Question about Sharp 32C-240 32" TV
I have an older Sharp TV. The color of the screen all of a sudden has darkened some. Is there a way on the tv to lighten the screen? Thank you!
    Problem Solver:
  • 5 Answers
This problem can result from the aging of various components within your set, in general with older TVs, particularly sets of 15 years or older for example tend to suffer from capacitors that degrade - effectively reducing the maximum level of picture illumination available. Another issue for old sets that have been used extensively is that of the picture tube's electron gun aging, over time the gun produces fewer electrons to fire at the phosphor coating hence causing less "glow" - this can be sometimes improved by adjustments to the tube. All in all the set may require a decent service to ***** what aged components need replacing. Some later TVs do have a trimpot on the flyback transformer to allow the tube's brightness to be increased, but most older sets lacked this feature. SHARP did have this feature on many of it's 90s TVs but it needs to be adjusted with care by suitable techs due to the dangerous voltages present.
Hope this info is of some help, Regards.
Posted on Aug 15, 2010
Recently I turned on my TV and I have vertical white area with some lines that are colored on the left side of the screen. The rest of the screen looks fine.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Oct 04, 2015 | Sharp Televison & Video
How may I fix colorful vertical lines on screen but clear voice on Sharp Aquos TV when I first turn it on?
T'Con board fault. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Aug 13, 2015 | Sharp Aquos Televison & Video
Panasonic dmp-bdt220 causes the screen to darken and lighten
It sounds like you have the unit's analog video outputs connected to a TV/Video combo or some time of a recording device. Going through a recording device can cause the image to brighten and darken.
Mar 04, 2014 | Panasonic DMP-BDT220 3D Blu-ray DVD TV
Our Sony Tv RMyD003 screen is darker than we would like and we need to brighten the picture. We are unable to locate our Manuel and would need your help. Thank you
Try going to your menu or input select and you should see a scale to darken or lighten input. The remote should have a button on it to let you get to main menu.
Aug 11, 2013 | Sony RMyD003 Remote Control
Why did my tv picture sudenly darken
The inverter has failed if you still have audio but the screen is black. You can get the inverter from www.tvrepairworld.com
Mar 18, 2013 | LG 42LC2D 42 in. LCD HDTV
Model CS-3515R, has buzzing noise, screen darkens, then noise stops\r\nand screen lightens up, then repeats about every 15 minutes.
There is some short in the inside circuit of your TV. Horizontal output transistor may be leakey. Replace it with a new one of same type and number. If it doesn't rectify the problem, LOT should be replaced.
Oct 16, 2010 | Mitsubishi Televison & Video
I have a Ti-89 and my screen is really dark all of a sudden. I cant figure out how to lighten it! I can read it, but only if i turn it just right and look at it up close. How can i lighten it?
Lighten the screen by holding down the green diamond key and then holding down the - key. If you go too far, use the + key instead of the - to darken the screen.
Sep 17, 2010 | Texas Instruments Office Equipment &...
To whom it may concern, The screen is very dark. How can I fix it? Also, how can I change the brightness? thank you for your time!
To adjust the screen contrast (to lighten screen or to darken it)
  1. Press the [2nd] key and RELEASE it.
  2. Press and HOLD the UP Arrow to darken screen, or
  3. Press and HOLD the DOWN Arrow to lighten it.
Keep pressing the UP or Down arrows (whichever you need to press) until the screen contrast is adequate.
In your case, the screen is too dark, so you must press the DOWN arrow to lighten it.
Aug 12, 2010 | Texas Instruments TI-83 Plus Calculator
Screen darkness
Just fixed mine.Remove the back of the TV on my model there in a small pwer supply turn the bottom of the two pots this will darken or lighten the screen. Fine tune with the settings on the remote
Jul 04, 2008 | Televison & Video
Sharp 32C-240 32" TV Logo
97 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
