Question about GE Refrigerators
On our side by side, the partition between the sections get really hot. Why?
  • GE Master
  • 1,606 Answers
Very hot partitions are either caused by dirty coils under refrig or the fan motor behind the refrig which cools the compressor and coils , is not working . Sometimes , a mouse gets caught in the blade and stops the motor . This is behind the refrig , behind the lower panel .
Posted on Aug 01, 2010
  • 1,543 Answers
Refrigerators used to use a low wattage electric heater to warm this area in order to prevent condensation from forming there. Now, in an energy concious world, they use a loop from the condensor so "waste" heat can be used for this purpose. If the refrig has been running a long time, this area can become rather hot.
Section between refrigerator and freezer extremely hot.
Check your owners manual troubleshooting. See if you find an answer. Please be more specific. Sounds like it's "stuck" in defrost mode, since it uses electrical heating elements to make the freezer coils melt ice off, but only lasts long enough to remove the collected ice. I would guess the unit runs constantly, or cannot maintain temperature. If the defrost cycle is not working there is a timer not working, or relay, or somehow a very rare short in the defrost system.
Feb 18, 2015 | Whirlpool 25.6 cu. ft. Side-by-Side...
My hard drive has been split, how do I make it back into one?
You can delete both partitions and then create a single partition and then format the partition.
If you do not want to delete the partitions and lose your data then you can use a program called Partition Magic to resize your main partition so it is a single partition.
Dec 11, 2011 | LaCie Computers & Internet
My computer will not pick up my drive when i put it in
The windows disk management utility will help solve this issue most of the time. Use the directions below:
Right click on you "My Computer" Icon
A menu will open
Chose "Manage"
The Computer Management window will open
The Computer Management window is broken down into 3 sections.
The first section on the left side of the window shows a menu. Disk Management is on the lower portion of the menu.
The right side is separated into two sections, top and bottom. The top portion shows a list of active drives on the computer. The lower portion shows all drives connected to the computer. CD or DVD drives that have not disk will not show as active drives on the top section, but can be seen in the lower section.
The lower section will show the drive description, drive size and drive condition (online or off line) in small box on the left side of that section. Disk drives will designate a "Drive" and a number. Drive 0 is usually your internal hard drive. Then it would list drive 1, drive 2, etc, depending on how many internal and external drive sources you have connected to your computer. Then it will list your CD drives and generally show their drive letter assignments.
Next to the smaller section described above, is a larger section which shows the driver letter, size of the driver and condition (if working correctly will show "healthy")
This is the area you can right click and get a menu that will allow you to open, explore, mark the partition as active, change the driver letter, format the drive or delete a partition. (A note of caution here. Changing the driver letter on your main hard drive partition will cause windows to stop functioning. The main hard drive, or hard drive partition, is normally given the letter "C".) A hard drive may show two or more partitions with separate drive letters designated for each partition.
A drive that is having a problem may show that it needs to be formatted (status as Unformatted). This can be done from this window. An external drive, whether it is a hard drive or CD/DVD drive, can have the letter designator change done if you want to organize your external drives. There are times when a drive will not show up because the drive letter that they are programmed to use are taken. Most USB drives are programmed to us the letters "F" or "G". In this area, you can assign the USB drive any drive letter that is not being used and this will make it visible in windows.
If you found this answer helpful, please remember to leave positive feedback.
Thank You,
Brian
Mar 20, 2011 | Computers & Internet
Where is sandisk repair centre in banglore? my 8 gb pen drive is not able to access by the computer and it is not getting formated
You can work at formatting you cruzer using windows disk management utility. The instructions are listed below. This may help you avoid going to the repair center. If your computer does not see the flash drive and you see no activity, the cruzer may failed. These 2 gb flash drives are really cheaper to replace than to repair in todays market. Also here is a link to Scandisk support showing directions and images refering the use of disk management.
http://kb.sandisk.com/app/answers/detail/a_id/10/sno/0
Here are the directions:
- Right click on you "My Computer" Icon
A menu will open
Chose "Manage"
If you found this information helpful, please remember to leave positive feedback.
Thank You,
Brian
Feb 11, 2011 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
We have recently noticed that the part of the refrigerator that separates the freezer from the refrigerator is very hot to the touch on the Samsung RS2630WW Side by Side Refrigerator. It also seems hot on...
This is a sure sign of pending compressor failure (high heat and head pressure, Since that 2 inch section comes directly from the compressor.For verification,
Remove the back cover, and place your hand on the compressor.(careful,may be hot) should be able to leave your hand on compressor without burning.
Check condensor fan in that same area , It may be not running
causing all the trouble
If this was helpful please rate me.
IMUFO2
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Sep 09, 2010 | Samsung RS2630WW Side by Side Refrigerator
Whirlpool 25.6 cu. ft. side by side Refrigerator with in door ice
The process of Refrigeration is for one section to be hot while cooling another section. I.e freezing in one section result in the heat build up and dissipattion else where. Any compressor working properly is going to be quite warm to the point of being hot to the touch when working NORMALLY. There is nothing that you need to do for the continued safe operation of your compressor. If your freezer has ice build up again in the near future your uint is not defrosting properly. If it functions normally after 2 or 3 days of use then you more than likely had a one time buildup of ice usually caused by someone leaving the door partially open
Jan 03, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Center front partition is very hot!
Either your coils are dirty ( clean from the front after removing the kickplate , only what you can get to ) or , the condensor fan motor is bad ( motor which cools the compressor ) .
Jul 07, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Center partition wall of refrigerator is hot !
Sounds like your condenser fan isn't working...Take the back cover off to see if there's anything stuck in the fan blades. Usually when the fan stops, the compressor & tubing that runs between the doors get really hot. You may also want to clean your condenser coils.
Feb 22, 2009 | KitchenAid Superba Architect KSCS25INSS...
Hot high side assembly and at the front door section
Replaced the GE fan motor which seems to have solved the problem.
Dec 28, 2008 | Kenmore Refrigerators
Divider red hot
I'm not familiar with the Samsung refrigerators, but on most side-by-sides the evaporator (cooling) coils are located within the divider partition between the two sides.... along with the defroster 'heater' coils. During the defrost cycle, this panel may feel warm/hot to the touch. Are the freezer/refrigerator sections staying as cold as they should be otherwise? If they are also TOO WARM, then you may have a 'defrost cycle' relay or timer motor malfunctioning.
also see if the fan works properly.
Good luck..
Aug 09, 2008 | Samsung RS2630SH Side by Side Refrigerator
Refrigerators Logo
70 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
