Question about Kenmore Elite 45986 Front Load Washer
F35 code showing up on my machine - Kenmore Elite 45986 Front Load Washer
    President:
  • 1,554 Answers
There is a steamer component, particularly the analog pressure sensor, malfunction detected by the Steamer Electronic Board as indicated by the fault code F35. Check to make sure that the pressure hose and air trap are not blocked and the pressure hose is connected properly. Also check the wire harness connections and ensure that hey are snug fit, not corroded, and fully inserted.
Remove the top panel to access and check air trap and the pressure hose connection. Remove the screws attaching the top panel to the rear of the machine then slide the panel rearward and off the cabinet.
Feel free to update us about the development of the troubleshooting and repair. You don't have to accept or reject and rate this post to add information or post comments and follow-up questions. Accepting a solution does not stop you from communicating with an expert. You can continue communicating with the expert as long as you need assistance regarding the issue stated
herein.
Posted on Aug 01, 2010
I have a Kenmore Elite Washer for over a year and is getting a F35 error code, then the SuD flashing. Cleaned out the soap container & inspected the inside (as stated on page 21 of "Washer...
F35 is a water level error.
The water level switch (pressure switch) has malfunctioned.
If you remove the top panel, three screws in the back, you will have access to the pressure switch.
With the tub empty, remove the vinyl hose from the switch and blow backwards through the hose to clear any restrictions.
If the fault codes return after doing this, you will likely need to replace the pressure switch.
Also - please be sure to use He soap.
Thanks for using FixYa!!
Nov 12, 2010 | Kenmore Elite 45986 Front Load Washer
Kenmore elite he3t stream showing error code sud then f35
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 01, 2010 | Kenmore Elite 45986 Front Load Washer
Code F35
hello
what The F35 error code indicates that the water temperature sensor reading is out of range (below 23 degrees F or above 217 degrees F)
The f35 error shows you and indication that ice maker sensor readings are out of normal range.
then what you need to do to fix up the problem is to bale out the water from it then clean up all form of water ant dry you can see from the screen
Please before you can carry out this instruction you will have to put OFF all source of power supply .
thank you and good luck.
Jun 03, 2010 | Whirlpool Duet GHW9150P Front Load Washer
WHAT DOES F35 CODE MEAN
F35 is the pressure switch which is located under the top panel on the back right. It may be faulty or have loose connections.
Apr 19, 2010 | Kenmore Elite 45986 Front Load Washer
Machine stopped with code of F35
F34, F35 and F36 are fusing errors.
To unlock:
- Turn off machine
- Turn it on while pressing keys 2 and 5 simultaneously
- On the menu that shows up, press 1st option "Software SW"
- Using the up and down keys, navigate to switch 3-1
- Press OFF
- Cycle machine power
Don't mess with anything else or you'll risk more trouble than you're having right now.
If the error comes up again, you have something wrong with your fusing unit. Check it.
Mar 06, 2010 | Washing Machines
Kenmore Elite front load washer stops and blinks F35 and locks up
f35 code indicates a pressure switch problem. Try unplugging unit for 2 minutes.Plug back in and test.If F35 reappears,check hose from tub to pressure switch
Nov 04, 2009 | Kenmore Elite 45986 Front Load Washer
HE5t washing machine flashes F35
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!
Jul 27, 2009 | Kenmore Washing Machines
Whirlpool Duet Steam washer
HELLO.F35 IS A ERROR CODE WHICH NEEDS THE ASSISTANCE OF A WHILPOOL SERVICE AGENT.THE CONTROL BOARD MIGHT NEED TO BE REPROGRAMED BEFOR YOU CONSIDER REPLACING IT.GOODLUCK.MOHAMED
Sep 15, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Error code f35-3 on konica minolta 7145 copier
How to reset failure codes (F34, F35, F36). To reset failure codes, perform the following: 1. Enter the 25 mode (turn the machine ON, while pressing the 2 and 5 keys). 2. Select [1. software SW settings]. 3. Using the arrows on the left of the touchscreen scroll to DIP SW 3. 4. Using the middle arrows scroll to BIT 1. 5. On the touchscreen select OFF (0). 6. Power the copier OFF/ON.
Mar 04, 2008 | Office Equipment & Supplies
Kenmore Elite 45986 Front Load Washer Logo
19 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
