I have a frigidaire front loader that I've owned for about 3 years. It traps water in the seal and also has mold growing inside it from time to time. It smells so badly right now that my entire wash room has an offensive odor that leaks into the house if I leave the door open. I use this washer every day, I have 6 people in my house, so it's not from siting for too long. My clothes are not smelling clean anymore either! How can I file a complaint and what can be done about it?
  • Anonymous Jan 08, 2009
    I have the same exact problem. Black mold/smelly/ clothes do not smell clean. I have increasing asthma symptoms/headaches
    Genius:
  • 1,028 Answers
Unfortunately we hvae created our own problems on front loads .all front loads all brands retain water in door boot .few people today wash with plain chlorine bleaches as result bacteria and mold are more likely to occur best solution wash door boot regularly with bleach and water solution run a bleach wash (no clothes) every few months and leave door open slightly after use don't give up too easily more than 1 cleaning may be necessary and should be done regularly
Posted on Apr 25, 2008
I AM ALWAYS GETTING MOLD INSIDE THE LG FRONT LOADER. THE RUBBER SEAL IS ALWAYS MOLDY
Hi
Try using bleach with hot water, run a cycle with hot water and bleach. Or spray bleach +water mixture on the seal. Run a cleaning cycle with hot water and bleach or vinegar at least once a month to reduce the growth of mold in other parts of the washer. If the growth is very high then try and leave the door open for 4-5 hours and let it dry and then spray the bleach+water (3:1) mixture on the seal. Let it dry for another 2-3 hours. You may need to change the seal in case of extreme growth of mold. Hope this helps...
Daniel
Aug 30, 2010 | LG WM-2077C Front Load Washer
I heard you are suppose to clean the washer once a month to prevent mold,is that true?
I have never cleaned my washer as i use bleach in with the whites when i wash. its up to you. they do make a cleaner for that.
Oct 31, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
My Frigidaire Affinity front loader smells like mold
have you cleaned the main waste pipe as this surpisingly enough gathers a lot of gunk and in warm weather makes it smell,i say this cus we expeirieced this and i replaced rather than cleaned the waste pipe,worth a try it worked for me,rgds paul
Jul 07, 2009 | Frigidaire GLTF2940ES Front Load Washer
MOLD
Hello Friend, Sounds to me like you have a problem with the quality of your water supply going into your washer. Water quality could be a possibility. If the water contains alot of micro-organisms this could be the problem. When you are not using your front load washer the door remains closed trapping in moisture causing mold and mildew to grow. If you just repeat the cleaning process once again with bleach you should'nt have this problem anymore if you leave the washer door partially open when not in use. Happy to help, Tim.
Jun 25, 2009 | Frigidaire GLTF2940ES Front Load Washer
Black mold growing on gray rubber boot inside door.
Leave washer door slightly ajar after use to air out any moisture. Should prevent any future mold.
Apr 10, 2009 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire Front load washer mold
LEAVING DOOR OPEN BETWEEN USES ALLOWS WASHER TO BREATHE. BEING A CLOSED SYSTEM, IT'S KIND OF LIKE PUTTING A TUPPERWARE LID ON A BOWL WITH RESIDUE AND MOISTURE INSIDE AND LETTING IT GROW.
Nov 03, 2008 | Frigidaire ATF6000ES Front Load Washer
Affinity Front loader
Its normal for water to collect in the seal folds. The main thing is to dry it out completely. Take a dry cloth or sponge and try to remove excess water. Leave the door open to dry it out. You can even use a de-mould agent spray (many varieties available in the market). The main idea is to kepp the folds dry.
Hope that helps!
Sep 28, 2008 | Frigidaire ATF6000ES Front Load Washer
Hey, Buddy!
Well the mold is caused from the door being shut after you arte finished with the use of the machine. it traps the mouisture inside..To solve this use some bleach and water wipe it down around the door seal..then after each load just crack the door open this will allow air to dry out the inside and stop the mold
Mar 02, 2008 | Bosch WFMC 3200 Front Load Washer
Frigidaire washing machine collects water behinf door seal
your washer is a great washer BUT you Have to wipe the silly gasket all the time and leave the door open to let it vent and dry I deal with this all the time and no they dont tell you this when you buy them (they Should) but they want the sale then its your baby.I do warranty work for all the name brands and I see this on all of them good luck
Dec 17, 2007 | Frigidaire Affinity ATF7000ES Front Load...
Frigidaire has several mfr defects with their new front loading machines. The detergent/bleach drawer retains water, the door often leaks, water does accumulate in the door seal and the spin has broken twice on us and the machin is only 15 months old! Repair is contracted out by Lowes to independant repair companies, who demand payment, even when Lowes says it is covered under warrantee. What a waste of a large amount of money! We will NEVER purchase Frigidaire or recommend their products to anyone.
Oct 30, 2007 | Frigidaire GLTF2940ES Front Load Washer
Washing Machines Logo
134 people viewed this question
Top Washing Machines Experts
Richard Roth
Richard Roth
