Question about Dell Axim X5 Pocket PC
Power Button My power button won't turn my Axim off so the battery keeps dying since I can't power it off.
  • 35 Answers
You could just go to the power settings, select advanced and choose turn off after x minutes of none use in the drop down. This will power the unit down after you stop using it. No need to add another program.
Posted on Dec 09, 2008
    Problem Solver:
  • 10 Answers
Hi Monkeycdo,
There's a program that gives you the Windows XP shutdown window to turn the Axim off (http://classic.pocketgear.com/download.asp?product_id=6666)
the main page is: http://freewareppc.com/utilities/shutdownwindowsxpstyle.shtml
However, you can also adjust the power settings to turn the unit off after a certain time of inactivity.
If the power on is a problem, the power control settings have an option to "Turn on Device" if a program button is pressed. Check that option and in the future you can press the bottom buttons on the front and the unit should come on (you will have to close the program window that you requested when you pressed the button);
let me know how this works (grandgregojunk [at] yahoo.com) or if you have any questions.
Good luck,
Greg
Posted on Jun 14, 2008
I forgot my password
Hi, Once you forget the Password, your only option is to perform a Hard Reset on the device and reset back to Factory defaults. You data will be lost, as this is in place to protect you in case the device has been lost or stolen. If you have backups, or sync the device with Outlook, you can run a restore or re-sync the device to populate the data back into your device. To do a hard reset:
  1. Press the Power button to turn the Axim unit On.
  2. Press and hold the Power button down while using the Axim stylus to press the Reset button at the same time.
  3. Release the Power button and the Reset button. The To clear all data in the memory screen appears.
  4. Press the Contacts button on the Axim to delete all of the data in the memory of the Axim handheld.
  5. Press the Mail button on the Axim to cancel the operation without losing data.
  6. THANK YOU
Dec 23, 2010 | Dell Axim X51v Pocket PC
Dell Axim X50 PDA won't turn on
try a hard reset
Dell Axim x50 / x50v / x51 / x51v:
Make sure the device is on before performing hard reset. To hard reset, press and hold the power button and press in on the reset button (reset hole) on the back of the unit for about 2-3 seconds. Release both buttons and you will see a confirmation screen asking you if you would like to clear all data in memory. To do so press the Contacts button. To cancel press the Mail button.
IT may be that the mainboard is faulty and would need to be replaced.
Aug 03, 2008 | Computers & Internet
Tip
How to Acess the update screen on your Dell Axim PDA
hold down your power button and your wireless button both at the same time.
then press your reset button on the back of your Dell axim and release your reset button quickly, but keep on holding the power button and the wireless button until a white screen pops up saying something about updating.
If a screen comes up about resetting to factory default, get out of that screen.
on Apr 10, 2010 | Dell Axim X50 Pocket PC
Dell Axim x51 v
Hard Reset
NOTICE: When you do a hard reset, you lose all the data stored in your device
Flash memory, and any programs that you installed on your device.
Do a hard reset if:
  • You want to restore the device to factory default settings.
  • You forget your password and need to reset it.
  • Your device is experiencing severe operational problems and you have already attempted a soft reset.
NOTICE: It is strongly recommended that you back up your data before you do a hard reset.
To do a hard reset:
Sep 13, 2009 | Dell Axim X51v Pocket PC
I have a dell axim x51v I made a password change and entere it into a digital rape recorder the recorder died on me and I do not remember the password as it happened 2 day after de change my cuestion is...
Hard Reset:
Do a hard reset if:
To do a hard reset:
Sep 03, 2009 | Dell Axim X51v Pocket PC
MY DELL AXIM X30 WILL NOT TURN ON
My Axim X30 would not turn on using battery power but would turn on when connected through charger adapter.
Solution:
1. Connect AC adapter directly to the charger adapter and then to the Axim X30 and to the electrical outlet.
2. Charge battery until power button is solid green.
3. Press the power button to power on.
4. Remove cable from cable connector leaving the cable connector connected to the Axim X30. The Axim X30 will remain powered on.
5. Turn the Axim X30 off.
6. Turned the Axim X30 on using battery power.
7. Remove cable connector from Axim X30.
Apr 07, 2009 | Dell Axim X30 Pocket PC
Dell Axim x51v that will not power on.
Assuming the battery is not dead, try taking the battery out for a few seconds to be sure the PDA is turned all the way off. Put the battery back in and close the back. Use the stylus to hold the reset button in (on the back) while you press and hold the power button. If the battery is dead do this while it is connected to the charger. It should diplay a message telling you to press the mail button (to the left of the cursor control button) to the reset to factory defaults. Caution this will erase everything in the built in memory including any programs you installed after you recieved it.
Hope this helps
Dec 15, 2008 | Dell Axim X51v Pocket PC
Power button flashing
Clean the battery connectors on both sides, so on your Axim and on your battery.
Also try to push the battery against the connectors, maybe put a sheet of paper between it or so.
Mar 28, 2008 | Dell Axim X50v Pocket PC
It won't turn on, bt the battery still charging
Another way I've found to do this is to press the power button and reset button at the same time. Then when you get the message to clear all data press cancel. I get this every time I re-charge my axim in the cradle. Doesn't anyone have a better solution? When it happens I have to reset my time. It's usually a day behind.
Sep 14, 2007 | Dell Axim X50v Pocket PC
Dell Axim X 50 blinking power button
My power button was also blinking orange/green/orange/green. I pulled the battery and put it in the back of the cradel. It still blinked there too, orange/green. So I bought a battery. Does this sound like your issue?
Jun 27, 2007 | Dell Axim X50v Pocket PC
Dell Axim X5 Pocket PC Logo
245 people viewed this question
Alun Cox
