Question about Dryers
I am looking for where to find the fuses for this Kenmore Electric Dryer. Can you help?
    President:
  • 2,468 Answers
Which fuses?the electronic control board fuse or the main power fuses,the electronic fuse is on the control panel behind the front,the main fuses that heat the dryer are in your homes power panel
Posted on Aug 01, 2010
SOURCE: Kenmore dryer (electric )
NOT ELITE HE4..... Model 96595400. Replaced thermistor and Hi-Limit Stat. Probably the thermistor.
Posted on Jun 29, 2008
  • 147 Answers
SOURCE: Kenmore Ultra Care Dryer- Electric
Your dryer doesnt have a fuse. Your home breaker panel is the only protection it has..Check your circuit breaker box for a tripped breaker.
Posted on Oct 22, 2008
vickygomar
  • 460 Answers
SOURCE: Kenmore electric dryer Mod. 100.66662501, type
Assuming that the fuses you speak of are the external pair, and not the internal motor or timer resets:
Check the fuse holder for corrosion on the plates. Often the fuse is not properly seated because of this build-up and therefore has an intermittent connection. This will cause the fuse to either heat up, or overload; ultimately failing.
To remedy this, turn OFF the breaker, or main switch if necessary, and fix a wooden dowel with a piece of emery cloth (or sand paper) on the end. Remove any visible black corrosion from the contact plates.
Finish with a spray of WD40 to protect the plates and fuse end.
Replace the fuse, ensuring that it's tight, reinstate power and try again.
Was this  helpful?
Posted on May 13, 2009
blueextc3221
  • 15935 Answers
SOURCE: kenmore electric dryer model 68702894 turns but no
The heater element may have failed - however, first check the Thermal limit fuse on the rear of the machine (silver disc held by 2 screws). Check for continuity.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Mar 05, 2010
SOURCE: my kenmore 400 electric dryer stopped working. im
The fuse is white about 1/2 inch wide and 1 1/2 inch long.. we think.. not a normal looking fuse. There is one screw holding it on, and you kind of have to slide it up and out.
Posted on Jun 29, 2010
Why won't it start?
Free Kenmore Clothes Dryer User Manuals ' ManualsOnline ...
laundry.manualsonline.com > ... > Laundry Appliance Kenmore
Products 1 - 50 of 65 - Kenmore ELITE HE3 Gas Dryer User's Guide 110.9787 9789. Pages: 0 ... Kenmore 27-Inch Wide Electric Dryer Owners Manual. Pages: 0 ...
Whirlpool & Kenmore Dryer Repair #02 - Won't Start or Run ...? 7:29https://www.youtube.com/watch?v=SPRqKVE8JfYOct 21, 2011 - Uploaded by canyonman1963... and repair a Whirlpool or Kenmore electric dryer that will not start or run. ..... I have a Kenmore Elite Oasis ST Dryer, model number 110.78082701. During ... Dryer Troubleshooting - NotDrying or Taking a Long Time to Dry ...How to take apart Kenmore Elite Dryer - YouTube? 6:28https://www.youtube.com/watch?v=QNa6zfzrm5kOct 16, 2012 - Uploaded by RenewApplianceI have a kenmore elite 79661423410 electric dryer stoppedworking manual says has no thermal fuse and I can't take it apart help thank you.
Dec 12, 2015 | Kenmore HE5 Electric Dryer
Kenmore 90 Series electric clothes dryer thermostat fuse had no continuity. Replaced the two fuses the parts place sold us. Turned it on after repairing, did heat up but then blew out the same thermostat...
I would say a venting issue, here is a thread, hope it helps Tim:
http://forum.appliancepartspros.com/dryer-repair/19493-dryer-blowing-thermal-fuses.html
Dec 23, 2010 | Kenmore 659 Electric Dryer
Hello, I think the fuse has blown in my series 80, Kenmore electric dryer. Can you please tell me what it looks like and the location of it. Thank you.
It's a thermal fuse and it is white plastic about an inch and a half long. has 2 wires going to it,usually lt.blue, If you remove the back panel of the dryer it is located near the dryer exhaust above the high limit thermostat.
If the thermal fuse is blown the dryer will not run.
Hope this helps.
Dec 11, 2010 | Kenmore 62802 Electric Dryer
Kenmore electric dryer (model # 110 60202990) dried a load of clothes like normal. But with the current load, it suddenly stopped heating. How can I fix this?
Hello Friend, Your problem is very simple to fix. You need a thermal fuse, very simple and affordable to replace. To replace the thermal fuse just remove back cover of dryer and look down where the air blows out. Now, just to the left where all the wires are you will see a white plastic part with two wires plugged into it. This part is called a thermal fuse. Just remove these wires and replace the thermal fuse. Your dryer will run like new. Happy to help, Tim.
Jun 12, 2009 | Kenmore 64742 Electric Dryer
My 2006 Kenmore electric dryer stopped running. We checked the plug and the breakers and don't see the problem. The codes on it are DWJR-ELE-2406028-FM54; 110.66652500. We can't find the owners manual. Any...
if you take the back off of your dryer and look for a little white thermo fuse with 2 wires on it if you unhook the wires and plug them together than start the dryer if it starts shut it off and replace the fuse and clean your venting
Mar 01, 2009 | Kenmore 659 Electric Dryer
Kenmore series 90 no heat
Check the glow ignitor on the right side of the dryer if you are looking at the front on the bottom side and make sure that it is not cracked
Feb 09, 2009 | Kenmore Elite HE4 Electric Dryer
Location of the thermal fuse on the kenmore gas dryer 80
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Feb 03, 2009 | Dryers
Oct 22, 2008 | Kenmore 62602 Electric Dryer
Doesn't start
Try this link and see if this helps you diagnose your problem. Please don't hesitate to contact me if you require further assistance.
http://www.fixya.com/support/r385301-thorough_dryer_advice
I hope this helps you isolate your problem. Let me know if you need assistance in locating parts too.
May 28, 2008 | Kenmore 62602 Electric Dryer
Dryers Logo
Top Dryers Experts
Marvin
Marvin
