Question about Briggs & Stratton Garden
Need valve settings for 14.5 ohv briggs - Briggs & Stratton Garden
  • 252 Answers
Hi
watch inlet valve open and close fully
set engine @ 1/4 past tdc on power stroke
sett inlet @ 0.003 thou and exhaust @ 0.005 thou
inlet valve is the one cloest to the muffler and ex is the other one
inlet has alloy push rod and ex has steel push rod
plug type is rc12yc
cheers hope it helps
here is web site
www.briggsandstratton.com
Posted on Aug 02, 2010
3 Suggested Answers
Dolfoff
  • 148 Answers
SOURCE: how to set static adjustment of the governor on a
You'll need to get a 3/8 wrench and a slotted screwdriver and locate the round governor shaft coming out of the engine block. The governor arm attaches to this with a clamping-bolt. You will notice that the round shaft is slotted for a screwdriver as well.
Loosen the clamping bolt slightly with your 3/8 wrench, insert your screwdriver and rotate the round shaft clockwise until it stops. (It has VERY little travel, so turn it both ways to verify that your are at FULL clockwise position.)
Hold screwdriver there and move the governor's arm in the same (clockwise) direction until the carb's throttle is set to WIDE OPEN throttle. Still holding the screwdriver clockwise, retighten the clamping bolt with the wrench.
Next, move the throttle lever on the dash of the tractor to idle and back to full several times and observe the carb's throttle shaft, it should come down from full throttle to idle and back again freely.
Start the engine and be prepared to shut it off if it over-revs.
If it doesn't over-rev, your base-line settings are correct.
Hope this is helpful,
Dolf-
Posted on Oct 17, 2009
  • 16317 Answers
SOURCE: My 24hp Briggs and Stratton ohv engine has bent push rods.
unable to answer if valve opened or not but does sound like ur bottom valve is bent or piston made contact and bent it to fix need to remove head and replace valve also need to inspect piston face is not damaged from possible contact
Posted on Apr 12, 2010
Valve settings on 17hp briggs ohv engine
.004 to .006 i set them at .005 no problem run great start easy
Nov 15, 2016 | Garden
What briggs valve gap lt1000?
Briggs opposed twin cylinders don't have valve gap. Single Cylinder OHV & V- Twin OHV do.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/anthony_e4f197748c31eabd
Jul 13, 2014 | Briggs & Stratton Garden
Need valve settings for 13.5hp ohv vanguard
Your owner's manual tells you
Apr 20, 2013 | Garden
How to replace ohv cam on 17.5 briggs model 31c707-1346-b2
I SET THE INTAKE VALVE AT .005 AND THE EXHAUST VALVE AT .003 AND THE EXHAUST VALVE MOVES ONLY HALF THE DISTANCE OF THE INTAKE. IT IDLES OK BUT GIVE IT SOME GAS AND IT BACKFIRES THROUGH THE CARBURATER AND SHUTS DOWN.
Oct 20, 2012 | Briggs & Stratton Briggs Stratton Intek V...
Briggs straton ohv on tiller , govener will not work, runs at high speed all the time, starter rope has become extremely hard to pull, will not spin engine.
The hard to pull, will not spin the engine issue could be because you need a valve adjustment. A valve adjustment is critical because it enables the built-in compression release on the Briggs OHV engine to function correctly and enable an easy start; plus of course, smoother running. Remove the valve cover and adjust those valves at 1/4" down past TDC on the power stroke. You WILL see a difference in the engine once you do the adjustment.. Here is a Briggs spec chart which has those values for their engines. Yours should be listed in the OHV engine section.
http://www.briggsandstratton.com/engines/support/frequently-asked-questions/~/media/71BB9DA0BD4D4C19A0DA611923A0B80A.ashx
Here is the Briggs recommended tutorial on HOW to adjust those valves. Scroll down this page to "Adjusting Overhead Valves"
http://www.briggsandstratton.com/engines/support/frequently-asked-questions/Servicing%20the%20valves/
May 22, 2011 | Garden
Need valve clearance for 24 ohv engine,4457770168e1
You should be able to get the settings from the Briggs & Stratton Website
Aug 24, 2010 | Briggs & Stratton Briggs Stratton Intek V...
How to change electric starter on vanguard 14 hp v twin vertical shaft.
Please, help me to regulate valves on Vanguard B&S 14HP OHV model:294446 tip:1141-a1. I don't know how. Thenks. My adress kolya-kolyanof@rambler.ru
Mar 31, 2010 | Briggs & Stratton Briggs Stratton Intek V...
B/S 23 H.P. OHV Hard to turn over.
THE VALVE NEED TO BE SET TO 3 TO 5 THOUSANTHS
Apr 25, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Garden Logo
267 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
