Question about Samsung Refrigerators
Samsung Model RS265LA..freezer is fine..refrigerator not cooling properly..have unplugged for 9 minutes several times to reset..STILL not working properly..57 degrees is as low as it will go..WHAT TO DO?
catriver
  • 878 Answers
SOURCE: Refrigerator won't cool. Freezer works fine!
Pierce, there was a service bullitin put out on this model. TDR-0010A-B. Had to do with normal freezer, warm fresh food compartment. Maytag issued a kit that included a new thermostat and damper assy. to solve this problem. Bullitin came out in 2002. If you are not having a defrost issue and all fans are running normal, I would call Maytag and inquire about the above posted bullitin, It may be covered. Catriver...post back.
Posted on Sep 04, 2006
  • 51 Answers
SOURCE: norcold rv refrigerator freezer
Make sure the thermister is attached firmly to the fins in the back. The boards on a Norcold can be reset a service center familiar with this process is your best bet. It takes disconecting the board and then shorting it out best to leave it to some one who is familiar.
Posted on Sep 08, 2008
SOURCE: Profile refrigerator section not cooling
We are not sure what precipitated the temperature swing up; however, within about an hour of emptying quite a lot of foodstuffs from top and bottom sections of the unit, I felt the cold air start to flow out of the rear vent. Within two hours, the upper section had dropped to about 50 degrees and by the next morning to 36. The freezer seemed to recoved on its own too, having risen to almost 8 degrees and then recovering to 0. Just patience and a smaller food payload?
Posted on Oct 02, 2008
tborn6
  • 700 Answers
SOURCE: samsung rs2533sw fridge not cooling
it sounds like the refrigerator evap is frozen up causing the compartment to get too hot. shut the unit off and let it thaw out. then take the screws out of the cover to check the stryrofoam on the back side of the cover to see if theres broken spots on it causing the air to bypass the evap causing it to freeze. Theres two screws behind the light cover and two at the very bottom of the cover and two behind the decorative plugs about 1/2 way
Posted on Dec 22, 2008
  • 25 Answers
SOURCE: refrigerator not cooling properly
evap. coil could possible be frosting up due to a defrost problem, this would keep the evap. fan from blowing air into ref. section. it also could be a bad evap. fan motor or it could be that the ref. inside light bulb could be staying on due to a bad light switch ,you would be surprisedhow much heat a 40 watt bulb produces
Posted on May 07, 2009
Back of freezer has frost and freezer wont cool to proper temp. icemaker etc also not working
Did you leave the freezer door open for a period of time while the refrigerator was running? Unplug and defrost the freezer manually with a hair dryer until all frost is removed inside and in back of the freezer. Reapply power and see if it will then cool/freeze properly. Let me know the results
APPLIANCE 911
Jan 10, 2016 | Samsung RH29H9000SR RH29H9000SR 36"...
Fridge won't cool past 57 degrees
Guessing ether a fan, damper our defrost issue. Sorry cant be much help.
Aug 19, 2012 | Samsung RF266ABRS Bottom Freezer...
Frige temp went up to 62 and won't come back down to 40. Try resetting and unplugging several times. Suggestions?
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 25, 2010 | Samsung RS267LBBP 26.1 Cu. Ft. Side by...
Hello! The power went out in my home today for about 8 hours. When the power came back on, my fridge [Samsung side by side (model#RS265LA)] came back on but did not reset properly. The freezer freezes...
if the fridge turns off and the two upper lights blink. you need to reset by holding the two two buttons down for several seconds until it resets if that doesnt work... open your refrigerator door look where the temp setting controll is. if you look under the temp setting a lot of refrigerators will have a hole you really have to look for it its about the size of a dime and inside there you can see the defrost timer. some of them have an extruding peice of plastic you can turn you have to stick a flathead screw driver to reach it but turn it until the compressor kicks on. if you make a full rotation and nothing happens you need to start the diagnoses. if your familiar with and own an electrical meter i can tell you how to do this also Check the breaker first, and then there could be a relay switch on the refrigerator that was blown by the power surge. Most of the time, they recommend that you unplug the refrig whenever the power goes off, and then DO NOT open the door unless absolutely necessary. I'd go to the breaker box, find the one for the refrigerator, and then turn it off and back on after a few seconds. If that doesn't work, call a repairman and get them to check the relay switch. regards Iversh
Feb 12, 2010 | Refrigerators
Model rs2533sw panel not reseting after being unplugged
I had the same problem (panel would not start up - just flashed one dash after a power outage).
The solution above: pressing the top two buttons for 12 seconds (Power Freeze and Power Cool buttons) reset the panel and everything is working fine now.
Thank You!
Dec 24, 2008 | Samsung RM255LASH Side by Side...
Samsung rs2533sw fridge not cooling
Dec 20, 2008 | Samsung RS2534 Side by Side Refrigerator
Samsung RS2545SH Refrigerator
Diagnostic mode will say what any electronic issues are. Check to see if there is, if any, frost build up on the rear panel or ports. If the unit had made any noise in the refrigerator. This unit may have a switching valve for the twin cool, so it could be an issue there.
Dec 02, 2017 | Refrigerators
My Samsung refrigerator will not cool
Call Samsung. I had the same problem when Best Buy delivered mine. The delivery people left the fridge in demo mode. The people at Samsung will talk you through it, it is very simple. The fridge should work fine then.
Jun 22, 2008 | Samsung RF265AA Bottom Freezer French Door...
Refrigerators Logo
121 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
