It shut down often when using and sometimes very difficult to boot it again unless from several trial
  • 11,800 Answers
Your Windows is full of viruses and corrupted. Just reinstall it and it will be good again.
Posted on Aug 01, 2010
My computer wil not shut down it re boots straight away
Hold the power switch down until the computer shuts down all the way. It should not reboot again unless you have a bad power switch.
Nov 01, 2010 | Evesham Computers & Internet
HP DV928US When battery in or charger plugged in
fails battery out so leave it out they love to short.
so when it fails test 2 is, hit the F10 or ESC key promptee
went it fails to boot, check BIOS key first, if BIOS fails.
be more clear.
what does it do when it wont turn on.
BIOS dead. screen 100% dead, and not even text
BIOS works even with HDD and DVD drive pulled.
that is the acid test on PCs.
the screen must say, hit F10? or ESC to enter setup, means HP BIOS. it must or power is no good. get a new power pack
the shut down tell me lost power, that can be the power pack 19vdc
or the jack at the mobo if failing to said pack.
try side pressure on that jack if at anytime the power button fails.
it self shuts down, I got that but lets fix , cant boot first.
that is how to fix this.
power on failures, are you saying the power key fails. some times
and the fan does not run every time.?
Also,
this old LT uses CCFL back lamps.
that love to fail. so when it shut down did the fan die.
did the HDD stop spinning ear to bottom? if not the CCFL is failing.
using and external monitor proves this every time,
do the flash light trick?
http://www.pcdied.com/monitors.html#flashlighttest
Aug 29, 2017 | HP Pavilion dv6928us Notebook
Gateway LX6810-So many problems, won't boot unless forced on and off several times, shuts down with blue crash screen constantly, fails after hibernation, bios won't even load sometimes until repeated...
I would RMA it if you can. If not run diagnostics on RAM and HD. If its not one of those i would suspect the motherboard. Although most Gateways use Intel Desktop Boards, which are halfway decent. If it is the board I suggest replacing it with Asus.
Jan 02, 2010 | Gateway LX6810 PC Desktop
Tecra m8 boot up problem
The true test here is, can it boot into the BIOS every time. If it can, then I suspect your getting ready to have a hard drive failure. Intermittent boot failures and non-start-ups are usually caused by a faulty hard drive. If it was your boot menu or boot loader, then it would never boot period. I would suspect the hard drive overheated and is damaged, or there are damaged sectors on the drive that contain some of your windows files.
Sep 25, 2009 | Toshiba N97842 13.3 TECRA M8-S8011 INTEL...
Toshiba Satellite M-200 laptop refuses to start
I am sorry. This problem is best solved by doing a complete system restore of you laptop.
Do you have the restore disk that came with it?
Aug 10, 2009 | Toshiba Portege M200 Notebook
Pc not always booting,
blow out dirts on bord, then you pack the board to avoid any bridging with the cassing
Jul 20, 2009 | Computers & Internet
1987 LeBaron won't start unless I pour gas into
Check you injector seals,you may be losing pressure in the fuel lines
Jul 16, 2009 | 1987 Chrysler LeBaron
My motorola v3m will shut down or sometimes screen will be black but keys are still lit up and I have to press on button several times to get it to fully boot up again.
You should try resetting the handset back to its original factory settings and see if this helps, if not maybe you need to flash your handset with the original firmware
May 09, 2009 | Motorola Mobility RAZR V3m Cellular Phone
My Dell Dimension 9150 will not turn on
Use your CD to boot up the computer and recover your operating system
May 05, 2009 | Dell Dimension 9150 (DIM915MIN) PC Desktop
Shutdown problem
Several things to check can be found HERE
May 31, 2008 | Microsoft Windows XP Professional With...
Computers & Internet Logo
13 people viewed this question
Alun Cox
David Payne
David Payne
