Question about Ricoh Aficio 2015 Copier
My ricoh aficio 2015 showing sc 144 code please help us to remove it
    President:
  • 2,072 Answers
• The flat cable between the BICU
board and the SBU has a poor
connection
board and the SBU is damaged
• BICU board defective
• SBU defective
Posted on Aug 02, 2010
I have Ricoh aficio 2015, it showing error code sc-114, please how do I clear the code.
you can make a brush air to the scanner and clean the mirror
if not
replace the ccd
Nov 12, 2016 | Ricoh - AFICIO 2015 Printer
How to clear error code sc 541 on ricoh aficio 2015
i want to make my nashuatec mp 500 copier to be dip in printig
Oct 04, 2012 | Ricoh Aficio 2015 Copier
ERREUR SC 144
connection
May 31, 2011 | Ricoh Aficio 2015 Copier
Showing the code Sc-144 on display and not working the machine model m-1500
If restarting the machine with the main power switch (red switch), or by unplugging it, then you have a defective circuit board (either BICU or SBU) -and you'll definitely need a technician
Aug 18, 2009 | Ricoh Aficio MP1600SPF Copier
Sc 481 on my ricoh aficio 1224
moz-screenshot.jpgmoz-screenshot-1.jpgThe problem (s) could be; defective main motor, image transfer belt out of position, belt mark blurred or absent.
A ITB belt inspection and/ or repair would be a job for tech.
Or you could just order a new PCU which would fix the problem.
Jan 08, 2009 | Ricoh Aficio 2015 Copier
Error code sc 500
Main motor lock error
Failed to detect main motor lock signal for 7 checks in succession (total of 700ms) after main motor started to rotate, or after last lock signal was detected.
Main motor defective
Too much load on the drive mechanism
Motor driver damaged
Oct 19, 2008 | Ricoh Aficio 2015 Copier
RICOH 2015 error code sc 500
Main motor/ transport motor lock/ fusting motor error.
The only thing you can do is check for any obstructions in the machine.
That needs to be looked at by a service because the problem could be a motor, a pcb, or a power supply.
It can be a lot of troubleshooting to do.
Oct 18, 2008 | Ricoh Aficio 2015 Copier
Ricoh Aficio 2015
Pressure roller warm up error. Usually means that the fuser roller isn't at the right temperature when you turn the copier on.
Try turning the copier completely off. Wait 30 seconds. Turn it back on again and see if it goes away.
If not a technician should look at the fuser section to see what the problem is.
Jul 15, 2008 | Ricoh Aficio 2015 Copier
Error
I do not recognize either of these codes (187 or 387) as part of the Aficio 2015 error list.
If the code is displayed on the screen, physically TURN OFF the copier with the main switch (red switch), wait 10 seconds and turn it back on. If it's an erroneous error, this should reset the error code. NOTE: THE ERROR CODE MUST BE DISPLAYED FOR THIS TO WORK.
Jul 08, 2008 | Ricoh Aficio 2015 Copier
Ricoh Aficio 2015 Copier Logo
501 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
