Question about Maytag Dryers
Model pye2000ayw my dryer will not turn on. the timer seems to tick, which indicates there i s power (i assume), and when i press the timer knob to start the machine, it does not start.
    President:
  • 2,468 Answers
Make sure first that you have 240 volts to the machine from the house power panel, if so,then it could be a drum belt broken the dryer motor isnt turning or the dryer drum idler tensioner pulley is bad or the belt is off the pulley on either the motor or idler,you need to remove the top and front covers to examine this
Posted on Aug 01, 2010
Timer does not tick and dryer does not reverse direction
The timer not moving is a sure sign it needs replaced. Fortunately replacing it is easy. Just search for your make and model dryer and order the timer. Remove the power, the back panel with the timer, the knob on the timer, and just a couple of screws and it's out. One by one move wires from old timer to new, install the reverse as taking it out. Put the knob back on, and the back panel. Plug it in, and you should be golden.
Ah, I just saw you answered in your own question! Good job! :-)
Anytime the drum turns, with or without heat, and the timer makes noises, doesn't move, has to be wiggled to start, or the start position changed, you can bet it's the timer. We just don't want to take a risk because it's one of the most expensive parts to replace, usually the motor costs a bit more, but seldom go out. Don't waste time troubleshooting other parts if any of the above applies, it's usually the timer.
Aug 30, 2015 | Dryers
The dryer model # PYE3300AYW The dryer has power but will not turn on when the timer/start knob is pushed. You can hear the timer ticking, but nothing else happens. What are the possible causes for this?...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Apr 20, 2011 | Maytag Dryers
I have a broken wash cycle timer knob on my whirlpool LTE5243BN0 thin twin washer/dryer. Ordered a replacement part, looks the same as my old one, threads okay, can't seem to screw it all the way on. The...
you might have broken something else off of the timer go here
https://www.repairclinic.com/PartDetail/Timer/WP3946432/4434024
is the white part still on timer shaft?this is the piece that the indicator knob slides onto so it's not loose and free spinning,i looked up your model and the indicator knob is no longer available
www.searspartsdirect.com/model-number/LTE5243BN0/1198/0152000.html?searchType=modelSearch&q=LTE5243BN0&searchTerm=LTE5243BN0
go here and you can see your machine
Oct 01, 2017 | Whirlpool LTE5243D Top Load Stacked...
Maytag dryer Model MDE3000AYA intermittently won't start. Interior light does illuminate when door is open. Normally when the timer knob is set a soft audible ticking sound is heard. When the dryer...
could have a bad timer,when it stalls try tapping on the timer or wiggling the knob to see if it will start,there's a little motor on the timer that you hear ticking and it could fail.
Jul 10, 2017 | Maytag Dryers
Dryer won't come on door is closed timer ticks the
you need to open front panel or top, depends on brand and model...
you will see door switch there, to check you will need electrical meeter, unplug from power before opening it.
check continuity of switch, by pressing/depressing it.
if it's working than check start button switch if your model has it.
appliancesrepairla.com
Jun 29, 2010 | Dryers
Dryer Won't Start
Make sure it has power. Then:Check the door switch. A little lever sticking down through top right of door opening. If it is not there you will need new door switch(sometimes the little lever breaks off). If it is there and does not click when you press it in you need a new door switch. if it clicks when you close the door then you have a bad thermal fuse.The thermal fuse is found by taking the back of the dryer off. The fuse is an oblong white plastic piece with 2 wires attached.
Door switch part number 3406109
Thermal fuse part number 3392519
May 27, 2009 | Kenmore 73952 Gas Dryer
I HAVE A WHIRLPOOL DRYER. TURN THE TIMER SELECT ON. THEN TURN START KNOB TO ON, THEN PRESS THE SAME KNOB IN TO START CYCLE. YOU CAN HERE THE TIMER AND SOUNDS LIKE THE CONTACT IS WORKING, BUT CYCLE WON'T...
Hello dacarle,
Welcome,
You said, I HAVE A WHIRLPOOL DRYER. TURN THE TIMER SELECT ON. THEN TURN START KNOB TO ON, THEN PRESS THE SAME KNOB IN TO START CYCLE. YOU CAN HERE THE TIMER AND SOUNDS LIKE THE CONTACT IS WORKING, BUT CYCLE WON'T START.
Please send me the model number so i can check out the problem.
Waiting your response
Huuum
Oct 15, 2008 | Whirlpool Dryers
Dryer won't start, Simpson Eziloader 4kg
Yes, the knobs don't like to be turned counterclockwise. Spin the knob clockwise to reinstall tightly, then move to set a dry time. Make sure half load button is pressed.
Jan 24, 2008 | Whirlpool GEW9250 Electric Dryer
My Push Start Relay or Control Knob is not starting the Dryer
is this the even heat model? if it is you need a new control board on the back of the timer area and might as well buy a couple relays the black ones with 4 wires in them. one is for the pts and the other is a heater relay both are the same part
Feb 07, 2007 | Kenmore 62622 Electric Dryer
Dryers Logo
Top Maytag Dryers Experts
Tim Whalen
Marvin
Marvin
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
