Fastener location for the door lower trim panel
  5. Remove the access cover at the front of the door trim panel. Remove by prying at its rear edge.
  6. Remove the red courtesy reflector from the lower tail of door. Disengage by prying at the screwdriver notch at the bottom of the reflector.
  7. Remove the flag trim panel from the door by prying it off at the 2 attachment clip points.
  8. Remove the 7 screws attaching the door trim panel to door:
    1. One screw is located at the lower rear screw pocket.
    2. Three screws are located along the bottom of the door.
    3. One screw is located inside the handle opening.
    4. One screw is located at the upper front.
    5. One screw is in the pull cup.
  9. Disengage the 2 hidden clips attaching the rear of the trim panel; pry them off at the 2 attachment clip points.
  10. Lift the trim panel upward and away from the door, disengage the trim panel from the upper retainer channel.
  11. Disengage the clip attaching the latch linkage to back door handle.
  12. Disconnect the electrical connectors as necessary, including the lower foot light, if equipped.
  13. Remove the door trim panel from the door.
  14. Remove the water shield (water dam) from the inside of the door.
    Fig. Remove the flag trim panel, door trim access cover, inside remote handle, and power door lock switch
  15. Raise the door glass.
  16. Remove the bolt and nut for the rear glass run channel and position the channel aside.
  17. Disconnect the lock rod from the lock button bellcrank.
  18. Disengage the lock and latch rods from the clips on the inner door panel.
  19. Disconnect the lock and latch rods from the outside door handle and the key cylinder at the door latch.
  20. Disconnect the wire connector from the power door lock motor.
  21. Remove the screws attaching the door latch to the door end frame.
  22. Remove the door latch and the power door lock motor from the vehicle.
    Fig. Expanded view of the door lock, latch, and linkage
    Fig. View of the door lock button, latch rod, lock rod, and door latch
Hope helps (remember rated this).
Jun 26, 2010 | 2000 Chrysler Sebring
How to remove the front panel of a maytag neptune gas dryer
Removal of the front panel requires the removal of the top cover and the console. Disconnect power to the dryer prior to servicing to avoid the risk of electric shock.
Remove the 2 screws attaching the top cover to the rear of the dryer then slide it rearward to clear the screw head from the top cover flange and lift the cover off the dryer cabinet.
Remove the screws securing the heater PCB board and disconnect the black and white wiring harness connectors from the board.
Remove the four screws attaching the console to the washer cabinet and rotate the console down to remove it from the dryer.
Remove the four screws attaching the top of the front panel to the cabinet and the two screws at the bottom of the door opening.
Pull the front panel forward and disconnect the interior light wiring harness then lift the front panel off the tabs across the bottom and move it away from the dryer.
Reinstall the front panel, the console, and the top cover in reverse of the removal steps.
Apr 21, 2010 | Maytag Neptune MDG5500AW Gas Dryer
IGNITER LIGHTS BUT NO FLAME
Hi, You will need to change the coils on top ogf the gas valve. If this is a Whirlpool model with rear panel access here is how: UNPLUG the dryer. This model you need to remove the two screws under the lint screen. Now use a flat blade screw drive and insert it in the gap between the top and the front panel and pry the top up. Now locate and remove the screws on the inside of the front panel in upper corners. The front should lift off. You will see the two black coils on the gas valve. When you remove the three wire coil, make sure the sleeve inside it gets put back on the post the coils slides onto.
If this model is a front access model, just remove the lower front panle and the valve is on the right side
If I can assist you further, please let me know.
Thanks
Vic
Jul 15, 2009 | Dryers
Driver side power window stopped working
The door panel is held on by plastic clips and 5 screws. 3 screws are on the bottom and 1 in the pull cup and 1 in the inner door handle.Then grab one of the corners and give a small tug, when you get some of the clips to pop out then proceed around the whole panel. To replace the panel take the clips out of the door with a fork and slide them back into the panel and then line it up on the door and use your hand like a hammer and bang the panel back on. Hope this helps
Jan 12, 2009 | 2004 Chrysler Sebring
Push to start switch for whirlpool dryer i need diagram i have four terminals on switch two blk. wires, one tan, and one white withred stripe whirlpool model #11062822101
hi how-to-repair-a-dryer-1.jpg Except for the power cord and the exhaust vent, the components that make up the dryer are contained in a sheet metal box. Each component acts independently of the others, but all are interrelated in some way. There are several different ways to disassemble the cabinet for tests and repairs, depending on the manufacturer and model of the machine. Basic disassembly procedures are simple.
Some knobs may be held to their shafts with setscrews. Unscrew the fasteners and pull the knobs straight out. To get at most parts, however, only remove the back panel. Don't disassemble the rest of the cabinet until you're sure you can't make the tests, replacements, or repairs from the back. If the light in the dryer burns out, remove it from the dryer. You may need to remove retaining screws and panels to access it. Replace the burned-out bulb with a new one of the same type and wattage; check the ends of the
Step 2: To remove the lower front panel, pull it away from the bottom of the cabinet. Lift the lower panel up and away. Remove the springs under each side of the lower panel.
Step 3: To remove the top panel, wedge a stiff-bladed putty knife under the rim of the top and pry the top off. The putty knife helps release several spring fasteners at the top of the cabinet sides and front.
Step 4: To remove the dryer's control panel, remove the screws that hold it to the cabinet top or front. These screws may be under a piece of metal or plastic trim; pry off or unscrew the trim. Most knobs are friction-fit; pull them straight out.
Caution: When testing or repairing the electrical parts of a gas dryer, remember that the dryer is hooked to a gas pipe. Turn off the shutoff valve on the supply pipe before disconnecting the gas supply line or moving the dryer and before doing any electrical work.
Sep 13, 2008 | Dryers
Hi, just a quick question. How do I remove the front panel from my Whirlpool dryer, and with which tools? The tumbler is scraping badly, and I want to diagnose it before condemning the appliance. It's not...
Disconnect the unit from its power supply before servicing!
Most Whirlpool dryers are disassembled by:
1. Raising the cover of the lint filter retainer housing on the top panel of the dryer, (if this where it is located), and removing 2 screws.
2. Using a flat blade screw driver, slide it between the top panel and the front panel approx. 3" in from the corners and pry upward gently. This will release the top from the front panel.
3. Remove the 5/16" screw from the inside corner where the front joins to the side panel, (Repeat procedure on the other side).
4.If your model has a separate lower panel, remove it by using the flat blade screwdriver and sliding it in frrom the side and gently twisting to release the retainer spring clip, ( Repeat procedure on other side). Remove door springs. ( make sure your door is latched tightly 1st).
5.Loosen or remove 2-5/16" screws from under the door at each corner.
6. You should now be able to remove the upper portion of the front panel.
May 28, 2008 | Whirlpool Dryers
How to disassemble amana clothes dryer
2 screws across the ;lower acess panel, then another 2 screws behind that panel will allow front panel to be removed, adn behind that panel will be 4 more screw attaching the front bulkhead, all 5/16 screws, pretty easy just remember to write the color of wires leading to the door switch before discnnecting
Apr 14, 2008 | Dryers
Frigidaire GLEQ2152ES Electric Dryer Logo
189 people viewed this question
Top Frigidaire Dryers Experts
Tim Whalen
Marvin
Marvin
Sal De
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
