Question about Ryobi 30 Cubic Centimeter Curved Shaft Gas Trimmer
The pull cord on my ryobi rlt30ht is stuck in the fullyextended position
4 Suggested Answers
SOURCE: Ryobi RLT30HT hard to start, won't tick over
Hi
On the rotochoke scale, between the run and half choke position there is a hole and in it there is a screw. This adjusts the idle. Turn clockwise to speed up, anticlockwise to slow down
Posted on Jul 02, 2009
  • 148 Answers
SOURCE: RLT30HT 30CC PETROL STRIMMER difficult to start
The plug that I have in my 720r is a Champion RDJ7Y. Can I suggest that you pull the old plug out and look to see which one you have? Also when you buy the new replacement it should already be gapped for what you need.
Posted on Jul 28, 2009
  • 151 Answers
SOURCE: Howdo I fit a new pull start cord on a ryobi 25cc
remove the plastic housing to gain access to the recoil. Pull the cord slowly all the way out,this will cause the spring to wind up.Clamp the recoil wheel so it will not return to its original position,be carefull the recoil has tension on it not remove the old pull rope and thread the new one in and thru the hole of the recoil tie knot.pull on the cord to take tension off and at the same time remove clamp. Slowly allow the recoil to wind the rope in and reinstall on unit.
Posted on Dec 24, 2009
Ryobi ss26 trimmer puller cord won't retract
It appears that the recoil spring has broken and you will have to pull it apart to replace it
Jun 17, 2013 | Ryobi Multi-Volt Battery Charger
Pull cord on my ryobi ss26 trimmer is stuck and will not pull out.
first pull your spark plug out to make sure you don't have cylimder full of gas and get back with us
Apr 27, 2011 | Ryobi Garden
The pull cord on my ZR29550 string trimmer is stuck in the fully retracted position. I can't pull it to start the machine. Also the electric starter can't turn it over.
well its not going to start with electric because the cord is out of it...
just take it apart becareful do not pull the recoil out or your in a mess....
but this should help you out if you need to know more just ask...
Aug 18, 2010 | Ryobi 15" Electric Factory Reconditioned...
The pull cord is stuck?
take the flywheel cover off and see what has it stuck.if it is the square nut that the rope pulley goes on the it needs some oil put in the hole on the end of it.it should turn to the left and not turn without turning the flywheel to the right.once you have it where it will turn easily to the left it should pull the pull rope back in after the engine cranks.if the flywheel won't turn to the right then you have a locked up motor.
May 27, 2010 | Ryobi Cultivator
Trying to replace pull cord on ryobi cs30. How do
how do I repair/replace the pull cord on my Ryobi CS30?
May 22, 2010 | Ryobi Garden
Starting cord won't release
TAKE OFF THREE SQREWS AROUND PULL CORD BUT DONT REMOVE, CARFULY LIFT EDGE SLIDE SCREW DRIVER IN TO HOLD PULLEY WHEEL IN PLACE , TURN OVER AND INSPECT COULD BE DIRT AND DABREE OR ONE OF THE TWO METAL LEVER,S (UNDER) PULLY WHEEL ARE STUCK UNJAM AND RETURN CARFULLY PUT SCREWS BACK IN AND TITEN BUT DONT STRIP IT OUT FROM OVERTITENING
Feb 17, 2010 | Ryobi Garden
Dec 15, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Jul 27, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Hi
Jun 11, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Ryobi 30 Cubic Centimeter Curved Shaft Gas Trimmer Logo
80 people viewed this question
Top Ryobi Garden Experts
Jim Parker
Jim Parker
Rexter1
Phil Walker
Phil Walker
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
