When using my computer i have a Mack truck that randomly blows his air horn in short blasts in no pattern just when he feels like it and always only short blasts. will sometimes even do it while i only have the desktop screen only on
    President:
  • 2,030 Answers
UHHHH.
You have made no sense here....what does a mack truck have to do with the operating system on a computer????.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
Posted on Aug 01, 2010
  • popa_bear37 Aug 01, 2010
    Sorry mate it just sounds like a mack might be a kenworth as i can't see it only hear the sound of what sounds like a truck air horn to me
  • Sean Wright
    Sean Wright Aug 01, 2010
    Where is the sound comping from??? Your computer???
    Sounds like if thats the case you have a corrupted system, or a bad sound card.
    Perhaps try reinstalling the operating system.
I have a 2006 Suzuki Forenza and my horn will not blow. Tried replacing fuse and the horn didn't sound at all, just blew the brand new fuse. Any help would be great!
its shorted, that line, the fuse blew saving you a nice fire.
are you using the correct fuel shown in you operators guide, see index , fuses.
do not mess under dash until you defeat those air bags, they can kill you. (break a neck easy) the schmatic is here.
official FSM
https://suzukipitstopplus.com/Products/1066-2006-forenza-reno-service-manual.aspx
$4 cost, dirt cheap.
first look at the actual horn, see damage there, it or the plug.
pull its plug and safe off (means tape it) and see if fuse blows yet?
always work the simple side first, not air bag side,or the
air bag clock spring, inside, steering last.
its either path A shorted, (most likely but fate wins)
or Path B, shorted relay coil.
if horn unplugged, fixes blowing fuse, the horn is bad.
easy huh?
Mar 18, 2015 | 2006 Suzuki Forenza
What is wrong with my 2000 Chrysler T&C van. The horn will blow at random times and continue for about 30 seconds. After the van sits for a while it usually will not do this anymore, but once the van...
My info says the horn switch is molded into the airbag module. You can't service the horn switch separately. You would have to replace the air bag module, if the horn switch is the problem? Air-bags can be dangerous, safety is your responsibility.
The wire going to horn switch is a ground for horn relay, it might be possible to use external horn button to sound the horn. That probably isn't very professional. Be careful with air bag.
Jul 08, 2017 | Chrysler Town & Country Cars & Trucks
Horn sticking and sounding on 2005 ford f150
The button or wire is shorted in the column. Horn relays turn on with a ground signal from the button, so the wire only has to come loose or the wire get chaffed to cause the horn to blow.
Aug 04, 2017 | 2004 Ford F150
Horn honks by itself
There is a short on the horn circuit
May 31, 2013 | 1989 GMC Sierra
After i changed the ignition switch in my 1983 cadillac now the horn wont stop blowing
did you removed the steering you might have grounded the wire for the horn , it works on a ground system i would check the wire again and make sure it's now shorted
Oct 04, 2012 | 1983 Cadillac Eldorado
My 2002 Nissan Altima's fan hardly blows any air. Even with the air blowing full blast, I barely feel any air at all.
your evaporator was dirty. The dirt that clog the passage way of the evaporator that why the air is minimal to feel. We usually pull down the the evaporator to be clean thoroughly.
Aug 16, 2011 | 2002 Nissan Altima
I installed a wolo air horn 419 and when I push the horn button all I here is the compressor and no horn.
It is possible that you may have reversed the polarity on the compressor; it may be "pulling" air instead of blowing it out. Remove the air hose from the compressor and put your thumb over the air outlet while pressing on the horn switch. If you don't feel air blowing out, reverse the positive & negative wires going into the compressor and repeat the test. The air horns should work at this time.
Note: Always install a relay on this type of horn system; the compressor puts a high amount of load on the horn switch if you don't.
Apr 09, 2011 | Honda CB 900 Hornet Motorcycles
The horn doesn't blow. at the horn relay,jumping 30/87 and the horn blows. terminal 85 is always +[positive],and this is correct.Terminal 86 is the ground for the 85/86 side of the relay. If I have the...
Your problem is most likely a defective clockspring assembly. This is also called "spiral cable assembly" it is located just under the steering wheel on the steering column and makes the connection between the main wiring harness and the circuits for the air bag and the horn. I cannot give you wire colors because your question did not mention year, make, model, engine size or whether the vehicle is equipped with cruise control or not. (cruise control makes a difference in the clockspring assembly used on your car.)
Anyway, the air bag and steering wheel has to be removed to fix it.
Dec 19, 2010 | Chevrolet 2500 Cars & Trucks
Horn starts blowing randomly
do you have a alarm on it. If so you need to disable it or turn it off. Other wise you have a short somewhere in your horn. disconnect the horn under the hood. Its usually upfront and looks llike a flat black circular device that has one wire going to it, unless you have a alarm then it may have more.
tepfy
Jan 27, 2009 | 2002 Lincoln LS
Random Horn Blowing
Wiring short, or incorrect wiring of your alarm system. Go through the wiring, and make sure everything is connected to what it should be, and check the material condition of those wires while you're in there.
Aug 15, 2008 | 1997 Chrysler Town & Country
Computers & Internet Logo
35 people viewed this question
Alun Cox
David Payne
David Payne
