I need instalation software for linksys wireless b router
    Scholar:
  • 176 Answers
Try the link below to open the internet browser in download the driver.
http://www.driverskit.com/freedownload/Net_Card/Linksys/BEFW11S4_4_Wireless-B_Broadband_Router_1_50_10/17771.html
Posted on Apr 25, 2008
How to setup linksys router
You can setup Linksys router without installation CD or software.
Connect the computer to the router and open the setup page of the router.
Change the Internet and wireless settings manually.
I will suggest you a website on How to setup Linksys wireless router.
This website may help you installing your router
May 28, 2010 | Linksys Wireless-G Broadband Router
Need cd for downloading program
Assuming you are trying to install a router.... routers do not use drivers or software. CD's provided with Routers are generally used to walk you through the installation/setup process. Most Linksys routers are default accessible at 192.168.1.1 via your browser. the default username is admin and the password is usually admin. If this does not work, try resetting the router by pressing the rest button located on the back of the unit (small hole) with a paperclip. hold the button in for about 1 minute and then release it... If you are unlucky enough to have a unit with a flashing power lite, this is a dead unit and is not repairable. Look up your model for more specific instructions on www.linksys.com under the support section.
Apr 12, 2010 | Linksys Wireless-G Broadband Router
INSTALLING THE SOFTWARE
No special software is required on your computers for this device to work.
Feb 07, 2010 | Linksys Wireless-G WRT54G Router
WRT400N LELA software not working
by default ip address of linksys is 192.168.1.1
to star config you need to be connected with ethernet cord rj-45
or conenct via wireless by conencting to linksys on wireless
admin user: blank
admin pws: admin
*choose a protocol on your linksys router on internect conenction type:
check isp protocol :
dhcp: needs serail number of mac address
it picks up automatic
pppoe: needs username and pws from isp
*the ip address has to be diferent from the isp modem:
isp modem 192.168.1.1 linksys 192.168.1.1 incorrect
isp modem 192.168.1.1 linksys 192.168.2.1 correct
change the ip on lan settings on your router
*wireless: ssid by default is linksys
ssid: linksys
wep : none
to setup wireless
access the wireless basic
change the ssid to any network name
enable the wireless password
choose wireless security
enable wep key 10 digit hex pws
make shure you saved settings on every settings
Sep 23, 2009 | Linksys WRT400N Router
Lenovo laptop cannot seem to find the linksys wireless g. we have two WIFI at the office one is linksys VOIP (secure) and linksys wireless G (unsecure). why is it that lenovo laptop only sees the secure...
make sure that the linksys VOIP(secure) router is broadcasting it's SSID or signal, otherwise it will not reflect even if you refresh the wireless network. If the router is broadcasting SSID but the lenovo laptop is not detecting it, try to re-install the wireless software for the laptop using the software from lenovo.com, just click Support then Downloads and drivers.
May 13, 2009 | Linksys Wireless-G Broadband Router
No Active Internet Connection
If you want to use the wireless portion of your router, you would need a wireless adapter installed on your desktop. If you are getting internet on your desktop then this means that your wired connection is fine to the router is fine. The WMP54G adapter will work with your router, however if you are not planning on connecting to the internet wirelessly through the router then there is no need to purchase the adapter. Hope that this helps you out.
Serge C.
Mar 30, 2009 | Linksys Wireless-G WRT54G Router
No Installation CD
No it's not needed, the main things you need to know is the IP address that the router is set to and it's login details which hopefully your friend can give you. (default IP: 192.168.1.1, default login and password: admin and admin)
After that, as long as your HS Internet modem has an ethernet port you would connect that to the Linksys and your PC's to the routers LAN ports. You can then also login to the router and setup the wireless part if you have any wireless devices to use with it.
Jan 24, 2008 | Linksys Wireless-G WRT54G Router
My laptop won't work wireless
Use windows network setup wizard to help in setting up your wireless. The wizard can search for your wireless. Some people believe you gan get away without using Linksys's software & I agree to a point. However Linksys believes to maintain a good connection you should install the software for the wireless router. You can download it from the link below. Check out the link "Learning Center". You might find it helpful. http://www.linksys.com/servlet/Satellite?c=L_CASupport_C2&childpagename=US%2FLayout&cid=1166859837401&pagename=Linksys%2FCommon%2FVisitorWrapper&lid=3740137401B343
I suggest to all running a wireless connection to set up security with a password to keep freeloaders from tapping into your bandwith for free.
Luck!
Please vote...
Jan 23, 2008 | Linksys Wireless-G WRT54G Router
Linksys wireless G-ADSL Home gateway
Sometimes this happens. Installing the Linksys software for your router helps a lot. To reset the router. Unplug the power cord from the wireless & unplug all cables to it. There is a reset button on the back side of the wireless. It is very small. Using a pen press & hold for ten seconds or so. Release & connect your cables & than the power cord. Never hurts to restart the pc or notebook. If you still need help you can check out Linksys home page for wireless G routers.
There is a decent ammount of help, a larning center & driver software.
Luck!
Please vote....
Jan 19, 2008 | Linksys Wireless-G WRT54G Router
Need driver
Routers don't actually have drivers. Linksys provides some software that can make the installation a bit easier, but no driver is required (or exists).
The Linksys website has some good instructions on installing and setting up their products. I would begin there or if you can give me more details on what problem you're having I would be happy to help.
Dec 22, 2007 | Linksys Wireless Ap + 4 Port Router...
Computers & Internet Logo
35 people viewed this question
David Payne
David Payne
