Question about Maytag MSD2351HE Side by Side Refrigerator
Hi..our maytag msd2351HE side by side is only making small amounts of ice..we are able to get water..Any suggestions?
  • Maytag Master
  • 1,606 Answers
I would suggest pulling the refrig out and removing the lower panel . On the right , there is a black box ( condensor ) . The fan pulls air thru the coils and dust , lint , etc , can block the air flow , causing the freezer to not get cold enough ( 5 degrees ) for the ice maker to work . Also check to make sure the fan there is working . If the fan is working and the coils are clean , try turning the freezer control slightly colder . If the fan is not working , replace the fan motor .
Posted on Aug 01, 2010
The door on our Maytag MSD2351HE did not shut entirely two nights ago. The freezer stopped working. Any ideas?
Can you hear and feel the fan blowing in freezer?
Problem will normally resolve it self after a day or two of unit going through defrost cycle. Do you see frost build up on back lower wall of freezer? If so the frost build up is blocking airflow. A hair dryer could be used to defrost, remove back panel and shut off refrigerator. Reassemble and check again after a couple of hours.
Jan 30, 2011 | Maytag MSD2351HE Side by Side Refrigerator
Water filter light will not turn green after installing new filter
try pushing the pin button that turns the light on an off when you open/close the door 5 times
it works on my fridge but it might work on yours too
Feb 19, 2010 | Maytag MSD2351HE Side by Side Refrigerator
Our ice machine does not make full ice cubes. they are small and not complete, they are full of holes.
The icemaker requires a water pressure of 1.5 - 8.5kgf/cm2. It is acceptable if the water supply fills a cup of 180cc with water in 3 seconds. The icemaker produces small cubes if the water fed into it is not enough and lumped together if too much water is supplied. In order to obtain the desired size of ice cubes, the amount of water supplied to the ice maker needs to be adjusted. Adjust the valve supplying water to the icemaker or the unit in general in such a way that right amount of water fills the ice tray.
Nov 06, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice maker makes very little Ice and the cubes are small.
The amount of ice is not dependent upon water flow, well as long as you do have flow, when enough water is in the maker it will shut off the supply.....ice quantity is dependent upon the length of the freezing cycle, the shorter the cycle the more harvests per hour. Adjust the timer so that you get complete freezing, but just barely
Jan 16, 2009 | Whirlpool GS6SHEXNL Side by Side...
Icemaker making small amount of ice
I RESET THE SWITCH ON THE ICE MAKER AND TURNED THE TEMP TO 9 FROM 5 AND IT STARTED MAKING MORE ICE. I'M NOT SURE WHAT WAS WRONG BUT IT APPEARS TO WORKING FINE NOW.
Dec 04, 2008 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
Maytag Conquest side by side. We have water in the door but no ice. Ice maker no longer makes ice. It dumped it's last load but has not refilled with water. Water gets to the door but for whatever...
if you hold the paddel on the left side in and dont block the small hole the beam will be sent to the reciever on the right side
the light will not blink but stay on
make sure that the switch on the right side is in the on position
hold in the paddel light should be on and not blinking
if it is blinking replace the emitter and reciever part no 4389102
May 18, 2008 | Maytag Refrigerators
Maytag side by side multi problems
1. Ice maker is not cold enough to start the ice making process.
3. having to take off the back panel is an indication of a problem in the defrost system. Call to have a service tech check this out.
May 15, 2008 | Maytag MSD2756GES Side by Side...
WATER DISPENSER
Check to see if the water line is kinked or if the valve is partly closed.next check to see if you have some blockage in the line. Shut the water off, remove the filter element,if you hace one and blow air in the water dispenser. If that doesn't do it, remove the line after the shut off, and blow air in before the filter. if all is good you may have to replace the water valve solenoid. Is your ice maker making ice ? if not it is not getting water either. let me know if this helps
Sep 09, 2007 | Maytag MSD2436GR Side by Side Refrigerator
NOT ENOUGH WATER.
Check to see if the water line is kinked or if the valve is partly closed.next check to see if you have some blockage in the line. Shut the water off, remove the filter element,if you hace one and blow air in the water dispenser. If that doesn't do it, remove the line after the shut off, and blow air in before the filter. if all is good you may have to replace the water valve solenoid. Is your ice maker making ice ? if not it is not getting water either. let me know if this helps..
My 9 month side by side refrigerator
Hollow ice would suggest poor water flow due to a blocked water filter, check the water flow before and after the filter, make sure you flush the water line out before fitting a new filter. Cheers Colin
Aug 12, 2007 | Maytag MSD2756G Side by Side Refrigerator
Maytag MSD2351HE Side by Side Refrigerator Logo
96 people viewed this question
Top Maytag Refrigerators Experts
Marvin
Marvin
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
