Question about Lakewood HV 18-c Floor / Box Fan
Fan doesn't work. it's dead - Lakewood HV 18-c Floor / Box Fan
    Guru:
  • 1,051 Answers
If it's dead, It'll be cheaper to replace it with a new one than try and repair it.
Posted on Aug 01, 2010
Engine doesn't crank over, blown fuses and certain things not working?
sound like dead battery.no power to fuses if battery dead use digital voltmeter check battery volts should 12.6 volts if not have battery charged tested.if battery 4 or 5 years old battery could be faulty.
Apr 29, 2013 | 2010 Mitsubishi Lancer
Gateway 500C: Dead. green PSU lite doesn't lite when pressing test switch
Obviously your Power Supply Unit is dead. You just have to replace it.
Feb 17, 2013 | Gateway Computers & Internet
My Maytag MFF2558VEM Bottom Freezer French Door Refrigerator doesn't keep cool
What you should be looking for is a blocked air flow. The fan in the freezer will push air up to the fridge and cool it off. Look for a dead fan motor in the freezer or a blocked air vent Good luck
Sep 08, 2012 | Maytag MFF2558VEM Bottom Freezer French...
The fan on my 2004 Grand Prix quit working 2 weeks ago. Checked fuses and that doesn't seem to be the problem. Any ideas?
if its the cooling fan at the rad then your talking about then if you disconnect the plug on the fan and run jumper wires to it directly from the battery it should run.also check the plug connection to make sure its in good condition and no corrosion.if you jump the fan motor and it doesn`t run tap the motor it should run either way if it doesn`t then the cooling fan motor needs replacing.
Nov 03, 2011 | 2004 Pontiac Grand Prix
My fan doesn't work nor does the motor make a sound.
Need help with a fun like to bypass the which
Sep 24, 2011 | WeatherWorks CH-1640SF Fan
Hi, I just bought an HP ProBook 4520s. It keeps shutting down without warning -- which makes its use very irking. I tried to restore the hard disk to the factory settings. After, it doesn't boot...
hello. (the fan turns on, then off , that it?)
a PC that self turns off, is power overloaded. tell what the fan does heck even clean it .
NO OS stated, why post lacking that.? xp, w7/8/10????? vista?
NO method for restore stated, must we guess? what MEDIA"?
  1. hammered the F11 key for HP magic recovery(best)
  2. used the HP recover disks with HP logos on top. ????
  3. used Microsoft disk (bad bad idea, unless you want to find all those missing HP drivers and put them all back as 1,2, does above. for free. ask we can find them see last link ....
so what does shutting down mean.?
just windows (unstated) bad, locks up or goes BSOD.
or does it mean the PC turns its self 100% off, silent fan silent HDD? dead silent from fan ok and hdd sounds ok.
if it really turns off, then take out that huge battery there.
they short, get it out of there first, run on AC pack forever. you can. so this is always first, and only takes, 4 minutes work.
Does it run now,(btw , power loss has 10 to 20 causes not 1)
we sometimes have to strip a system to find what shorted.
things in the real world can short, many things. in fact.
NEXT:
then do the long reset posted on HP real site 1,000,000 times. there. endlessly.
with main battery out, ac pack pulled.(both)
push power button for 10 to 30 seconds. this resets sleep modes ,etc.
put back only AC pack ONLY, does it turn on now and say on , does the fan work the fan must work and not be packed in lint.
ok if it stay on (fan /hdd sounds) then we do BIOS NEXT.
PCs boot in a serial order , in fact.
does the F10 ey works as it prompt you for 7 years
do you get text? ever?
power on, see text do as it states, "hit F10 to enter hp setup"
means to hammer F10 to enter bios. do so now.
F10 is BIOS page entry command,
this screen is LED so the back lamps never fail, like earlier owns do.
leaving what, next, if no text or BIOS acts up, or BIOS time and date are wrong, then RTC CMOS coin cell is dead. new one. now.
Coins fail at 7 years on average. a cheap and easy fix.
when the coin goes dead, BIOS goes dead with it (goes mad)
if that is ok and just the HDD will not boot,. then try F11 magic key.
F11 is full recovery to day one stated, HP OS, (unstated) and all HP magic driver are renewed, this is the correct way.
if the HDD has been slammed, F11 will be dead now. for ever.
if F11 is dead, we then test the HDD.
all in this order.
your PC is 2010, like mine, so 7 years old is on the cusp of
coin cell bad,(but usually are ok now, if lucky like my 3 are)
full support page is here.
the real support page at HP,. Fixya is not HP ,not now or ever.
https://support.hp.com/us-en/product/hp-probook-4520s-notebook-pc/4145198/manuals
how to test a HDD, if the motor is silent it is dead. ear to side of drive, dead silent (PC fan running sure) all test here are free.
zero cost. just work.
http://www.pcdied.com/brick-dead.html
so the power button is pushed the fan turns on right>?
then goes dead silent,? surely you can tell what fan does , sounds and if text ever lands on the LED screen there.
most un-serviced PC, pack up lint like this.
like this, doom happens like this every time not kept clean.
all do it.
http://www.pcdied.com/Filth101/html/image_9.html
Dec 11, 2017 | HEWLETT-PACKARD ProBook 4520s
Panasonic logo comes on for 7-8 seconds then shus off.
This is most likely a fan issue. Remove both covers (there are 2), so that the PCB is exposed. Using compressed air (ideally from a compressor, not from a can), blow all of the dust out of the unit, especially near the fans (there are 4 of them). If this doesn't work, you may have a dead fan. PacParts sells replacements.
Jul 23, 2011 | Panasonic PT-AE3000U LCD Projector
Tried changing keyboards , different usb ports, tried to restart totaly dead now, had to jump,running[fans only] lights on 2&3,still says keyboard failure. Time of day clock stopped . Invalid...
REPLACE THE LITHIUM BATTERY ON THE MOTHER BOARD IF THAT DOESN'T HELP LOOK AT THE FAN IN THE BACK OF THE POWER SUPPLY TO SEE IF THE FAN IS SPINNING IF NOT YOU WILL HAVE TO REPLACE IT
Jun 25, 2011 | Dell Dimension E310 PC Desktop
Heater fan doesn,t work
if you are getting power at the fan plug, it is possible that the recycled motor is bad.
Feb 04, 2009 | 1994 Cadillac DeVille
Lakewood HV 18-c Floor / Box Fan Logo
116 people viewed this question
Top Lakewood Dryers Experts
Craig Butler
Craig Butler
Jay Finke
Jay Finke
Are you a Lakewood Dryer Expert? Answer questions, earn points and help others
