Question about Cuisinart Coffee Makers & Espresso Machines
We have a Cuisinart CBC-1600 that has been working fine until this AM when the everything backed up and the coffee would not come through the filter and essentially overflowed. We cleaned everything out assuming the coffee was too fine. We tried making another cup and the same thing occurred. In both cases we ended up with a half pot of coffee with the other half still in the coffee filter.
rickzilla
  • 706 Answers
SOURCE: how do I clean the inside of a thermal coffee pot
white vinegar is never a bad choice..
Posted on Oct 11, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: How do I set the time on cuisinart coffee maker
Set the function knob to CLOCK
Press and hold the HR button for a few seconds if the clock display time is not flashing
Once display time is flashing:
Press and release the HR button a few times for it to advance - it will say "PM" on the display if it is set for PM
Press and release the MIN button to set the mins
Posted on Sep 29, 2009
SOURCE: Coffee overflows
I have a 1600 with the same problem. The problem is due to a poorly designed fit between the carafe and the drain plunger in the coffee basket. If you lift the carafe slightly, you will see the plunger has a long way to go. If you have the tendency to push the carafe fully to the back of the hotplate it makes this worse. OK, so now the fix, which worked for me. Find a small piece of plastic to glue to the top of the carafe lid. You just need a small dimple to push the coffee basket spring in further when you in sert the carafe on the hotplate. You should experiment a little first to see how thick it needs to be. Overall it's a poorly designed combination and someone needs a lesson in tolerancing.
Posted on Jan 10, 2010
  • 4 Answers
SOURCE: my 12 cup cuisinart coffee pot keeps shutting off
I have the same pot except for the 10 cup model, and it has been doing the same thing. I realized that I have never changed the charcoal filter inside, and I believe that may have been the problem. I removed the filter, ran vinegar through the pot several times as well as cleaned some nasty looking scum out of the water reservoir. I ran 3 pots of water after that. The problem has not recurred so far. I think it may be fixed although time will tell for certain.
Posted on Mar 27, 2010
SOURCE: the heater plate on cuisinart cbc-1600 coffee
Called the company and the representative told me that on the CBC 1600 series, it is intentially designed to turn off the hot plate after brewing because the stainless steel carafe will keep the coffee hot. If you are experiencing poor heating, her suggestion was to preheat the pot with really hot water before putting it under the basket. I can't help wondering if they have turned a bug into a feature
Posted on Jun 16, 2010
In my CBC-00, there was a hard filter inside the filterholder basket. It accidently got thrown away and now I cannot find a replacement online. Any ideas about how to find one? Thanks!
Contact the manufacturer directly and see what they can do. We have no other resources here. If this uses a standard cone filter you can buy a generic on line. I have one in use right now.
Jul 20, 2016 | Cuisinart Brew Central Coffeemaker 12 Cup...
My cuisinart cbc 1600 wont stay on its shows erl on the screen and shuts off .. what is this problem and what can do to fix it
There's a three year warranty on this unit. If it's less that 3-years old, contact Cuisinart for a repair or replacement.
Jun 04, 2016 | Cuisinart Coffee Makers & Espresso...
How do I remove the filter basket from Cuisinart Programmable coffeemaker CBC-5200PC Series?
I have this coffee maker and the basket comes out with the grinding cup and assembly. It's all one piece and pulls straight up.
You may need to pull a bit harder.
Jun 11, 2014 | Cuisinart DGB-300 Coffee Maker
Cuisinart CBC-00 series coffee maker seems to have lost power
Yes it has a short. Mine did the same. Cost to much to fix, cheaper To buy new one, if under 3 years old cuisinart will replace for $10 shipping charge. 1-800-726-0190
Jun 28, 2010 | Cuisinart DCC-1200 Coffee Maker
The heater plate on cuisinart cbc-1600 coffee maker does not stay on after brewing cycle to keep coffee hot. is this normal operation?
The CBC-1600 comes with a thermal carafe. therefore, it doesn't rely on a heater plate to keep the coffee warm.
Feb 01, 2010 | Cuisinart DCC-1200 Coffee Maker
We have a CBC-1600 10 cup coffeemaker. after brewing the coffeemaker beeps and turns off. The hot plate part of the coffeemaker will not stay on for longer than 5 minutes.
The CBC-1600 is designed differently than you might expect. The stainless steel, insulated carafe is designed to keep the coffee hot instead of a hot plate keeping a glass carafe hot. Some people like that style better (including me). Some people - like my dad - don't think it keeps the coffee hot enough.
Your coffee maker is working exactly as designed. The carafe itself is designed to keep the coffee at the same temperature as it was brewed.
Dec 24, 2009 | Cuisinart Coffee Makers & Espresso...
Coffee Makers & Espresso Machines Logo
57 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
