Question about LG LFX25960ST Stainless Steel French Door Refrigerator
When I get ice through the door dispenser, after I pull my cup away it sometimes (1 out of 4) makes a loud buzzing noise followed by a click. Everything seems to work ok, I don't see anything jammed in there or anything like that. What causes this sound and can I fix it myself?
    Genius:
  • 1,478 Answers
I guess this a similar noise when it is jammed with ice. Kind of a loud buzz but it does not really sound like anything is moving. It happens when the door/chute is stuck.
I suggest you unplug the fridge and then visually inspect the ice maker...try to pull the chute open...or run the ice maker and verify the door is opening. If the sound is occurring 100% of the time the door could be off its track or misaligned.
If you try to open the door it should have resistance, like it is sort of spring loaded. Generally this outer assembly is only held on by 2-3 screws...if you are handy at all you could try removing it yourself to get a closer look at everything. It also could be the gearing in the ice grinder.
Shut off the icemaker and take out the ice bin and empty it. Make sure that there is no ice melted and refrozen on the bottom. I've also seen where ice in the bin has frozen together in large clumps and it makes a heck of a racket.
Take care.
Posted on Aug 01, 2010
  • alan598 Aug 01, 2010
    Thanks for your quick reply. This happens about 25% of the time .. and ice always comes out (I don't think I mentioned that). I'm wondering if maybe the solenoid that opens the chute is just burning out or something, is that possible?
    The other 75% of the time it makes a much quieter humming noise and then click -- I assume this is the normal operation. So I don't think its off its tracks, I will see if I can take it apart and get more info.
I have a ge adora fridge that when pressing the lever for ice makes a loud humming noise & feels like freezer wants to explode. Cab anyone tell me if they have ever run into this issue
You probably have a ice dam in your ice tray. The anger is trying to dispense if but if the cubes have frozen together and produced a large chunk of ice it cannot break up. Open the freezer door completely and lift up and pull out through ice tray. Remove ice until dam removed. Reassert tray and make sure to turn ice maker back on. It is essy to inadvertently bump switch. Try dispensing ice to see. If noise went away.
Hope this helped!
Apr 19, 2016 | GE Refrigerators
Why is icemaker making a clicking sound?
Ice Maker Not Dispensing Ice ' ThriftyFun
www.thriftyfun.com/Ice-Maker-Not-Dispensing-Ice-4.html
Sometimes your refrigerator ice maker makes ice, but does not dispense it. ... If it gets pushed all the way back to the ice maker it prevents the metal arm from full ... Itry not to put anything on the shelf over the bin and also try to keep it pulled out just a little ... My ice maker is making a clicking noise and not making much ice.
Ice maker making ice, but won't come out thru door
www.appliance-repair-it.com/ice-maker-making-ice-but-wont-come-out-...
If when you attempt to dispense ice (and it doesn't work) the whole refrigerator seems to .... Many have just bought a new refridgerator or don't use the ice dispenser. ... I'vetried to decrease the cold in it from the dial and that doesn't help. ... The motor was working and the auger would turn with no ice in bin but the added ...
Dec 25, 2015 | Samsung RH29H9000SR RH29H9000SR 29 cu. ft....
Amana AFD2535FES makes loud buzzing noise
When a start relay and the coil that opens the water for the ice maker or the water dispenser begin to weaken they some times buzz. Its possible you will need to either replace the=> 67003753 Water Inlet Valve
or the compressor=> 67005560 Relay or overload with run capacitor
Here is a parts manual for your=> AFD2535FES and a user manual=> HERE If you have questions please ask thanks Sea Breeze
Oct 18, 2012 | Amana AFD2535FES Stainless Steel Bottom...
Icemaker makes a loud buzzing noise when dispensing ice.
This would be your dispenser door solenoid making the noise, if left alone with out replacing it may end up causing the control board to fail. The part is number 13 on this diagram. http://www.whirlpoolparts.ca/parts/fspShowPage.php?model=MSD2732GRW&pageNo=17
61005884 is the part number you will need to get.
Apr 18, 2010 | Maytag MSD2732GR Side by Side Refrigerator
LFX25970 Bottom Freezer Refrigerator This morning it began to make a clicking noise coming from the ice/water dispenser and cold air was coming down from the opening. I pushed the lever for ice and it...
You may have an issue with one or more of the following:
* icemaker
* dispenser actuator
* ice chute door assembly
* ice dispenser solenoid (if the solenoid is stuck in an open position, the ice chute door/flap would remain open allowing cold air to escape).
Contact an appliance service company.
Feb 16, 2010 | LG Refrigerators
Ice dispenser appearing to get stuck in the open
The noise is probably the solenoid which operates the door or the one that switches it from cube to crushed ice. Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} You'll have to look to see what's wrong.
Remove the dispenser cover by gently prying starting at the bottom going round and round a little at a time to prevent from breaking it. When it's off the screws will be exposed to access the other components.
Here's a diagram of the dispenser which may help.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=48122&diagram_id=656733#d656733
Jan 08, 2010 | Maytag MZD2768G Side by Side Refrigerator
Water/Ice Dispenser buzzes loudly as soon as freezer door closes.
I am not sure what would be buzzing, but besides the parts in this area that are worked manually, this means that the working parts are not electric they are manual working parts, the parts that are electric are the lights and a switch for different ice types, if you have this option. You can remove the cover
by pushing up on the plastic plate that surrounds the ice/water area with the lights on it, on the back you will see the electric connections to the chip board, you could unplug these connections and see if the noise stops. Now every fridg is the same so make sure there are not any screws holding the plate
on before you try to push it up so it can be removed. Any questions please post back.
Mar 27, 2009 | GE Refrigerators
Loud Buzzing Noise from Behind Freezer
Sounds like the freezer fan blade is hitting on a build up of ice or frost. You may have a defrost issue, or it may be a one time thing, like the door was open for a long time (object holding door partially open) or also check the ice dispenser duct door to make sure it is closing. Sometimes a chunk of ice hangs up in the ice shoot, allowing moist air to enter freezer, resulting in the extra frost / ice near the freezer fan. You might also check the door gaskets, especially the bottom side where sugary liquid spills might cause a gasket to tear. #2: Long run times: If cooling is good, don't worry. Older refrig's often ran less time, but used much more electricity than the newer refrig's, even though new one run longer. (Like having a 40 watt light bulb on for 20 hours a day uses less electricity than having a 100 watt bulb on for 10 hours a day)
Aug 27, 2008 | GE PFS22SBSSS Stainless Steel French Door...
Loud humming noise as fridge is running
Hey everyone-
I recently fixed a similar problem with my freezer. I searched first and found this and a few other sites which listed this and wanted to provide input for anyone in the future.
I have a GE GSH25JSRF SS. It is about 3 years old. Several months ago I noticed when the evaporator fan in the back of the freezer turned on it would make an awful howling or whistling sound. Basically sounded like what you would hear from the window of an older house if the wind outside was blowing real strong. It was loud enough to hear on the other end of the house.
I was convinced that it HAD to be the air blowing over the venting or a gap that created that sound. But I read different solutions on the internet and decided to take a chance on simply replacing the evaporator motor and attached fan blade. That solution worked and my house is quiet again, thank god.
I ordered the parts from a supplier on the internet. Keep in mind, though, if you're not real handy it may be more than you bargain for. Might be easier to have a service guy come out.
I'm still not sure exactly what aspect of these parts caused the howling sound. It could be a bearing within the motor or perhaps the fan blade slipping due to wear. Either way, it's fixed now. Just wanted to share. Thanks.
Oct 04, 2006 | Samsung RS2630WW Side by Side Refrigerator
LG LFX25960ST Stainless Steel French Door Refrigerator Logo
107 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Mike
Mike
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
