Question about Coffee Makers & Espresso Machines
Weak or no coffee
I also have the same problem of either no or weak coffee in my 2-4 cup FCP model. Now my problem is to find parts to fit this model, since all the suggested sites do not offer those...
    Scholar:
  • 176 Answers
Hi, Go to eBay, search for Farberware coffee pot parts. You will see my auctions for parts, I have all the parts you might need. Your pot is a china 4 cup. Meny people are having bad luck with the inports from China. I should be able to help. Ron
Posted on Aug 11, 2010
I recently purchased a 4-cup Farberware coffee pot (to replace one that served me well for over 30 years!!) The Model number is FCP with the initial G a few spaces after the FCP. I have had trouble...
Helen,
Fixya is does not sell parts or service, but rather helps answer questions about getting parts and service problems resolved.
You should contact the Farberware website for a replacement cord for your Coffee Pot. Click the "Customer Service" button on the left side of the page, or telephone 1-800-233-9054 for customer service if you'd prefer to speak with someone instead.
I hope this helps - and Happy Thanksgiving to you, too!
Nov 18, 2010 | Microwave Ovens
FCP-240,280,412 Farberware Percolator, 3 Prong Cord is too heavy for the percolator. It sometimes comes loose and we have cold coffee. Also the Spring on the Pump Tube does not stay in place. Any Help?
HI, on the plug, is it the part that pluges into the wall or the pot. By the model # you have 3 China pots. On the pump just below the coffee basket, take a pair of pliers and put the basket on the tube , now just make small crimp just below the basket,just enough to make it out of round., you will make it so the crimp will not let the spring or basket go by. If it is the plug going into the wall just bend the 2 flat outward so the plug fits snug. Good luck . Ron
Jun 20, 2010 | Coffee Makers & Espresso Machines
Coffee to water ratio
Weak coffee is 2 tsp per cup strong coffee is 3 tsp or 1 Tbls per cup. (3 tsp per Tblsp) 32 Tablespoons = 2 Cups, there are 4 Tblsp per 1/4 cup. If you're confused ( I am from reading my answer) Use 1 cup for weak coffee, two cups for strong or 1 & 1/2 for regular strength coffee. Hope that helps!
Apr 11, 2010 | West Bend (58036) 36-Cup Coffee Maker
I have a fcp 512 and the contacts in the base are
Hi. The model # you have a 12 cup China pot.You have to replace the base. Do you use a 3 wire cord or a 2 wire cord. I have the 2 wire base, 8.00 plus 3.00 Go to eBay (ron622c) in find member. bobbyone
Nov 05, 2009 | Faberware Coffee Makers & Espresso...
Coffee comes out as weak as coloured water! far too weak.
you probably are not putting enough coffee in to strengthen the coffee
Apr 25, 2009 | Philips Senseo HD-7810 Coffee Maker
I need the plastic base for a Faberware FCP 240-A 4 cup Percolato
ok heres a simple fix if you dont have the money for replacement or cant find parts
J.B.weld from auto parts store this stuff if strong enough to fix a cracked engine block so im sure the pot can get fixed this way
Dec 06, 2008 | Faberware FCP240 Coffee Maker
Senseo machine has started producing very weak coffee
I don't know if you've tried this, but it works like gangbusters for me. I use non-senseo pods with the 2-pod holder, and they're too big for the 1-pod holder but not quite big enough for the 2-pod one.
I would frequently end up with a lousy, weak cup of coffee, and after a little investigation I deduced that water was flowing into the pod holder and AROUND the pod, without going THROUGH the pod directly. The name-brand senseo pods fit perfectly, and always produce a strong cup, even if I don't like their coffee, and it's because there's such a tight seal between where water flows in and where it flows out.
Simple solution: Put your pod in with the flat part facing up, and the bulgy part facing down. Press it down hard into the 2-cup holder. Run a little HOT tap water, and lightly wet the surface of the pod--not so much water that the pod starts floating in the holder, but enough to get it soggy. Then make your cup of coffee. The water will flow through the pod first, and kind of like siphoning gas through a hose, once it's started going through the pod it won't stop. Instant awesome cup.
Oct 24, 2008 | Philips Senseo HD-7810 Coffee Maker
Coffee Makers & Espresso Machines Logo
49 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
