Question about Dell XPS™ 600 PC Desktop
Light and fans come on for one second then shut
When I press the power button on my XPS 600, the light comes on and the fans turn for one second, then shut down.
  • 1,511 Answers
Hello and Welcome to FixYa!
It seems that there is some hardware conflict or hardware problem (Heating/malfunctioning). To trouble shoot the problem you need to remove all the peripherals (Sound Card, Modem, T.V tuner card,e.t.c.). Remove the RAM from the RAM slots. Use a soft clean cloth to clear the dust particles if any.Re install the RAMs to the Ram slots. Remove extra drives (If any Installed in the computer). Try changing the power socket to any other power outlet (If Possible). Press the data and power cables to make sure that they are inserted properly...
Above are the steps to minimize any hardware compatibility issues. If the problem still persists, you need to cross check each hardware Physically.But that would be discussed later if needed. Please each possibility one by one carefully and you will have your trouble resolved.
Best of Luck,
Please Do Rate the solution, If you think this helps you,
Concerned.
Posted on Aug 01, 2010
  • 9 more comments
  • bob7297 Aug 01, 2010
    Ok I've done that. Same problem no matter which parts are removed. One thing I did notice was that the fans turned on for a split-second when I plug the power cord back in.
  • Waqar Hassan
    Waqar Hassan Aug 01, 2010
    Ok! Remove the BIOS cell and wait for 10 seconds and re-insert it, Secondly remove the main Power cable (that comes from PSU to motherboard), remove that cable and tightly insert it to the socket. It seems like that the PSU is making trouble and needs to be check physically and replaced if faulty... You can cross check the PSU, if you are available with...
    I don't have a schematic and am communicating by iPhone. Where is the Bios/ how do I recognize it?
  • Waqar Hassan
    There is a small cell (battery ) installed on the motherboard. Usually Shinning Silver in color with black or blue jacket. You need to remove that cell and then re insert it after at least 10 seconds. This will restore the BIOS settings to default one.
    No change. How do I check the psu?
  • Waqar Hassan
    Here is the simple way to check the PSU using a multimeter:
    1. Turn off the PC, but do not unplug it. Open the system unit. Set the multimeter to read DC volts in the next range higher than 12 volts. Locate a power connector similar to the hard drive (or CD-ROM drive connector that is unused) and turn on the PC.
    2. You can also unplug a drive connector and use it. Turn on the PC and insert the BLACK probe into the power connector on one of the BLACK wires. Touch the RED probe to the YELLOW wire on the power connector.
    3. The multimeter reading should be +12 volts. Now touch the RED probe to the RED wire and the reading should be +5 volts. If no readings or different readings occurred, you’ll have to replace the power supply. If the readings were correct, you should check the P8 or P9 connectors at the motherboard. These connectors may also be named P4 and P5. To check these connectors, perform the following:
      • Insert the BLACK probe into P8 at one of the BLACK wires. Insert the RED probe into the P8 connector at the RED wire. The reading on the multimeter should be +5 volts.
      • Check the power going to the motherboard connections by inserting the RED probe into P8 at the YELLOW wire and you should get +12 volts. Leave the BLACK wire touching the BLACK wire at the P8 connector. Check the BLUE wire and the reading should be a -12 volts.
      • Now move the BLACK probe to the BLACK wire on the P9 connector. Test the WHITE wire by inserting the RED probe and the reading should be -5 volts. Check the RED wires on the P9 connector and you should get +5 volts on each red wire. You won’t get exactly 5 or 12 volts, but the readings will be very close, such as 5.02 volts.
      • If the Power Supply is a couple of volts off in either direction, such as when the RED wire should be reading -5 volts but it reads -8 volts, or if there are no readings, replace the power supply.
    I will do that shortly. In the meantime, however, I have onther symptom. When I unplug P2 from the MB and plug the power cord into the PSU, the fans on the PSU run continuously. Whe P2 is plugged in and I plug the power cord in, the PSU clicks, all the fans spin. The PSU immediately clicks again and all activity stops.
    You directions say to turn on the computer to chech the voltage. The problem is that the computer won't turn on.
  • Waqar Hassan
    Unplug P2 and then check....
    I checked the Bay 1 connector because it has both 12vdc and 5vdc. The 12vdc reads about 15vdc and the 5vdc reads about 12vdc.
  • Waqar Hassan
    Waqar Hassan Aug 02, 2010
    The PSU is giving excess voltage... i-e It is malfunctioning.... I would suggest you to replace the PSU and then check... (Please Do keep in mind, that over voltage might had damaged the Main board components....).
Hi, I have a dell xps product red, was working well, shut down last evening and now when i press the power on there is no noise of any sort and the only light which illuminates is the monitor screen light....
Check that the power cord is plugged into the wall and the computer. If you're using a power strip, double check that it is plugged into the wall, and turned on as well.
If you still get no response from the machine, open the case and look for spinning fans or lights from the motherboard when you press the power button. Generally, a bad power supply is going to still allow your power button to blink amber warning, as a pass through from the power cord.
Nov 14, 2012 | Dell XPS One Red Desktop Computer
Lamp will not come on. Press power button, fan
You might not be getting power from the ballast, it may be gone.The ballast is what gives the lamp it's major charge of high power.
Oct 24, 2009 | Sony CPJ D500 Multimedia Projector
Dell XPS400 No Start!!
If you fan isn't turning like it should, it is definitely a power supply issue. Go out and purchase a power supply with 250-300 watts...thats a good standard wattage!!
May 12, 2009 | Dell XPS 200 PC Desktop
Black screen Dell laptop xps vista
the symptom more or less feels like there is a video driver problem on the laptop. I would like you to shut down the sytem ,disconnect the Ac adapter and remove the battery from the system. press the power button for 10 seconds .
Reinsert the battery and connect the Ac adapter.
Press the Fn + Power button , to run the diagnostics.
Do post back if you see colored lines on the screen ..so that i can give you more help
Thanks
proton
Apr 05, 2009 | Dell XPS M1210 Notebook
Dell XPS 600 turns itself on to solid amber
Hi. the mother board seems to be having some initialization issues during boot up. this is common when the mother board is failing. i would check to make sure the battery on this board is working. if it is, the board my be ruined.
power board seems to be fine.
please rate and god bless.
Mar 17, 2009 | Dell XPS 600 PC Desktop
Dell XPS M140 laptop shuts off after powering on
Most laptops that I have worked on that power off that quickly turned out to be an overheating problem. Is the cooling fan running for the brief period that you can hear the hard drive before it powers off ? If the fan is running another potential resolution might be to remove the processor and apply new thermal paste.
Nov 10, 2008 | Dell Inspiron XPS M140 Notebook
Fujitsu Plasmavision PDS-4233
HI, I haHe a Fujitsu Plasma HDTV Model PDS4233. The TV won't power ON, When i turn on the master power button the light starts flashing a red light repeatedly. I also observed that the Fans power up for about three seconds immediatly after i press the master power button, after the three seconds the fans shut OFF and the light continues to blink.. I haven't observed the light to see if there is a pattern with the blinking..
Aug 30, 2008 | Fujitsu Televison & Video
XPS 600 serious Boot up Problems!
sounds to me like the fan is on the way out ,and if the cpu gets too hot the pc will shut down.
check that the fan is not obstructed,clean it if it is full of dust, replace it if it is not working as it should.
also listen to the power supply fan, is it working ok,this could cause the same type of problem but for different reasons.
good luck
Terry
Mar 11, 2008 | Dell XPS™ 600 PC Desktop
try pressing and holding the enter button on the projector for about 30 seconds - this resets it. It worked for me!!
Feb 10, 2008 | NEC VT460 Multimedia Projector
Dell XPS™ 600 PC Desktop Logo
75 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
