Question about Goodman Heating & Cooling
I had the heating elemnt replaced in my unit and since that time I don't have the air flow volume I had before it was replaced and now I can't cool my trailer. The air is real cold (my vents is real wet) but I don't seem to get enough air to cool my trailer. What could be my problem? Model #PGB030075-1 and Ser #0104617125.
  • 407 Answers
Some things that would change air flow in a system are:
Blocked/Clogged Return Air. Usually a dirty filter.
Blocked/Clogged A-Coil. Inside the coil box, you have to remove the cover that is on the coil itself, unless it's a downflow, then you can see on top of the coil if it is clogged or dirty. You can usually clean it with a small wire brush.
Fan Settings Have Been Changed. On the electrical board inside the furnace, you will have terminals that your fan motor wires connect to. You should have a terminal for heat, one for cool, and two that are marked as "Park". The BLACK wire from the motor will be the highest speed setting. You will have this information on the schematics on the back of the furnace door panel also, they are fairly easy to read. All the speeds are HIGH/MED HIGH/MED LO/LOW. The two speeds you don't want, you place on the PARK terminals.
Furnace Blower Motor Getting Weak. If there seems like there is no change in the speed settings, then your motor could be going out and would have to be replaced.
These are just a few possibilities that you can check out. Hope it helps and good luck!
Posted on Aug 01, 2010
Testimonial: "I find this absolutely precious and am sure it will solve my problem. THANKS!"
Dryer takes over two hours to dry. The blower spins and the heating element comes on, but gets the vent in the back where the heat entes the dryer so hot it burns little circles in our clothes.
Check for air flow issues. Remove hose at the back of the machine and run it. Form an opinion about AIR VOLUME. Hook hose back up, turn machine on, and go outside and check the air volume. My bet is you have an air restriction. You need really good air flow for the system to work correctly. The large quanitiy of air flow cools the pieces, stop or restrict the air flow and everything overheats.
Jan 16, 2011 | Dryers
I replaced a bad 325 degree thermal cut-off on my kenmore dryer and 30 minutes it went out again. any suggestions?
Two cut off units will not be bad, and they should reset when cooled. Check your air flow. pull the hose off of the back of the machine, turn it on and form an opinion of the volume and force of the air flow.....Hook everything back up, turn on machine, go outside and verify VERY SIMILAR air volume and force.
If the air is restricted, the system will overheat and the limiters will trip.
Dec 24, 2010 | Kenmore 62802 Electric Dryer
THe a/c has very weak flow of air blowing even with the fan on high. My last carrier had a high volume of air coming out of the vents which was adjusted by the installer as I desire room by room. This...
It sounds like you got shafted and the guy installed a smaller air handler unit with a smaller motor to try to make more of a profit...
The problem is getting an unbiased opinion from someone who knows their stuff...sad to say but stuff like this happens all the time...
Here are a couple of tips that I wrote that may help you...
What Size Air Conditioner Do You Need?
http://www.fixya.com/support/r3636709-size_air_conditioner_need
Heating and Air Conditioning Scams
http://www.fixya.com/support/r3623166-heating_air_conditioning_scams
heatman101
Jul 23, 2010 | Carrier Heating & Cooling
DRYER TAKES 2 CYCLES TO DRY. WHAT CAN BE THE PROBLEM
Check to make sure lint hasn't built up in the area of the lint trap and on the exhaust where it leaves the room. Improper air flow will cause the drier to over heat and shut down the elements to prevent a fire. Once the elemnts are cool then they start again until they reach that temp. again then they shut off. So check for lint buildup before anything else
Hope this helped
Dave
Mar 03, 2010 | Dryers
Have a goodman 3 ton heat pump - ac worked excellent this summer - however when in the heat pump mode we hear sounds like gravel or rocks inside the big copper line - heat works but what causes the sounds/
You are reversing the flow of refrigerant in the heating cycle. Since liquid is now flowing through the suction
line it has less volume than the gas from the cooling
cycle that was flowing through it.. Making sure the outdoor unit is soundproof might eliminate this.
Feb 14, 2010 | Heating & Cooling
Running high head pressure in heating cycle runs fine in a/c cycle
Check your indoor air filter. When the unit is in heat pump mode the indoor unit is cooling the air, ie. removing the heat from the unit. If the air flow is restricted then the unit will run high head pressure. If the filter is clean then maybe something else is restricting the air flow of the indoor unit. The other possiblity is that the unit is over charged. When in cooling the overcharge will not create the problems that it will in heating mode. The only proper way to charge a heatpump is to remove ALL the refrigerant and then wiegh in the proper amount of refrigerant into the system.
Nov 19, 2009 | Heating & Cooling
Hot Surface Indicator Light has not turned off since last night.
if the hs ind light does not turn off then that particular heating elemnt needs to be replaced.heat sensor is built in the elemnt.when elemnt is turned off and it cools down it makes a switch to open and inturn ind light turns off.but sometimes thst gets stuck and light remains on.but do not worry abt element,it remains off,its just that indicator light that remains on.
Jul 30, 2009 | Jenn-Air JED8430 Electric Cooktop
AIR IS NOT WORKING. hAVE SYSTEM SET AT 72 AND STILL SHOWS 85 DEGRESS IN HOUSE. PIPES AT THE TOP OF UNIT SEEMED TO BE FROZE
There are two things that make a central air conditioner freeze up, they are poor air flow, that means check your air filter, and your system is low on refrigerant, and that will take a serviceman to fill on refrigerant. For the time being set your thermostat cool/heat switch to off, and turn your fan switch to on. This will thaw out your cooling unit, and when the ice is gone you can switch the heat/cool switch to cool to resume cooling until you have figured out which problem you have.
Jun 24, 2009 | Heating & Cooling
We need to install the lower heating element in the upper oven
ill aasumme that yo can see the elemnet in question, and its not a "hidden bake" elemnet located under the oven floor.. should be an easyrepair, with a little bit of patience. don trush shoudl only take 10 min anyway. TURN OFF POWER> LIVE WIRES TO ELEMENT AT ALL TIMES. REGARDLESS OF UNIT ON OR NOT!!! ther ewill be 2 screws along the bottom of the element holding the elemnt in the unit. after emoving carfully slide the old elemnt out a few inches, slowly pull out, for the wires are still attached to the back of elemnt and you want them to stay there you dont want them to disconnect and fall behind unit, (you will then need to remove the unit form the wall to access htem). so pull slowly espescially if you feel resistance in the wiring. after you getit out far enough simply unplug and plug in the new one reinstalll and you shoud be fine
Nov 20, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
My air conditioning unit is not blowing as cold as it did, nor is it blowing as hot as it did in the heating mode
90 percent of the time the freon charge is low and lack of freon lessens the amount of compressed heat that can be created and also the amount of heat that can be extracted. hence less cooling and less heating. however the exact same thing can occur when a change over valve gets stuck partially between heat and cool . it then mixes the hot and cold together and you get poor cooling and poor heating. you check it with a gage. fed law requires that you have an epa certification to apply a gage. low pressures in heat and cool on both high and low pressure gages are a sign of low charge. if low pressure and high pressure are close to the same on both gages then a good chance valve is stuck half way between. you can also sometimes check by feel . at the change over valve two lines should be virtually to hot to touch and two should be cold to the touch. one is heating flow and other is cooling flow. if the valve is stuck then temps will be within a few degrees of the same on all. low charge and the hot lines won't be hot hardly .and the cold line s barely cool. look for white frost forming in the heat mode outside at the condensor tubing shortly after you turn on the heat. thats a sign of low charge. good luck.
Nov 04, 2008 | Heating & Cooling
Heating & Cooling Logo
90 people viewed this question
Top Goodman Heating & Cooling Experts
Paul Carew
Tim Whalen
christian nielsen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
