Question about Drive Health & Beauty
ONE OF THE WHEELS ON MY MOMS DRIVE CRUISER 3 HAS A ATTACEHD METAL BRACKET WHICH IS BENT. DO YOU HAVE A REPLACMENT. THAT WE CAN PURCHASE
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 347 Answers
Hi im disabled myself,just glad to help,rate me if you like,i do this cause i care,not for profit.Visit the makers or ebay to see what you require,ebay is a great place to go & chances are there will be someone who has what you need.Hope i was of help Colin.
Posted on Aug 02, 2010
Rheem model: RCFA-HM4821AC I am trying to purchase the assembly that holds the filter in place. It might be called a tray, or a rack, or a bracket, or an assembly; I do not know what it is called.
Get an HVAC contractor to take a look at it. We usually remove the blower assembly, measure the back side of the unit, a fab a piece of 90° metal to help retain the air filter down. Like a shelf bracket that runs the legnth of the back side. The original installer didn't use a filter base. The unit sits on top of it and it's easy to change the filter. You can fabricate 1, or possibly find a pc. at a hardware store. Thin 90 degree metal. Hope this helps!
Mar 30, 2017 | Filter Heating & Cooling
Rear Drive Shaft Keeps Busting The Center Support Bearing
Check the u-joints in the drive shaft. Are they binding up? Work the u-joints around by hand with the driveshaft out. They should turn smoothly and uniformly-any looseness or stiffness in any portion of travel is a bad u-joint. Not sure if u-joints on Nissans can be replaced, or if you have to buy a new or used driveshaft with the u-joints. At one time u-joints were not replaceable, but some aftermarket suppliers were trying to change that. You would have to check at a parts store.
Check the frame piece that the carrier bearing and bracket sits on. Is it still straight and true? Not bent from being hit from underneath (like running over a large boulder)?
Is the bearing still good? What is getting busted, the bearing itself, or the rubber insulator ring, or the metal bracket that holds it all in place? Unless there is a problem in the rear differential (like locking up), it is likely a mis-alignment of the bracket or frame it sits on, or a seriously bad u-joint, or a seriously bent drive shaft.
Aug 03, 2013 | Nissan Pickup Cars & Trucks
Power wheels
If the wheels are bowed out it is usually caused by the steering linkage being damaged. Power Wheels vehicles have a long metal bar that runs between the two front wheels on the vehicle, on either end of the long bar is a plastic bracket. The bracket is riveted to the long bar and sometimes that can become loose or bent.
Remove the battery and flip the vehicle over, inspect the linkage and also the front axles to see if they are bent or damaged. If any parts are they need to be replaced, also make sure the tires themselves are not damaged.
Here is a link to the parts you will need for the repair.
Linkage: http://www.mendingshed.com/powsteerlin7.html
Tire: http://www.mendingshed.com/jeepb7659.html
Front Axle: http://www.mendingshed.com/b7659axle.html
Axle Cap: http://www.mendingshed.com/noname4.html
Let us know if you have any questions.
May 11, 2013 | Fisher Price Power Wheels Barbie Jammin'...
My dryer belt broke and it looks like one the wheels broke but i looked the part up on line and looks like the wheel comes with the kit i just want to know is this how it is suppose to look like it comes...
that one wheel in question is the "belt-tensioner" wheel or known as the "idler-pulley" that keeps the belt tight that turns the drum,it has a bracket and spring that hooks to the base of the machine.which is what puts pressure on the belt
Mar 08, 2011 | Dryers
Need rear wheel for my chicco litewat stroller
Hi, With he Chicco strollers there are at least 2 mechanisms for the rear wheels. You need to check which versions you have. 1) you will find a metal ball press stud on either side Of the chassis. Take a screw driver and push that metal ball in as far as you can to clear the housing for the wheel. Then pull the wheel away from the chassis. 2) Repeat for the other side 3) if both rear wheels come away WITH two a v shaped hinged metal rod then you can simply replace the rear wheels. I have seen them on eBay. 4) if yours pulls away and the hinged bracket has a material strap to it then these are not meant to be removed or at least I would not necessarily recommend that but of course the choice is still yours. You may need to purchase a replacement chassis again can be purchased on eBay. Hope this helps. Liz.
Jul 29, 2010 | Chicco Liteway Stroller by
I have Acer Extensa 4620 its dvd drive is not working where should i get repaired and how much will be it costs?
Fix it yourself heres how: purchase a replacment dvd drive heres an example of one you could purchase that will fit your model http://cgi.ebay.co.uk/ACER-EXTENSA-6602-DVR-K15RA-DVD-RW-LAPTOP-DRIVE-7865_W0QQitemZ330344511659QQcmdZViewItemQQptZUK_Computing_LaptopAccessories_LaptopDrives?hash=item4cea1138ab#ht_1313wt_732
Most dvd drives from any acer extensa will fit your model with the relevent bracket, which you will already have connected to your broken one.
ok now veiw the service manual here Service Manual and go to page 57 chapter 3 (67/142) here you will find the section called removing the optical drive module. its really simple just follow the instructions and pictures carefully.
Hope this Helps! Please Rate!
Nov 27, 2009 | Acer Extensa 4620 Notebook
Replace EGR valve on a PT Cruiser
The valve is located just above where the engine and transmission seam meets. There is the metal exhaust gas tube with 2x8mm bolts and a fiber gasket. The EGR mounts to the cylinder head with 2 10mm bolts and a metal gasket. There are 2 vacuum lines that go to the control solenoid, a black plastic pod moounted under the throttle body. It clips into the TB mounting bracket, and has a 3rd vacuum supply line and 1 electrical connector.
Sep 14, 2009 | 2002 Chrysler PT Cruiser
Water pump replacment precedure on 2001 jag stype 3.0
Hello
To replace water pump : Raise the car
1- Drain cooling system. 2- Remove drive belt tensioner clip (if there is one) 3- Remove accessory drivebelt * Rotate the belt tensioner counter clock wise , 3/8 inch square drive bar should do it
* Remove accessory drive belt
4- Lower the car 5- Remove the upper shield. 6- Remove the throttle body. 7- Detch the coolant hose from housing assembly. 8- Remove the upper radiator mounting bracket 9- Detach the hose assembly from the water pump and lower hose. 10- Remove the hose assembly * Detach the hose clips
11- Remove intake manifold support bracket * Detach wiring harness
* Remove intake manifold support bracket
12- Detach coolant hose from water pump 13- Remove coolant hose from the water pump to lower housing. 14- Remove water pump
Installation :
in reverse order and make sure to use new gaskets and seals
Jul 07, 2009 | 2001 Jaguar S-Type
Can't fold down a razor cruiser for storage, how do you do it?
There are two steps to release the handle for folding. Pressing the thumb lever is one step and the other is lifting the handle bracket up. The handle is held in place by two metal pins (one on each side of the handle bracket). The pins slip down into a notch on the scooters bottom bracket. If the lever won't push, you will need to spray some WD-40 or other lubricant on it as they do tend to rust. Once you have the thumb lever where it can be pressed down, you can then lift the handle out of the bottom bracket. This may be stuck as well so a light tap with a hammer may be necessary to release the handle.
Mar 31, 2009 | Razor Scooters Cruiser Scooter
Back wheel on my stroller is buckled
Hmm. You may be out of luck. Sometimes on the lower end brands, the back wheels may be riveted on to the frame, but if they are removable, you should be able to get new wheels from the manufacturer directly. www.gracobaby.com 1-800-345-4109 .
Good Luck! from Moms Just Know
Oct 22, 2008 | Baby Gear
Health & Beauty Logo
Top Drive Health & Beauty Experts
Colin Taylor
ray gallant
Marvin
Marvin
Are you a Drive Health and Beauty Expert? Answer questions, earn points and help others
