Question about HP Mini 1000 Netbook
Netbook has been installing update 17 of 30 for 16 hours. States: do not power off or unplug your machine. Please advise.
  • 10,319 Answers
The registry has a glitch in it. Turn off and reboot and start over with the down loads
It is the only way
Posted on Aug 01, 2010
  • Anonymous Sep 20, 2010
    I am having the same problem with my HP netbook. It has been downloading Update 21 of 36 for almost 24 hours. I have tried to turn off the power and when I turn the power back on, the screen is still there, with the same message. I have even tried taking the battery out to make sure it would turn off, but when I put it back in and turned on the computer, the same screen is still there. What can I do????
  • frank thomas wilson
    frank thomas wilson Sep 20, 2010
    the hard drive is locked up so no help of any can get to to go again.
    if you did not try pressing all 3 keys at the same time (alt ctrl del ) do so now on this computer and see if a new window appears
What is E58
Good Afternoon Friend,
I understand you are receiving an E58 code on your Frigidaire Affinity washer, model# ATF8000FE. The E58 states that it is a high current on the motor phase. This could possibly be a false code, as well. I suggest resetting your appliance, by either unplugging it or shutting the power off at the circuit breaker, for 3-5 minutes. Restore power and start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 19, 2014 | Frigidaire Affinity ATF8000FE
What does error code E23 on a frigidaire affinty front load washing machine mean
Good Morning Friend,
I understand you are receiving an E23 code on your Frigidaire Affinity washer, model# GLTF2940ES. The E23 code states that the drain pump relay on the control board has failed. This could also be a possible false code. I suggest resetting your appliance, by either unplugging it or shutting the power off at the circuit breaker, for 3-5 minutes. Restore power and start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 18, 2014 | Frigidaire GLTF2940ES Front Load Washer
Windows 7 installing updates 1 of 2 1 stopped at 14 but hour glass is still spinning
Turn it off and let it try the updates again. It will pick up the updates the next time.
May 12, 2012 | Computers & Internet
Stuck on installing updates
DO THIS FIRST - Perform a hard resetIf a PC suddenly fails to boot properly, you should perform a hard reset as the first action. Performing the hard reset will correct many problems. If the computer still does not start properly, select your symptom from the list below to guide you to the recommended corrective actions.
  1. Disconnect all peripheral devices and remove all USB devices and SD media cards. You want to test the computer not the accessories!
  2. Disconnect the AC power adapter, remove the battery, and then press and hold the power button for at least 15 seconds to drain all residual power and restore default startup settings.
  3. Reconnect the AC power adapter (but do not insert the battery), Press the Power button, Look for glowing LEDs near caps lock and num lock keys, and Listen for sounds of a fan or other moving parts turning.
Feb 18, 2012 | HP Mini 1000 Netbook
Map update failed
https://youtu.be/C9JQGEK1-0o
Feb 12, 2018 | Garmin Nuvi 1450LMT GPS Receiver
I hav my ASUS Eee PC 1101HAB netbook, i was charging it while im using,after an hour or two, i noticed that it stops charging. i checked my charger and saw that the LED is off. i tried to unplugged it, and...
Hello.
Hello.
The most common reasons are the battery, power adapter/cord and power jack.
If you move/wiggle the power adapter at the point where it connects to the laptop, and the power goes off and on, the power jack is the problem.
The power jack is inside the laptop and either needs soldering or replacement.
If no change, the power adapter is probably faulty and needs replacement.
Also, power off and remove the battery. If the laptop powers on with just the adapter connected, your battery is faulty.
In any case, since your netbook is still under warranty, I strongly advise you to return it where you purchased, for a repair or replacement. A two-month old network should not have power problems.
Hope this helps.
Dec 26, 2010 | Computers & Internet
What do I do when my computer says, Please do not power off or unplug you machine. Installing updates 5 of 5. For about 6 hours now!!
Hi Good day!!! Sir/mam you will need to wait till it finish, because it is a Microsoft update.it is required for your pc to update cause your using a OEM Operating system (Original OS).
Don't forget to vote Thanks!!!
Oct 29, 2010 | Computers & Internet
Cannot connect to the router
Right click the network icon in the system tray. Click "repair."
If that doesn't work.Power off netbook, router, modem...
Turn on router. Then Modem. Then netbook in that order waiting 1 minute interval between each.
Everything should be functioning ok.
Dec 21, 2009 | Linksys WRT54G2 Wireless Router
HP Mini 1000 Netbook Logo
204 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
