Question about Tag Heuer Formula 1 CAC111D.BT0705 Wrist Watch
The digital display keeps flashing - Tag Heuer Formula 1 CAC111D.BT0705 Wrist Watch
Try putting duct tape over the led part, but not the rest of the watch. its ugly, but it should work
Posted on Aug 01, 2010
Silicon scientific atomic watch
Should be 4 buttons, 2 on left and 2 on right. Press bottom left 3 times and hour offset digit will be displayed. Press and hold top left until hour offset digit starts to flash. Press either top or bottom right to adjust offset hour to correspond with your time zone. Eastern -5, central -6, mountain -7, pacific -8. These are negative numbers, not positive. Then press top left button once, then press bottom left button to return to time display.
Jul 31, 2016 | ATOMIC Watches
Watch Problems
PROVIDE US HERE THE WATCH MODEL..
AND ALSO PROVIDE A DETAILED PICTURE IF POSSIBLE...
Sep 17, 2008 | Watches
How to set time on Casio 550 pro trek. I can't get it to set for daylight savings time.
According to Casio, in the time keeping mode hold the E until each of the following steps occur. hold SET appears in digital display>HT flashes. Second hand points to the current home city code. Set 2: Use A to select the city code you want to select as your home city. Each press of A moves the second hand clockwise. keep pressing A until it lands on the city code you need. Select your home city code before changing any other setting. Step 3: Press D to cycle through the available settings on the digital display. When the time keeping setting you want to change is displayed, you A ad or C to change it. Step 5: Press E to exit the screen, the hands of the watch will move to the time you set. Any other information or diagram is listed on the website Casiowatchparts.com
Mar 13, 2016 | Casio Watches
I have a tag kirium. i have recently changed the battery but i have noticed that the hand movements keep stopping and the back light flashes on and off. the digital display still keeps time ok but if i go...
If it's genuine, that's a very expensive watch.
Why risk problems by changing the battery yourself? Take it to a TAG dealer, and get them to do it. Sure, it'll cost you more than DIY but then you wouldn't have the problem you have now.
Oct 15, 2017 | Watches
Please can u show me how to change the time on this watch.
Set the time on your Baby G by switching to time mode. The button on the bottom left-hand side of the watch is the mode button. Pressing it once to will set the watch to time mode. The time digits will begin to flash.
  • 2Start by adjusting the seconds. Press the button on the top-right side of the watch once. The second digits will start to flash. Press the bottom right-hand button until the correct second time is displayed. Hold down the button to cycle through the digits. Once the correct time is displayed, press the bottom left-hand button and the digits will stop flashing. Press the bottom left-hand button again to set the hours.
  • Sponsored Links
  • 3Follow the same procedure to change the hours setting. Set the time and date by cycling through the digits in the following sequence: seconds, hours, minutes, year, month and date.
  • 4Press the bottom right-hand button to set the seconds to 00. When the second display is between 1 and 29, the digits will change to 00. If the display is between 30 and 59 seconds, the seconds will revert to 00 and one minute will be added to the minutes display.
  • 5Change from an a.m. to a p.m. setting by pressing the button in the middle of the bottom of the watch when any of the time display digits are flashing.
  • Nov 03, 2012 | Watches
    Resendly purshased a casio 4772 watch. diplay time and city. trying to get it set for dst. read manual and cant get button (A) to flash. can u help
    Hi ...
    your watch supports Time Zones , Automatic time Updates, Automatic adjustments of DST.
    First Verify Correct Home City Is Selected
    1. In Time Keeping Mode (That is The Digital Display shows time and Day of week)
    2. Press Button (A) long enough to country code start to flash on digital display.nightflare_4.png
    3. Press Button (B) or Button (D) to change Country code to current one.
    4. After Selecting Desired Country, Press button (A) TWICE.
    Now Country Code will be saved on watch.
    Supported Country codes are:-
    To Activate DST (Daylight Saving Time).
    2. Press Button (A) long enough to Digital Display start to flash.
    3. Press Button (C) TWICE to Display DST Settings.
    4. Press Button (D) repeatly to cycle through three DST Options:-
    A --> DST is set on Automatic Mode. If Your country uses DST, the watch will Adjust DST Accordingly.
    OFF --> DST is set to disabled. No DST is applied to Main Time Settings
    ON --> DST is Set to On. DST is applied even if your country doesnot follow DST.
    5. Press Button (A) TWICE to save Selected Option.
    Default values (Factory Settings) when you bought this watch is
    This way you can set DST
    Mar 13, 2011 | Watches
    Need instructions for my sr927w accurist watch
    QUICKSTART - SET THE TIME
    1. Push the bottom right hand button until the mode hand indicator points to TME.
    2. Press and hold the upper left button for three
    seconds. The hour and minute hand will retract to the 12
    O’clock position.
    3. Select the time zone on the digital display by pressing the
    upper right button or the lower left button.
    4. Pull the bottom right button out one click. The bottom part of
    the digital display will start flashing. Press the
    bottom left button to adjust for daylight saving time.
    5. Press the upper right button. You will see the seconds
    flashing on the lower half of the digital display. Press the lower
    left button to reset the seconds to 00.
    6. Press the upper right button. You will see the minutes
    flashing. Press the lower left button to set the minutes to your
    current time.
    7. Press the upper right button. You will see the hours flashing.
    Press the lower left button to set the hours to your current time.
    8. Press the upper right button. You will see 12H or 24H
    flashing. Press the lower left button to switch between 12 hour
    and 24 hour.
    9. Push the lower right button back in.
    SET THE CALENDAR
    indicator points to CAL.
    2. Press and hold the upper left button for three seconds. The
    hour and minute hand will retract to the 12 O’clock position.
    4. Pull the bottom right button out one click. You will see the
    month flashing on the digital display. Press the lower left button
    to change the month.
    5. Press the upper right button and the date will begin flashing.
    Press the lower left button to change the date.
    6. Press the upper right button. You will see the year flashing.
    Press the lower left button to change the year.
    7. Push the lower right button back in.
    SET THE ALARMS
    indicator points to AL1, AL2 or AL3.
    4. Pull the lower right button out one click. You will see ON or
    OF flashing on the digital display. Press the lower left button to
    turn the alarm on or off.
    5. Press the upper right button. You will see the hours flashing.
    Press the lower left button to change the hour.
    flashing. Press the lower left button to change the minutes.
    SET THE TIMEZONE
    1. Setting the time zones allows you to add or remove cities on
    the digital display or switch between daylight saving and
    standard time. Begin by pressing the lower right button to move
    the mode hand indicator to SET mode on the bottom dial.
    2. If the hour or minute hands are obscuring the digital display,
    press and hold the upper left button for three seconds. This will
    cause the hour and minute hand to retract to the 12 O’clock
    position.
    3. Now pull the lower right button out one click. You will see the
    digital display flashing. Press the upper left button to select
    SET to display the city or OFF to not display the city. Press the
    lower left button to turn summer time on or off. Summer time is
    indicated on the lower part of the digital display. Daylight
    savings time must be manually set for each city.
    4. Pressing the upper right button will allow you to scroll
    through all the cities. After setting, push the lower right button
    back in.
    USING THE TIMER
    1. Press the lower right button to move the mode hand
    indicator to TMR mode on the mode dial.
    position.
    3. Pull the lower right button out one click. You will see the
    minutes flashing in the digital display. Change the minutes by
    pressing the lower left button. Once you have set the minutes
    on the timer, push the lower right button back in.
    4. Pressing the upper right button starts and stops the timer.
    5. Press the lower left button when the timer is stopped to reset
    the timer to its initial preset time.
    USING THE CHRONOGRAPH
    1. To use the chronograph press the lower right button to move
    the mode indicator hand to CHR mode on the mode dial.
    3 .To start or stop the chronograph press the upper right
    button. If you press the lower left button it will display the split
    time for 10 seconds.
    4. When the chronograph is stopped press the lower left button
    to reset back to zero.
    SET THE TIME ZONE
    the mode indicator hand to SET mode on the bottom dial.
    savings time must be manually set for each city..
    through all the cities. After setting, Push the lower right button
    back in one click.
    Hope this helps. =)
    Oct 10, 2009 | Bulova Watch
    Hi, I need help with this brand of Roxy blue Calculator watch insurction and I got them from ebay but she dont have any booklet. I try to set the time. I can't do it so would you make simple explain to me...
    Had same problem. Press and hold C (mode) until the display flashes. Then press C again (without releasing) to get to time. Press "Select" to move from sec, min, hours, days, etc. Press advance to go change the actual time.
    these directions work http://www.roxy.com/graphics/uc/roxy/manuals/Roxy_manual_watch_70s.pdf if you change the following: C=C Mode A=Select B=Advance
    Normal Time Setting 5.1 In Normal Display, hold C-Button for more three seconds and then push C-Button once. Tuesday flag and seconds digits will flash. Push B-Button once to reset the second to zero. 5.2 Push of A-Button once: Minute digits flash and advance by depression of B-Button 5.3 Push of A-Button once again: Hour digits flash and advance as above. 5.4 Push of A-Button once again: Month, digits flash and advance as above 5.5 Push of A-Button once again: Date digits flash and advance as above 5.6 Push of A-Button once again: Flag of weekday flash and advance as above 5.7 If push of C-Button during any changing time, Normal Display will be appeared
    Jun 14, 2009 | Watches
    Flashing digital display
    I just managed to solve this problem. Turn the digital face to the first screen which is probably flashing EOL with date. Then pull knob out as if you were going to set the time. Hold in two auxilliary buttons, you should see BAT come up on the screen. That should be it stopped flashing!
    Dec 25, 2008 | Tag Heuer Kirium Formula 1 Chronograph...
    Casio g-shock watch
    http://world.casio.com/wat/download/en/manual/
    try for the manual from here.
    riz.
    Nov 06, 2007 | Casio G-SHOCK 200M DW5600E1V Wrist Watch
    Tag Heuer Formula 1 CAC111D.BT0705 Wrist Watch Logo
    258 people viewed this question
    Top Tag Heuer Watches Experts
    Ansel Alberto
    Ansel Alberto
    Are you a Tag Heuer Watch Expert? Answer questions, earn points and help others
