How do I keep rain from entering the tube opening through the window and into the air conditioner ? model LP0910WNR
  • gerk667 Aug 01, 2010
    sounds too complicated
    President:
  • 4,070 Answers
Hi! Mostly, the cure is putting an overhead roof like covering that protects it from the rain. Hope this helps and have a good one!
Posted on Aug 09, 2010
  • 10,319 Answers
If this is a window unit rain will get inside of it no matter what. It can not be covered while running. Also the unit must bet set with a slight pitch angling towards the outside. If the unit sits level in your window it will leak inside your home.
Posted on Aug 01, 2010
  • frank thomas wilson
    frank thomas wilson Aug 02, 2010
    The tube opening should be facing downward & not upward
    The tube is for the drain & gravatation with weight is downward here on earth
  • 4,924 Answers
If you are referring about hoe to keep the rain getting inside by the hole that the tube is getting in ...it depends on how is the hole in the window made...If it is bigger than the tube ...and possibly square and not round..than the easy fix is with some Plexiglas ..and some strong adhesive..just cause the plexiglas is kinda plastic and ... can be easily cut in the form of the hole ...and around the tube ...tidest that you can ..and glued directly on the external side..around the tube ...than to make it waterproof ..use a silicon tube ..and fill the edge ...The silicon stuff is the solution in the case that the glass is already tide cut around the tube ...too...just use a transparent silicon spray ..the kind they use in the pluming ..and isolate it well from both sides...it will be kinda esthetically enough too cause there is transparent kind in almost any hardware store..or construction materials store..
  • Catalin Turcu
    Catalin Turcu Aug 01, 2010
    you do not specified if the hole in the window is cut to almost fit the tube ..cause in this case all you need is a silicon tube ...and to fill the edge of the glass until you isolate the space between ...this will be the kind used on the plumbing ...
Keep getting code e1
According to page 24 of your owner's manual, the E1 error is indicative of a short circuit in the Indoor Air Thermistor. The unit will likely require service.
Good luck,
Marty
Jun 21, 2014 | LG Electronics LP0910WNR Portable Air...
How do you add feron to lg lp0910wnr ac
I would suggest taking it to your local service shop. They can add the nedded service valve and add freon.
Jun 06, 2014 | LG Electronics LP0910WNR Portable Air...
How do I drain the water tank in my LG LP0910WNR Air Conditioner
tienes que ver por la parte posterior un tapon de color ***** yquitarlo y luego sacar un corcho de goma y el agua saldra
Jun 12, 2012 | LG LP0910WNR Air Conditioner
My unit show a error code E1
Here is a tip that gives a further explanation of that E-1 code. The causes ofthe E-1 code can be varied depending or the brand of your air conditioner.
Read through this tip... it will help you understand what is happening withyour window air conditioning unit and give you some things to try to help youget your problem resolved.
E-1 Code on Window Air Conditioning Units
heatman101
Jul 07, 2011 | LG LP0910WNR Air Conditioner
Does portable air conditioner made by LG have a 24 hour timer? model # LP0910WNR. If so how do I program it? Thanks
Maximum models and brands having 24 hrs timer. And yours also one of that. If you have clock in your remote keep in what time it should be on and off. If no clock, Press timer on it display as 00.00. Press < or > till you get 24.00. Helpful?
Dec 30, 2010 | Heating & Cooling
Why do most window air conditioners have vents on top - would not rain get in and ruin something? Should I be concerned?
Thee window air conditioners are designed to keep the rain water on the outside. There are no components that the rain can get to damage anything.
May 07, 2010 | Haier hwr10xc6 Air Conditioner
LG air conditioner window unit use in the rain
please check the housing of the air conditioner.
see to it that there is no vent or openings at the top of the housing for the rain to enter.
you can use it even when it is raining.
tnx 4 using fixya,
drcool
Oct 03, 2008 | LG Heating & Cooling
GE air conditioner with air louvers on top of case - problem?
Most fan motors are allergic to water. You should carefully examine the places where rain could go and decide whether GE has sold you a risky situation. After all, they have left it up to you to make the decision.
I wouldn't buy one with openings on the top and I wouldn't keep one after GE has demonstrated that not responding is the kind of help you will receive.
Jul 22, 2008 | Heating & Cooling
Heating & Cooling Logo
26 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
