Question about Hoover SteamVac F5914-900 SpinScrub Upright Vacuum
Model number f 5912-900 hoover steam vav with clean surge.This is not the f5914 model........my new machine has 10 min. on it...in mid use it has stopped sucking and now is blowing more than anything, I took the front clear piece off as well as the black cowling/shroud and can find no obvious hoses to un-clog nor anything else to un-clog for that matter...I am looking for advise to fix this thing now, myself
  • bryansargean Aug 01, 2010
    The extraction tank if finicky if it isnt on just right it wont **** !!!Otherwise cleans great !!
    Guru:
  • 630 Answers
Here is a list to go by for no suction problems that you can follow along with they are common proble Problem #1 Steamvac is not Sucking!
If your Hoover Steamvac was working properly and suddenly it is not sucking any water, nine times out of ten, the culprit is the lid on the lower recovery tank. The lid on the lower tank (or dirty water tank) needs to hinge at the front and snap down at the back in order to creat a proper seal. If the lid snaps on but is not locked on at the front, you will not get any suction. Simply take the lid off, and ensure that when you put it back on, it must hinge on the front tabs of the tank.
Problem #2 – My Steamvac is still not Sucking!
Right now you are thinking that you shouldn’t have let your brother borrow your Steamvac. And you are right, because he used the hose attachment and returned it with the hose still attached to the front of the tank (some models only). Now when you try to use it there isn’t any suction. In this case, you are missing your tank duct. On models where the stair/upholstery hose attaches to the front of the recovery tank, one must remove a square plastic piece in order to attach the hose. This square plastic tank duct must be replaced before the Steamvac will operate properly in the upright position. So call you brother on the phone tell him to find it, or call me at the number at the top of the screen to order one.
Problem # 3 – My Steamvac isn’t sucking very well and the brushes are spinning slowly
Most the likely, the culprit here is under the recovery tank. Standing behind the steamvac with the lower tank off, to the right and front you will notice a round duct opening about 2 inches in diameter. This should have a rubber seal on it. If it is missing, look under the hood of the steamvac it may have fallen forward there. Otherwise, give me a call to get another one.
Problem #4 – My Steamvac brushes are not spinning or are spinning very slowly
Believe it or not they may just need to be cleaned! You can remove the rack of brushes by pinching the tabs on either side and pulling it out. The plastic is clear so you can see if the brushes and gears are gummed up with hair and carpet fibres. Rinsing usually works best. There are two more things to check if this doesn’t solve the problem. First, check that the switch for the brushes is set to high. Second, look under the clear plastic piece near the switch (it is removable). There is a small screen that collects lint and hair (like a dryer screen!). This is the air intake for the turbine that drives the brushes. Clean it off and your back in business.
Problems #5, #6, #7 – My Hoover Steamvac doesn’t turn on, leaks, or is really noisy
Unfortunately, these problems are usually a bit more complicated and need professional service. At Clean Machines we offer a free estimate/repair ceiling service which gives you assurance that repair bills don’t get out of hand. Please visit us at our store at 111 West 2nd Ave in Vancouver for all your Hoover Steamvac carpet shampoo, stain removers, and free tips on cleaning.ms and easy to remedy:
Posted on Aug 01, 2010
How can I get power switch to work on hoover spinscrub steam carpet cleaner?
Replace the switch.
http://www.ereplacementparts.com/hoover-f5914900-steamvac-with-clean-surge-parts-c-37315_37419_37425.html
Aug 28, 2014 | Hoover SteamVac F5914-900 SpinScrub...
I just bought a hoover steam vac model F5914900 and the clean water tank is leaking. I tried pressing the clean surge button and the trigger button that was suggested by someone else but it won't
Go to Hoover.com and find a local Service Station. They will replace it at no charge. MUST be a warranty location to get it free. Take your sales slip with you.
Jul 28, 2012 | Hoover SteamVac F5914-900 SpinScrub...
Manual for Hoover Steam VAc model #6040-900
need manual for steam vac dual V model:F7206-900 series:Z12.0
Jul 13, 2011 | Hoover SteamVac F5914-900 SpinScrub...
Can't find info for hoover steam vac spin scrub model # F5905900 on Hoover website, doesn't show that model number at all...looking for mesh (kind of cone/cylinder shape) that goes in dirty water tank (I...
The cleanout tool is part # 43514001. The filter is # 90001398. Be sure to leave a 1/2 inch gap between the top of the filter and the bottom of the lid. If you need a manual, try model F5914-900 0r F5912-900 on Hoover.com
Mar 18, 2011 | Hoover SteamVac F5914-900 SpinScrub...
Steam vac won't **** water
check to see if the recovery tank lid is on correctly. if this is not on, the machine will not **** up the dirty water from the carpet. all you will get is suction that is chopy when it comes up instead of more like a flow.
Jul 31, 2009 | Hoover SteamVac F5914-900 SpinScrub...
#for hoover steam vav ve with rinse
Here is a link http://www.hoover.com/pdfs/manuals/F7220900.pdf
Or go to hoover.com, scroll down and on the left click on downloads, enter your model number and a pdf. file will come up that you can download.
Jun 10, 2008 | Hoover F7220900 SteamVac V2 Upright Vacuum
Hoover steam vac spin scrub
http://geeksquad.fixya.com/ThreadView.aspx?prdid=40488&thid=640907
Posted by mid-nite on Jun 02, 2008
My aunt lost the instructions to her steam vac, and she never got the chance to read them. Do you know how to operate it?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Hoover SteamVac F5914-900 Spin Scrub Upright. The best thing to get an owners manual is to download the owner’s manual from the Hoover website or to call your local vac dealer or to call the Hoover Factory / Manufacturer to have them send you out in the mail a new owner’s manual for the model you have listed above . the phone 3 are listed below:
. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
http://www.a-1vacuum.com/ 1-800-657-1874 Customer Service
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 02, 2008 | Hoover SteamVac F5914-900 SpinScrub...
When squeezing trigger and Depressing Clean surge Button on Upper handle of the Hooover Steam Cleaner F5914-900 there is no "snap" indicating trigger rod is in place. Everything else went in as...
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=552215
Generic problem for all Vacuums
Posted by lnikol6 on Apr 28, 2008
Hoover Steam Cleaner F5914-900
When squeezing trigger and Depressing Clean surge Button on Upper handle of the Hoover Steam Cleaner F5914-900 there is no & quot; snap& quot;
indicating trigger rod is in place. Everything else went in as instructed. The screws and bolts were no problem
this concerns me because the main complaint I read about this model was leaking from the trigger and clean surge and the problem was not getting the rod in place. No matter how many tries or people (three) it still doesn't occur.
I would suggest getting a schematic, owners manual or product breakdown to see what you are doing wrong or to check with the Hoover tech support line to see if the can either mail, fax or email the schematic to you so that you can complete your service job. There is something definitely happening with the serv job that we are overlooking and the schematic or product breakdown will help in the serv job you are doing, it sounds to me that you are doing things right but there could be another broken part or while installing the current part may not have been install properly, or is in need of an adjustment. Feel free to contact your local vac dealer or contact the Hoover Tech Line listed below:
8 a.m. - 7 p.m. EST
Don – The Vac Man
Go Ahead. Use Us.
Apr 28, 2008 | Vacuums
Hoover SteamVac F5914-900 SpinScrub Upright Vacuum Logo
129 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
