Question about E-Machines eMachines Desktop PC
Hd is there but not there
I installed a hard drive to my system. It is recognized in bios but does not show on my system i cannot load a operation system because it states i do not have one installed
  • brian c
    brian c May 11, 2010
    Is it a SATA drive?
    Also, please specify which model E-Machines you have.
  • 20 Answers
You have to do a resart and hit f2 key to go into bios. Change the startup device to the cd-rom drive. What ever os you are running you must put that disk in and you need to hit a key to run from the disk. You have to format the drive and install OS. If this is just a data drive, you still have to format drive but don"t install OS.
Posted on Apr 25, 2008
Boot failure insert system disk, but it wont load
You need to check both in BIOS by pressing F key during boot. First check to see if HD is there. If OK, then change Optical drive to first boot, save and reboot.
IF MISSING HD -
Your hard drive is missing from the system. Or, just does not recognize it. The obvious - Remove any USB devices like drives and any media from disc player. Its trying to load, but can't find bootable hard drive, CD, or USB... Remove the hard drive and re-seat (reconnect). Check BIOS by pressing an F key during boot. Look on the screen for correct Function key. Might be F2 key. Verify BIOS recognizes the drive. It must be listed! There is no going forward if it's not. Check boot order and make internal hard drive first. Save and restart.
Dec 07, 2012 | Computers & Internet
Gatewat CX2724 original HD died (Hitachi 100GB @5400RPM) I just installed a brand new WD 250GB @7200RPM. Since I didn't have the original recovery disk I'm trying to install a full version Windows XP...
if you have a new hard drive you will have to install the windows operating system from an external source such as a cd drive
go to bios --boot settings and change from 1st boot hard drive to 1st boot cd
install the win os and then you can install the rest
when finished go back to bios and -boot and change back to 1st boot hard drive
Apr 24, 2017 | Gateway CX2724 Notebook
I reciently installed a bigger HD and now I get the"blue screen from hell"!! How can I get it to boot on the new HD?,Ray
did you format the hard drive first?
typically you need to format the hard drive using the NTFS file system before you install your operating system.
does your bios recognize the hard drive?
make sure your bios detects the hard drive.
can you boot your computer in Safe Mode? If so, do that and use your error log to find the specific cause of the blue screen,
lastly post the blue screen error message on here to get a better answer.
Nov 26, 2009 | HP EliteBook 6930p Notebook
I installed a new hard drive, getting media error
Make sure your hard drive is being recognized in the BIOS. If it is then go ahead and install your operating system and any drivers you need for your hardware.
If its not being recognized then take out the hard drive and reseat the hard drive back into its slot. Go back into the BIOS and see if its showing up now. If not then more then likely the new hard drive is faulty. Best way to verify this is to try a good known working one in there and go in the BIOS to see that its showing up.
Jun 07, 2009 | HP Pavilion dv2000t Notebook
Does not show up in my computer but does in bios
Can you boot the computer from a boot floppy?
If so, try and partition and format the drive with fdisk and format.
May 20, 2009 | Maxtor DiamondMax D540X (4D060H3) 60 GB...
I have a new hard drive and no operating system for my laptop
well you donot need special programs you can use the same operating system to format, partition and load your operating system, after you connect your harddrive to your board go to setup Bios and look for the hardware that installed on your chip and you will see if your hardrive is recognized, After that load your operating system cd on your dvd rom and let the pc boot to that dvd drive, here the you will start loading the operating system, so you have to format, partition and then install windows, Try windows vista will make it easy for you.
Best Regards
Feb 28, 2009 | Dell Latitude D600 Notebook
Hard Drive not found after installing software.
  1. Boot to the bios with the HDD connected
  2. Turn on all the lock lights on keyboard (SCROLL< CAPS<NUM)
  3. Press ALT+E (Wait for Beep)
  4. Press ALT+F (Wait for Beep)
  5. Press ALT+B to reboot
  6. IDE redetect should initialize on boot.
  7. HDDs should now be seen
Sep 29, 2008 | Computers & Internet
Realtek HD Driver Instllation failure
Please explain more the position:
1. Is the hard drive properly connected in the computer?
2. have you booted the computer to recognize HD in BIOS?
3. Have you inserted bootabe Windows CD to attempt loading the operating system?
4. Has the Operating system loaded and failed?
Note: hard Drives are made in Standard Industry specs. If its good and connected properly it should work. If it is a second or third hard drive you are connecting, it may be connected wrong in data cables.
Feb 17, 2008 | Computers & Internet
DVD hardrive problem
Do you check the setting of your hard drive? It seems that you have already another hard drive (HD) install which is working already were your operating system install. Try to put the 2nd HD setting in slave position. Follow instruction that is written at the back of HD. Your computer should read the 2nd HD as slave and will see it as drive: F or G and so on.
Jan 11, 2008 | Acer Aspire T690 (AST690UP820A) PC...
E-Machines eMachines Desktop PC Logo
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
